Discuss
Dishwasher fills and drains but won't run
 in
Dishwasher Repair
So brief backstory: I had a partially clogged kitchen drain, which took a significant amount of snaking/plunging/boiling water to clear.
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher fills and drains but won't run
  #1 (permalink)
Old 03-05-2018, 02:29 PM
Junior Member
LiquidPony is on a distinguished road
Default Dishwasher fills and drains but won't run
Model Number: WDF520PADM3   Brand: Whirlpool   Age: 1 - 5 years
So brief backstory: I had a partially clogged kitchen drain, which took a significant amount of snaking/plunging/boiling water to clear. But it is now cleared and draining quickly. The slow drain was discovered because my dishwasher stopped working. Just running the faucet did not produce enough water volume to back up the drain, but when the dishwasher pumped out its water it backed up into the sink.
My dishwasher (Whirlpool WDF520PADM3) still won't run. Behavior is: it fills up with water, it drains (presumably to test the drain speed?), then it fills again, then it just sits there.
From the diagnostic mode, it reports the following error codes: 6-4 (float valve open) and 8-1 (drain too slow). However, the float valve moves freely and appears to be working (when I pull it up manually, I can hear the relay switch click), and when the dishwasher drains (e.g., if I fill it and then manually enter drain mode), it drains freely without backing up.
I have tried "resetting" the dishwasher (it is hard-wired, so I turned it off at the breaker for a few minutes and then turned it back on), to no avail. If I start it up, the behavior is the same.
At my wits end here. Any help or additional troubleshooting steps would be greatly appreciated. It's almost like it's stuck in some error mode from when the drain was clogged and I can't get it to reset.
Thanks!
* Quick update ... so I "reset" it again, and when I start it up (in 1-hour wash mode because the damn thing takes like 4 hours to run through a normal cycle), it fills and then makes a noise that I would describe as bullfrog-esque (the pattern is duh duhduh). I can hear the clicks that I assume are the dishwasher attempting to switch cycles and then it just makes that bullfrog noise repeatedly. I turned it on, let it be, and come back 2 hours later and it's just sitting there full of steaming hot water baking food onto my dishes for the 13th time.
Related Models
Whirlpool WDF530PAYB0 UNDERCOUNTER DISHWASHER
Whirlpool WDF530PAYB1 UNDERCOUNTER DISHWASHER
Whirlpool WDF530PAYM0 UNDERCOUNTER DISHWASHER
Whirlpool WDF530PAYM1 UNDERCOUNTER DISHWASHER
Whirlpool WDF530PAYT0 UNDERCOUNTER DISHWASHER
Whirlpool WDF530PAYT1 UNDERCOUNTER DISHWASHER
Whirlpool WDF530PAYW0 UNDERCOUNTER DISHWASHER
Whirlpool WDF530PAYW1 UNDERCOUNTER DISHWASHER
Whirlpool WDF530PLYB0 UNDERCOUNTER DISHWASHER
Whirlpool WDF530PLYM0 UNDERCOUNTER DISHWASHER
