Discuss
GE electric dryer runs, heats, won't shut off
 in
Dishwasher Repair
My dryer continues to run. The buzzer does not go off, and the dryer will run until I open the
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » GE electric dryer runs, heats, won't shut off
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 02-22-2008, 06:10 PM
carpenter carpenter is offline
Junior Member
carpenter is on a distinguished road
Default GE electric dryer runs, heats, won't shut off
Model Number: DBB3300EA1WW   Brand: GE   Age: 5 - 10 years
My dryer continues to run. The buzzer does not go off, and the dryer will run until I open the door (for hours if I let it). Any suggestions will be greatly appreciated.
Thanx
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-22-2008, 06:43 PM
roycreamer roycreamer is offline
Expert
APP Volunteer
roycreamer is on a distinguished road
Default
if it won't shut off on auto dry, try timed dry. if it still won't shut off, it's most likely the timer...
roy
  #3 (permalink)
Old 04-29-2008, 09:32 AM
mikedudl mikedudl is offline
Junior Member
mikedudl is on a distinguished road
Default
Quote:
Thanx
I replaced the short travel button assembly where you set the heat range and fabric types to cure the same problem on our GE profile dryer. Opening the door was the only way to stop the dryer before I replaced the button assy.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gas Dryer runs, no heat, wont shut off. shabner Dryer Repair 1 12-18-2007 05:03 AM
gas-electric runs but not heat martucha Dryer Repair 3 11-14-2007 09:31 PM
Dryer heats sometimes TommyC Dryer Repair 1 10-27-2007 12:44 PM
Frigidaire Electric stove/cooktop's element will not shut off Morris Oven Repair (including Ranges and Cooktops) 2 10-14-2007 09:24 PM
electric dryer has no heat, but still runs in both permanent press and timed dry. chrisnross Dryer Repair 1 09-12-2007 05:51 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
