Discuss
Kenmore Elite Dishwasher 665.16039403 Wash & Pump Problems
 in
Dishwasher Repair
Hi All, First time posting. Pulling my hair out on this one. I have been troubleshooting my dishwasher for months
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Kenmore Elite Dishwasher 665.16039403 Wash & Pump Problems
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 07-24-2018, 11:35 AM
Junior Member
Maico18 is on a distinguished road
Default Kenmore Elite Dishwasher 665.16039403 Wash & Pump Problems
Model Number: 665.16039403   Brand: Kenmore   Age: More than 10 years
Hi All,
I have been troubleshooting my dishwasher for months and replaced a couple of items: OWI sensor (performed diagnostic cycle after replacing it) and drain hose (check valve gone). Main problem was dirt and a film left on the dishes. Less of a problem with parts replaced but still not washing like it used to. Last night, ran a diagnostic cycle and then a Pots and Pans cycle with hi-temp and sani rinse with a Finish Cleanser only in the tub. This morning, the Clean LED was on but also the Sanitized LED was blinking. What I am more concerned with though is that I hear the wash pump (verified not to be the drain pump) running in the last half hour to 45 minutes of the cycle and then turns off when the cycle ends with Clean LED. The pump has been doing this since the beginning of my troubleshooting and I can't remember if it was that way when the dishwasher was running trouble free. Doesn't make sense because there is no water in the sump when it runs during this time. Between the pump running and the dishes not coming out as clean, I feel there is still a problem. Note that I have also timed a Normal cycle two days ago with the fill and drain times within spec. Cycle ran with 10 almost clean dishes for a full two hours which is excessive (should have been around 78 minutes, not 120!) per the diagnostic/troubleshooting sheet in the bottom panel. Further, it did a pre-wash, main wash and rinse and that's when the wash pump comes on with no water in the sump and just spins until the cycle ends with Clean LED on. Washing and Sensing LED's are on during the time the pump is on. Near end of cycle, the Sensing LED turns off.
Things I have done and conditions that haven't changed during the life of the dishwasher: water softener, hot water (I will check temperature tonight but never had problem with temperature and five people in the house), taken out both wash and drain pumps from sump, taken out sump, cleaned chopper and sump, pump impellers good and connected to pump shafts, removed control panel with no obvious signs of burned out components, cleaned vent, cleaned all spray arms (no dirt in ports), verified arms turn, water drains no problem, water gets very hot during hi-temp cycle, touching heating element during cycle is too hot to touch (resistance not checked).
I thought the control board might be bad but I can't determine that without replacing it and that is $250 later (I'm in Toronto, Canada area).
I am really hoping someone has an idea of what might be going on. All help is appreciated. Thank you.
Related Models
Kenmore 665110739120 DISHWASHER
Kenmore 665110739130 DISHWASHER
Kenmore 665110739140 DISHWASHER
Kenmore 665110739190 DISHWASHER