Whirlpool WDF530PLYW0 UNDERCOUNTER DISHWASHER
Whirlpool WDF530PSYB0 UNDERCOUNTER DISHWASHER
Whirlpool WDF530PSYM0 UNDERCOUNTER DISHWASHER
Whirlpool WDF530PSYW0 UNDERCOUNTER DISHWASHER
Whirlpool WDF730PAYB0 UNDERCOUNTER DISHWASHER
Whirlpool WDF730PAYM0 UNDERCOUNTER DISHWASHER
Whirlpool WDF730PAYT0 UNDERCOUNTER DISHWASHER
Whirlpool WDF730PAYW0 UNDERCOUNTER DISHWASHER
Whirlpool WDF750SAYB0 UNDERCOUNTER DISHWASHER
Whirlpool WDF750SAYM0 UNDERCOUNTER DISHWASHER
Whirlpool WDF750SAYW0 UNDERCOUNTER DISHWASHER
Whirlpool WDF780SLYB0 UNDERCOUNTER DISHWASHER
Whirlpool WDF780SLYM0 UNDERCOUNTER DISHWASHER
Whirlpool WDF780SLYW0 UNDERCOUNTER DISHWASHER
Frigidaire WDG216RBD0 Wwh(v4) / 27 " Gas Dryer
Frigidaire WDG216RBD1 Wwh(v1) / 27 " Gas Dryer
Frigidaire WDG216RBD2 Wwh(v1) / Gas Dryer
Frigidaire WDG216RBW0 Wwh(v3) / 27 " Gas Dryer
Frigidaire WDG216RBW1 Wwh(v2) / 27 " Gas Dryer
Frigidaire WDG216RBW2 Wwh(v2) / Gas Dryer
Frigidaire WDG336RBD0 Wwh(v2) / 27 " Gas Dryer
Frigidaire WDG336RBD1 Wwh(v3) / 27 " Gas Dryer
Frigidaire WDG336RBD2 Wwh(v1) / Gas Dryer
Frigidaire WDG336RBS1 Wwh(v4) / 27 " Gas Dryer
Frigidaire WDG336RBSD0 Wwh(v2) / 27 " Gas Dryer
Frigidaire WDG336RBSW0 Wwh(v1) / 27 " Gas Dryer
Frigidaire WDG336RBW0 Wwh(v1) / 27 " Gas Dryer
Frigidaire WDG336RBW1 Wwh(v5) / 27 " Gas Dryer
Frigidaire WDG336RBW2 Wwh(v2) / Gas Dryer
Frigidaire WDG336RED0 Wwh(v1) / Free Standing Dryer
Frigidaire WDG336RES1 Wwh(v0) / Dryer
Frigidaire WDG336REW0 Wwh(v2) / Free Standing Dryer
Frigidaire WDG436RBD0 Wwh(v2) / 27 " Gas Dryer
Frigidaire WDG436RBD1 Wwh(v6) / 27 " Gas Dryer
Frigidaire WDG436RBD2 Wwh(v1) / Gas Dryer
Frigidaire WDG436RBW0 Wwh(v1) / 27 " Gas Dryer
Frigidaire WDG436RBW1 Wwh(v7) / 27 " Gas Dryer
Frigidaire WDG436RBW2 Wwh(v2) / Gas Dryer
Frigidaire WDG446JBS1 Wwh(v1) / 27 " Gas Dryer
Frigidaire WDG546RBD0 Wwh(v2) / 27 " Gas Dryer
Frigidaire WDG546RBD1 Wwh(v1) / 27 " Gas Dryer
Frigidaire WDG546RBD2 Wwh(v3) / Gas Dryer
Frigidaire WDG546RBS0 Wwh(v0) / Gas Dryer
Frigidaire WDG546RBS1 Wwh(v4) / Gas Dryer
Frigidaire WDG546RBW0 Wwh(v1) / 27 " Gas Dryer
Frigidaire WDG546RBW1 Wwh(v2) / 27 " Gas Dryer
Frigidaire WDG546RBW2 Wwh(v5) / Gas Dryer
Frigidaire WDG546RET0 RESIDENTIAL DRYER
Frigidaire WDG546RFS0 Wwh(v0) / Dryer
Frigidaire WDG546RFS1 Wwh(v0) / Dryer
Frigidaire WDG546RGS0 Wwh(v0) / Free Standing Dryer
Frigidaire WDG546RGS1 Wwh(v0) / Dryer
Frigidaire WDG547PBS0 Wwh(v1) / 27 " Gas Dryer
Frigidaire WDG547PBS1 Wwh(v0) / 27 " Gas Dryer
Frigidaire WDG646RBSD0 Wwh(v2) / 27 " Gas Dryer
Frigidaire WDG646RBSW0 Wwh(v1) / 27 " Gas Dryer
Frigidaire WDG846RBD0 Wwh(v2) / 27 " Gas Dryer
Frigidaire WDG846RBW0 Wwh(v1) / 27 " Gas Dryer
Frigidaire WDH2 Frg(v3) / Top Load Washer
Frigidaire WDLH1 Frg(v3) / 27 " Washer
Frigidaire WDLL0 Frg(v2) / 27 " Washer
Frigidaire WDLL1 Frg(v2) / 27 " Washer
Frigidaire WDLW0 Frg(v1) / 27 " Washer
Frigidaire WDLW1 Frg(v1) / 27 " Washer
Frigidaire WDMA1 Frg(v11) / Washer
