Discuss
KitchenAid Dishwasher overfills with water
 in
Dishwasher Repair
I was hoping someone could provide some advice on a KitchenAid dishwasher that seems to be overfilling during the main
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » KitchenAid Dishwasher overfills with water
  #1 (permalink)
Old 03-27-2018, 03:05 PM
Junior Member
cesser is on a distinguished road
Default KitchenAid Dishwasher overfills with water
Model Number: KUDS35FXSS5   Brand: Kitchen Aid   Age: 1 - 5 years
I was hoping someone could provide some advice on a KitchenAid dishwasher that seems to be overfilling during the main wash cycle. This doesn't always occur, but seems to happen about 20% of the time. Here are things I have tried:
- Reduced detergent and eliminated jet dry. Suds are low to non-existent, but problem still occurs.
- Cleaned with effresh (although it uses softened water and there are no deposits in dishwasher)
- Removed and cleaned filter, sump, chopper assembly, feed tube, wash arms, etc.
- Removed and cleaned float. Tested overfill switch, and it appeared to work. My DMM confirms that there is continuity and switch functionality at control panel.
- Unplugged/plugged dishwasher during fill (appx 10 times), and the water inlet switch appears to immediately shut off
- Reduced pressure from supply line by partially closing valve
- The dishwasher drains completely at the end of the cycle, and no water is visible in the sump prior to starting the dishwasher.
When overfilling does occur, the float is high and water splashes out the front of the dishwasher pan, into the door insulation, dripping from there to the floor. I can confirm that water splashes out the front (and doesn't leak from elsewhere) by removing the outer door panel.
What is the typical water level for this dishwasher?
Should it continue to add water until the overfill switch is activated, because this seems rather high? During fill, I can hear that this is the case - it will fill, pause, spray and continue to fill, pause, and repeat this pattern until I hear the fill valve stagger. At this point, I can see the overfill switch clicking on and off as well.
Could the control panel be faulty? Other than occasionally overfilling, everything seems to be operating correctly. Is there a way to perform a diagnostic on the control panel?
Thanks for your help!
- Chris
Related Models
KitchenAid KUDS35FXWH0 UNDERCOUNTER DISHWASHER
KitchenAid KUDS35FXWH1 UNDERCOUNTER DISHWASHER
KitchenAid KUDS35FXWH2 UNDERCOUNTER DISHWASHER
KitchenAid KUDS35FXWH3 UNDERCOUNTER DISHWASHER
KitchenAid KUDS35FXWH4 UNDERCOUNTER DISHWASHER
Whirlpool KUDS40CVBL0 UNDERCOUNTER DISHWASHER
Whirlpool KUDS40CVBL1 UNDERCOUNTER DISHWASHER
Whirlpool KUDS40CVBL2 UNDERCOUNTER DISHWASHER
Whirlpool KUDS40CVBL3 UNDERCOUNTER DISHWASHER