Kenmore 66513012K110 UNDERCOUNTER DISHWASHER
Kenmore 66513013K110 UNDERCOUNTER DISHWASHER
Kenmore 66513014K110 UNDERCOUNTER DISHWASHER
Kenmore 66513019K110 UNDERCOUNTER DISHWASHER
Kenmore 66513023K110 DISHWASHER
Kenmore 66513032K110 UNDERCOUNTER DISHWASHER
Kenmore 66513033K110 UNDERCOUNTER DISHWASHER
Kenmore 66513039K110 UNDERCOUNTER DISHWASHER
Kenmore 66513042K110 UNDERCOUNTER DISHWASHER
Kenmore 66513043K110 UNDERCOUNTER DISHWASHER
Kenmore 66513044K110 UNDERCOUNTER DISHWASHER
Kenmore 66513049K110 UNDERCOUNTER DISHWASHER
Kenmore 66513102K900 DISHWASHER
Kenmore 66513102K901 UNDERCOUNTER DISHWASHER
Kenmore 66513102K902 UNDERCOUNTER DISHWASHER
Kenmore 66513103K900 DISHWASHER
Kenmore 66513103K901 UNDERCOUNTER DISHWASHER
Kenmore 66513103K902 UNDERCOUNTER DISHWASHER
Kenmore 66513104K900 DISHWASHER
Kenmore 66513104K901 UNDERCOUNTER DISHWASHER
Kenmore 66513104K902 UNDERCOUNTER DISHWASHER
Kenmore 66513109K900 DISHWASHER
Kenmore 66513109K901 UNDERCOUNTER DISHWASHER
Kenmore 66513109K902 UNDERCOUNTER DISHWASHER
Kenmore 66513112K700 DISHWASHER
Kenmore 66513112K701 DISHWASHER
Kenmore 66513112K702 UNDERCOUNTER DISHWASHER
Kenmore 66513113K700 DISHWASHER
Kenmore 66513113K701 DISHWASHER
Kenmore 66513113K702 UNDERCOUNTER DISHWASHER
Kenmore 66513114K700 DISHWASHER
Kenmore 66513114K701 DISHWASHER
Kenmore 66513114K702 UNDERCOUNTER DISHWASHER
Kenmore 66513119K700 DISHWASHER
Kenmore 66513119K701 DISHWASHER
Kenmore 66513119K702 UNDERCOUNTER DISHWASHER
Kenmore 66513122K700 DISHWASHER
Kenmore 66513122K701 DISHWASHER
Kenmore 66513122K702 DISHWASHER
Kenmore 66513122K703 DISHWASHER
Kenmore 66513123K700 DISHWASHER
Kenmore 66513123K701 DISHWASHER
Kenmore 66513123K702 DISHWASHER
Kenmore 66513123K703 DISHWASHER
Kenmore 66513124K700 DISHWASHER
Kenmore 66513124K701 DISHWASHER
Kenmore 66513124K702 DISHWASHER
Kenmore 66513124K703 DISHWASHER
Kenmore 66513129K700 DISHWASHER
Kenmore 66513129K701 DISHWASHER
Kenmore 66513129K702 DISHWASHER
Kenmore 66513129K703 UNDERCOUNTER DISHWASHER
Kenmore 66513132K700 DISHWASHER
Kenmore 66513132K701 DISHWASHER
Kenmore 66513133K700 DISHWASHER
Kenmore 66513133K701 DISHWASHER
Kenmore 66513139K700 DISHWASHER
Kenmore 66513139K701 DISHWASHER
Kenmore 66513152K700 DISHWASHER
Kenmore 66513152K701 DISHWASHER
Kenmore 66513152K702 DISHWASHER
Kenmore 66513153K700 DISHWASHER
Kenmore 66513153K701 DISHWASHER
Kenmore 66513153K702 DISHWASHER
Kenmore 66513154K700 DISHWASHER
Kenmore 66513154K701 DISHWASHER
Kenmore 66513154K702 DISHWASHER
Kenmore 66513159K700 DISHWASHER
Kenmore 66513159K701 DISHWASHER
Kenmore 66513159K702 DISHWASHER
Kenmore 66513163K700 DISHWASHER
Kenmore 66513163K701 DISHWASHER
Kenmore 66513163K702 DISHWASHER
Kenmore 66513163K703 DISHWASHER
Kenmore 66513169K700 DISHWASHER
Kenmore 66513169K701 DISHWASHER
Kenmore 66513169K702 DISHWASHER
Kenmore 66513169K703 DISHWASHER
Kenmore 66513173K700 DISHWASHER
Kenmore 66513173K701 DISHWASHER
Kenmore 66513173K702 DISHWASHER
Kenmore 66513173K703 DISHWASHER
Kenmore 66513173K704 UNDERCOUNTER DISHWASHER
Kenmore 66513182K800 DISHWASHER
Kenmore 66513182K801 DISHWASHER
Kenmore 66513182K802 DISHWASHER
Kenmore 66513183K800 DISHWASHER
Kenmore 66513183K801 DISHWASHER
Kenmore 66513183K802 DISHWASHER
Kenmore 66513189K800 DISHWASHER
Kenmore 66513189K801 DISHWASHER
Kenmore 66513189K802 DISHWASHER
Kenmore 66513192K900 DISHWASHER
