Canadianice
#1 Posted : Thursday, April 12, 2018 8:18:35 AM(UTC)
Canadianice
Hi all I’ve got a Bosch 800 Plus series thats giving me an E-15 error every 5 or so cycles and I’ve been trying to track down the source of the leak for a while.
I’ve viewed it during operation a number of times and can’t see a drip of water from anywhere, but it seems that every so many cycles there’s a leak that trips the float and the E-15 error.
An older post with a similar issue suggested the drain hose, and I replaced the one of the hoses and inspected the other neither had any visible holes or cracks, and neither seem to leak under water or air pressure.
I’ve considered the water softener tank but it seems to hold water, and I see no evidence of water running down the sump area into the base, it could be the connection for the recirculating pump or heater which I think are the most likely culprits.
Anyone have a similar experience? I got my hands on an endoscope so I’m going to observe it running with the camera today and hope I can find the source.
Any help or ideas would be greatly appreciated!!! Thanks.
Jerry / APP Team
#2 Posted : Friday, April 13, 2018 10:16:15 AM(UTC)
mattt
Groups:
Hello Canadianice,
This is commonly caused by the water valve Part number: AP5691117
not opening fully. The design of the water inlet actually has a small pinhole made in it by the manufacturer that causes a dribble of water to leak into the base if the water does not come in at full force. Changing the water valve and clearing the water from the base will normally take care of this issue.