Whirlpool KUDS40CVBL4 UNDERCOUNTER DISHWASHER
Whirlpool KUDS40CVSS0 UNDERCOUNTER DISHWASHER
Whirlpool KUDS40CVSS1 UNDERCOUNTER DISHWASHER
Whirlpool KUDS40CVSS2 UNDERCOUNTER DISHWASHER
Whirlpool KUDS40CVSS3 UNDERCOUNTER DISHWASHER
Whirlpool KUDS40CVSS4 UNDERCOUNTER DISHWASHER
Whirlpool KUDS40CVWH0 UNDERCOUNTER DISHWASHER
Whirlpool KUDS40CVWH1 UNDERCOUNTER DISHWASHER
Whirlpool KUDS40CVWH2 UNDERCOUNTER DISHWASHER
Whirlpool KUDS40CVWH3 UNDERCOUNTER DISHWASHER
Whirlpool KUDS40CVWH4 UNDERCOUNTER DISHWASHER
Whirlpool KUDS40FVBL0 UNDERCOUNTER DISHWASHER
Whirlpool KUDS40FVBL2 UNDERCOUNTER DISHWASHER
Whirlpool KUDS40FVBL3 UNDERCOUNTER DISHWASHER
Whirlpool KUDS40FVBL4 UNDERCOUNTER DISHWASHER
KitchenAid KUDS40FVBL5 UNDERCOUNTER DISHWASHER
Whirlpool KUDS40FVBT0 UNDERCOUNTER DISHWASHER
Whirlpool KUDS40FVBT2 UNDERCOUNTER DISHWASHER
Whirlpool KUDS40FVBT3 UNDERCOUNTER DISHWASHER
Whirlpool KUDS40FVBT4 UNDERCOUNTER DISHWASHER
KitchenAid KUDS40FVBT5 UNDERCOUNTER DISHWASHER
Whirlpool KUDS40FVPA2 UNDERCOUNTER DISHWASHER
Whirlpool KUDS40FVPA3 UNDERCOUNTER DISHWASHER
KitchenAid KUDS40FVPA5 UNDERCOUNTER DISHWASHER
Whirlpool KUDS40FVSS0 UNDERCOUNTER DISHWASHER
Whirlpool KUDS40FVSS2 UNDERCOUNTER DISHWASHER
Whirlpool KUDS40FVSS3 UNDERCOUNTER DISHWASHER
Whirlpool KUDS40FVSS4 UNDERCOUNTER DISHWASHER
KitchenAid KUDS40FVSS5 UNDERCOUNTER DISHWASHER
Whirlpool KUDS40FVWH0 UNDERCOUNTER DISHWASHER
Whirlpool KUDS40FVWH2 UNDERCOUNTER DISHWASHER
Whirlpool KUDS40FVWH3 UNDERCOUNTER DISHWASHER
Whirlpool KUDS40FVWH4 UNDERCOUNTER DISHWASHER
KitchenAid KUDS40FVWH5 UNDERCOUNTER DISHWASHER
Whirlpool KUDS50FVBL0 UNDERCOUNTER DISHWASHER
Whirlpool KUDS50FVBL2 UNDERCOUNTER DISHWASHER
Whirlpool KUDS50FVBL3 UNDERCOUNTER DISHWASHER
Whirlpool KUDS50FVBL4 UNDERCOUNTER DISHWASHER
Whirlpool KUDS50FVPA0 UNDERCOUNTER DISHWASHER
Whirlpool KUDS50FVPA2 UNDERCOUNTER DISHWASHER
Whirlpool KUDS50FVPA3 UNDERCOUNTER DISHWASHER
Whirlpool KUDS50FVPA4 UNDERCOUNTER DISHWASHER
KitchenAid KUDS50FVPA5 UNDERCOUNTER DISHWASHER
Whirlpool KUDS50FVSS0 UNDERCOUNTER DISHWASHER
Whirlpool KUDS50FVSS2 UNDERCOUNTER DISHWASHER
Whirlpool KUDS50FVSS3 UNDERCOUNTER DISHWASHER
Whirlpool KUDS50FVSS4 UNDERCOUNTER DISHWASHER
Whirlpool KUDS50FVWH0 UNDERCOUNTER DISHWASHER
Whirlpool KUDS50FVWH2 UNDERCOUNTER DISHWASHER
Whirlpool KUDS50FVWH3 UNDERCOUNTER DISHWASHER
Whirlpool KUDS50FVWH4 UNDERCOUNTER DISHWASHER
Whirlpool KUDS50SVBL0 UNDERCOUNTER DISHWASHER
Whirlpool KUDS50SVBL2 UNDERCOUNTER DISHWASHER
Whirlpool KUDS50SVBL3 UNDERCOUNTER DISHWASHER
Whirlpool KUDS50SVBL4 UNDERCOUNTER DISHWASHER
Whirlpool KUDS50SVSS0 UNDERCOUNTER DISHWASHER
Whirlpool KUDS50SVSS2 UNDERCOUNTER DISHWASHER
Whirlpool KUDS50SVSS3 UNDERCOUNTER DISHWASHER
Whirlpool KUDS50SVSS4 UNDERCOUNTER DISHWASHER
Whirlpool KUDS50SVWH0 UNDERCOUNTER DISHWASHER