Frigidaire WDMF1 Frg(v12) / Washer
Frigidaire WDMH1 Frg(v13) / Washer
Frigidaire WDML1 Frg(v14) / Washer
Frigidaire WDML2 Frg(v13) / Washer
Frigidaire WDMW1 Frg(v15) / Washer
Frigidaire WDMW2 Frg(v14) / Washer
 WDP1W Washer
 WDP1W Washer
 WDP2B Washer
 WDP2W Washer
 WDP3B Washer
 WDP3G Washer
 WDP3G Washer
 WDP3N Washer
 WDP3R Washer
 WDP3S Washer
 WDP3T Washer
 WDP3U Washer
 WDP3W Washer
Frigidaire WDP632GER0 Wwh(v0) / Dishwasher
Whirlpool WDP68805
General Electric WDRR2500K0WW WASHER
General Electric WDRR2500K1WW WASHER
General Electric WDRR2500K2WW WASHER
General Electric WDRR2500K3WW WASHER
General Electric WDRR2500K4WW WASHER
Frigidaire WDSCL2 Frg(v1) / Washer
Frigidaire WDSCL3 Frg(v1) / Washer
Frigidaire WDSCL5 Frg(v1) / Top Loading Washer
Frigidaire WDSCL6 Frg(v2) / Top Load Washer
Frigidaire WDSCLL0 Frg(v4) / 27 " Washer
Frigidaire WDSCLL1 Frg(v5) / 27 " Washer
Frigidaire WDSCLL2 Frg(v2) / 27 " Washer
Frigidaire WDSCLW0 Frg(v3) / 27 " Washer
Frigidaire WDSCLW1 Frg(v4) / 27 " Washer
Frigidaire WDSCLW2 Frg(v1) / 27 " Washer
Frigidaire WDSCW2 Frg(v2) / Washer
Frigidaire WDSCW3 Frg(v2) / Washer
Frigidaire WDSCW4 Frg(v0) / Washer
Frigidaire WDSCW5 Frg(v2) / Top Loading Washer
Frigidaire WDSCW6 Frg(v1) / Top Load Washer
Frigidaire WDSDL2 Frg(v15) / Top Loading Washer
Frigidaire WDSDL3 Frg(v11) / Top Load Washer
Frigidaire WDSDLL0 Frg(v8) / 27 " Washer
Frigidaire WDSDLL1 Frg(v8) / 27 " Washer
  #2 (permalink)
Old 03-05-2018, 09:29 PM
Junior Member
LeRayParateur is on a distinguished road
Default
The clicks might be the diverter motor positioning the water flow.
If there is no washing action while the unit is full of water, it might be because of a bad wash motor.
If you have long enough electrical wire and water supply hose to advande the dishwasher out of under the counter, you can start a cycle and check if you have 120V to the wash motor under the dishwasher.
If 120V AC goes there but the dishwasher doesn't wash and draw 0 Amps from the start, it's likely a bad motor. If there is a current detected when starting the cycle, but it drops to zero after a few seconds/minutes, there might be something blocking the impeller, and the motor protection system turns it off before it overheats.
Please note that most Whirlpool wash motors have a small PCB inside the motor, so it's not as simple as reading windings resistance.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Samsung Dishwasher Drains, fills & Drains Again bowdeC01 Dishwasher Repair 1 06-02-2016 12:34 PM
GE Dishwasher - Fills and Drains nothing else bdoleman Dishwasher Repair 0 12-15-2011 02:24 PM
Ge Dishwasher fills then drains mousse Dishwasher Repair 1 09-04-2011 10:31 AM
Dishwasher fills and tries to run but doesn't. Still drains formflier Dishwasher Repair 0 08-30-2011 10:09 PM
Bosch dishwasher fills, drains, fills again then stops ricsan Dishwasher Repair 1 06-05-2008 03:40 AM
