My dishwasher is only about 2 yrs old. About 2 days ago I noticed it making some very loud grinding type noises for a few seconds and then it would stop for several minutes and then start the noises again. This happened several times. The dishes on the top rack were not clean after that load stopped ... the bottom looked ok.
Yesterday I tried to start it again and it finally stopped making that grinding sound but then just started doing a low hum and then a click ... like it just couldn't get started.
Last night I flipped the power switch (light switch) and then turned it back on and the clicking noise stopped but it still isn't working right. Soap is not getting washed away -- and it smells like something is burning slightly -- but not a real strong smell.
When I put it on rinse only it seems to be making the normal usual sounds ... but not on the wash cycle.
I have no idea what the problem could be. Any ideas?
