Discuss
What's the Connection: Inlet Hum & Overflow?
 in
Dishwasher Repair
Beginning: Short humming noise began in first wash, in last cycle humming became continuous. Draining did occur, but was inadequate
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » What's the Connection: Inlet Hum & Overflow?
  #1 (permalink)
Old 06-16-2018, 05:03 PM
Junior Member
mikenh is on a distinguished road
Default What's the Connection: Inlet Hum & Overflow?
Brand: Bosch   Age: More than 10 years
Beginning: Short humming noise began in first wash, in last cycle humming became continuous. Draining did occur, but was inadequate causing overflow by end of last cycle.
First intervention: Clean out fine and large filters. Some junk but not heavy obstruction. Opened pump to inspect impeller and backwash preventer - almost nothing found.
Test rinse cycle: Humming happens when water enters even with power off. Seems to drain normally and fully with no unusual noise - even with water off. Did not do a full two cycle to test for overflow.
Question: How is the inlet humming connected to the overflow event? Would an internal obstruction somehow cause both? Thanks for any and all guesses.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replacing water inlet valve-electrical connection cidegroot Refrigerator & Freezer Repair 0 08-01-2011 12:38 AM
overflow at the plastic water inlet hsg. 356speedster Dishwasher Repair 0 07-13-2010 09:51 AM
Water Inlet Valve wiring connection Paul522 Refrigerator & Freezer Repair 0 06-08-2010 05:27 PM
Water inlet overflow Steve A Dishwasher Repair 0 10-15-2009 02:41 PM
Water Inlet Manifold Supply Vent Overflow srpayne Dishwasher Repair 2 08-25-2009 02:22 PM