Whirlpool KUDS50SVWH2 UNDERCOUNTER DISHWASHER
Whirlpool KUDS50SVWH3 UNDERCOUNTER DISHWASHER
Whirlpool KUDS50SVWH4 UNDERCOUNTER DISHWASHER
Whirlpool KUDT03FTBL0 UNDERCOUNTER DISHWASHER
Whirlpool KUDT03FTBL1 UNDERCOUNTER DISHWASHER
Whirlpool KUDT03FTBL2 UNDERCOUNTER DISHWASHER
Whirlpool KUDT03FTBL3 UNDERCOUNTER DISHWASHER
Whirlpool KUDT03FTPA0 UNDERCOUNTER DISHWASHER
Whirlpool KUDT03FTPA1 UNDERCOUNTER DISHWASHER
Whirlpool KUDT03FTPA2 UNDERCOUNTER DISHWASHER
Whirlpool KUDT03FTPA3 UNDERCOUNTER DISHWASHER
Whirlpool KUDT03FTSS0 UNDERCOUNTER DISHWASHER
Whirlpool KUDT03FTSS1 UNDERCOUNTER DISHWASHER
Whirlpool KUDT03FTSS2 UNDERCOUNTER DISHWASHER
Whirlpool KUDT03FTSS3 UNDERCOUNTER DISHWASHER
Whirlpool KUDT03FTWH0 UNDERCOUNTER DISHWASHER
Whirlpool KUDT03FTWH1 UNDERCOUNTER DISHWASHER
Whirlpool KUDT03FTWH2 UNDERCOUNTER DISHWASHER
Whirlpool KUDT03FTWH3 UNDERCOUNTER DISHWASHER
Whirlpool KUDT03STBL0 UNDERCOUNTER DISHWASHER
Whirlpool KUDT03STBL1 UNDERCOUNTER DISHWASHER
Whirlpool KUDT03STBL2 UNDERCOUNTER DISHWASHER
Whirlpool KUDT03STBL3 UNDERCOUNTER DISHWASHER
Whirlpool KUDT03STSS0 UNDERCOUNTER DISHWASHER
Whirlpool KUDT03STSS1 UNDERCOUNTER DISHWASHER
Whirlpool KUDT03STSS2 UNDERCOUNTER DISHWASHER
Whirlpool KUDT03STSS3 UNDERCOUNTER DISHWASHER
Whirlpool KUDT03STWH0 UNDERCOUNTER DISHWASHER
Whirlpool KUDT03STWH1 UNDERCOUNTER DISHWASHER
Whirlpool KUDT03STWH2 UNDERCOUNTER DISHWASHER
Whirlpool KUDT03STWH3 UNDERCOUNTER DISHWASHER
KitchenAid KUDT23HY3 DISHWASHER
Whirlpool KUDU02FRBL0 UNDERCOUNTER DISHWASHER
Whirlpool KUDU02FRBL1 UNDERCOUNTER DISHWASHER
Whirlpool KUDU02FRBL2 UNDERCOUNTER DISHWASHER
Whirlpool KUDU02FRBL3 UNDERCOUNTER DISHWASHER
Whirlpool KUDU02FRBL4 UNDERCOUNTER DISHWASHER
Whirlpool KUDU02FRSS0 UNDERCOUNTER DISHWASHER
Whirlpool KUDU02FRSS1 UNDERCOUNTER DISHWASHER
Whirlpool KUDU02FRSS2 UNDERCOUNTER DISHWASHER
Whirlpool KUDU02FRSS3 UNDERCOUNTER DISHWASHER
Whirlpool KUDU02FRSS4 UNDERCOUNTER DISHWASHER
Whirlpool KUDU02FRWH0 UNDERCOUNTER DISHWASHER
Whirlpool KUDU02FRWH1 UNDERCOUNTER DISHWASHER
Whirlpool KUDU02FRWH2 UNDERCOUNTER DISHWASHER
Whirlpool KUDU02FRWH3 UNDERCOUNTER DISHWASHER
Whirlpool KUDU02FRWH4 UNDERCOUNTER DISHWASHER
Whirlpool KUDU02VRMT0 UNDERCOUNTER DISHWASHER
Whirlpool KUDU02VRMT1 UNDERCOUNTER DISHWASHER
Whirlpool KUDU02VRPA0 UNDERCOUNTER DISHWASHER
Whirlpool KUDU02VRSS0 UNDERCOUNTER DISHWASHER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ice maker overfills with water sparky123 Refrigerator & Freezer Repair 0 09-14-2013 09:00 PM
ice tray overfills with water ko422 Refrigerator & Freezer Repair 0 02-24-2012 10:17 AM
Dishwasher overfills occasionally jerry80234 Dishwasher Repair 2 03-13-2011 01:56 PM
Washer overfills with hot water jwallack Washer Repair 1 07-23-2009 04:03 PM
Dishwasher overfills mechanicmee Dishwasher Repair 0 06-13-2009 10:31 AM
