Discuss
Whirlpool DU1055XTSS2 stuck in cycle
 in
Dishwasher Repair
The panel has no lights but pressing the cancel/drain button drains the dishwasher and eventually the pump stops running. Pressing
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Whirlpool DU1055XTSS2 stuck in cycle
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-19-2018, 03:00 PM
Junior Member
ridiculouslyfrustrated is on a distinguished road
Default Whirlpool DU1055XTSS2 stuck in cycle
Brand: Whirlpool   Age: 1 - 5 years
  1. The panel has no lights but pressing the cancel/drain button drains the dishwasher and eventually the pump stops running.
  2. Pressing start goes right in to a cycle with the Pots/Pans, Drying, Hi-Temp Rinse lights lit. Leaving it running will result in the cancel light and 4/6 delay lights coming on.
  3. Canceling drains but never resets the unit and it goes right back to starting mid-way through a pots/pans cycle.
Powered off for minutes without change.
Left it running through a complete cycle as according to a different site the unit can get "confused" when it's lost power and has to complete the cycle even if it takes 3-4 hours. It ran for 4 hours and ended with just the Clean light lit but panel did not respond, pressing cancel drained and put us back to starting mid-way through a pots/pans cycle.
Assume it's not something inexpensive like a thermal fuse but thought I'd ask if anyone had seen these symptoms before buying a new control board.
  #2 (permalink)
Old 06-29-2018, 08:55 PM
Junior Member
Default
Ordered a new control panel and that resolved the problems, dishwasher ran through a complete cycle without error.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Stuck on 44 min, won't complete cycle fokker457 Dishwasher Repair 0 03-08-2013 10:26 PM
Whirlpool Gold stuck in wash cycle ari_c Washer Repair 0 01-10-2011 09:27 AM
Whirlpool stuck in rinse cycle vegemom Dishwasher Repair 7 12-03-2010 03:42 PM
whirlpool dishwasher stuck in last cycle nholt1236 Dishwasher Repair 0 10-16-2010 03:41 PM
Whirlpool Dishwasher Stuck in Cycle rgou812 Dishwasher Repair 5 04-23-2008 06:50 PM