Kenmore 66513192K901 UNDERCOUNTER DISHWASHER
Kenmore 66513192K902 DISHWASHER
Kenmore 66513193K900 DISHWASHER
Kenmore 66513193K901 UNDERCOUNTER DISHWASHER
Kenmore 66513193K902 DISHWASHER
Kenmore 66513194K900 DISHWASHER
Kenmore 66513194K901 UNDERCOUNTER DISHWASHER
Kenmore 66513194K902 DISHWASHER
Kenmore 66513199K900 DISHWASHER
Kenmore 66513199K901 UNDERCOUNTER DISHWASHER
Kenmore 66513199K902 DISHWASHER
Kenmore 66513206K901 UNDERCOUNTER DISHWASHER
Kenmore 66513206K902 DISHWASHER
Kenmore 66513212K901 UNDERCOUNTER DISHWASHER
Kenmore 66513212K902 UNDERCOUNTER DISHWASHER
Kenmore 66513213K900 UNDERCOUNTER DISHWASHER
Kenmore 66513213K901 UNDERCOUNTER DISHWASHER
Kenmore 66513213K902 UNDERCOUNTER DISHWASHER
Kenmore 66513219K901 UNDERCOUNTER DISHWASHER
Kenmore 66513219K902 UNDERCOUNTER DISHWASHER
Kenmore 66513222K600 DISHWASHER
Kenmore 66513222K601 DISHWASHER
Kenmore 66513223K600 DISHWASHER
  #2 (permalink)
Old 07-25-2018, 07:11 AM
Junior Member
Default
What I need to confirm first is whether or not the wash pump should run (dry) in the last half hour to 45 minutes of the cycle? Is this normal?
The answer to this question will likely lead to me replacing the control board but I need to confirm first.
  #3 (permalink)
Old 07-25-2018, 09:27 AM
ohm ohm is offline
Senior Member
ohm is on a distinguished road
Default
No that is not normal.Sometimes the water valve can let water to come in and work ok for some fills then open up electrically and then when it is suppose fill no water.This is very common just letting you know. Tech sheet below.Part number: WPW10158389
  #4 (permalink)
Old 07-25-2018, 10:01 AM
Junior Member
Default
Thank you ohm. I will replace the water valve and see if that works. I will let you know.
  #5 (permalink)
Old 07-25-2018, 08:32 PM
Junior Member
Default
You are magic ohm: the water valve was the problem! I ran a normal cycle and it went through multiple rinse cycles until the end of the cycle and the clean LED lit. I never would have thought the solenoid on the water valve would have faulted out mid cycle like that but it makes sense that it was the problem. Thank you very, very much. If anything changes, I will let you know but you have solved my problem. Many thanks!!
  #6 (permalink)
Old 07-26-2018, 07:15 AM
ohm ohm is offline
Senior Member
Default
Yeah let me know!
  #7 (permalink)
Old 07-26-2018, 02:21 PM
Junior Member
Default
This thread should be STICKY'd IMHO as I couldn't find any answers on the internet regarding the pump spinning at the end of the cycle.
  #8 (permalink)
Old 08-01-2018, 04:21 PM
Junior Member
Default
It has been a week and my dishwasher is running better than ever! Thank you again ohm!
  #9 (permalink)
Old 08-01-2018, 08:37 PM
ohm ohm is offline
Senior Member
Default
Glad to help!
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Elite Ultra Wash Dishwasher donderlinde Dishwasher Repair 0 03-14-2016 07:10 AM
Kenmore Elite Dishwasher not completing wash cycle MegF Dishwasher Repair 0 01-18-2016 10:44 AM
dishwasher wash pump will not pump streetguy Dishwasher Repair 1 01-19-2011 08:13 AM
Kenmore Elite made by Bosch dishwasher won't cycle to wash jdfish2 Dishwasher Repair 0 10-16-2010 07:51 AM
Kenmore elite ultra wash dishwasher not circulating mjasinski Dishwasher Repair 1 11-11-2008 04:21 AM
