Discuss
Whirlpool Quiet Partner II will not start and drain
 in
Dishwasher Repair
Having some problems with my dishwasher that won't start a full cycle and then won't drain. This dishwasher is seldom
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Whirlpool Quiet Partner II will not start and drain
  #1 (permalink)
Old 02-18-2018, 09:43 AM
Junior Member
zotmeister is on a distinguished road
Default Whirlpool Quiet Partner II will not start and drain
Model Number: DU10555XTVS1   Brand: Whirlpool   Age: 5 - 10 years
Having some problems with my dishwasher that won't start a full cycle and then won't drain. This dishwasher is seldom used, maybe 1-2 a month.
Problem may have started 6 mo. -1 year ago where if I start a cycle, the dishwasher would run (filling with water) for about 20-30 sec and then turn it self off. I would have to push cancel/drain several times (304 times) before it would start.
Recently, the problem is worse. If I start a cycle, it will again shut itself off within 20-30 sec. Now, though, the cancel/drain function won't even work and the dishwasher will not drain, even with repeated pushing of cancel/drain function. I have also tried the diagnostic cycle of pushing repeated heat dry/normal, heat dry/normal. The dishwasher would go through a quick cycle of filling with water in the machine for 20-30 seconds (like what is described above) and then just stop with no error lights blinking to determine where the problem may lie. Pushing cancel/drain button did not drain dishwasher...I just hear a click and quick buzz sound as if the machine wants to activate the function, but can't.
I have checked:
1. blade and filter blockage - did not fix problem
2. replaced drain pump - did not fix problem
3. replaced check valve - did not fix problem
4. checked continuity of thermal fuse - it was functioning
5. All control panel lights appear to light up when pushed
Does anyone have an idea what the problem is and is it worth fixing or just getting a new dishwasher? Could it be the control circuit board and needs replacing? Don't want to spend any more money if it cost more than getting another dishwasher. Is it worth calling a repair man?
Thanks for any help or suggestions.
Related Models
Whirlpool DU1055XTPB0 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTPB3 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTPB4 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTPQ0 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTPQ3 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTPQ4 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTPS0 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTPS3 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTPS4 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTPT0 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTPT3 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTPT4 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTSB0 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTSB1 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTSB2 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTSB3 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTSD2 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTSD3 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTSQ0 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTSQ1 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTSQ2 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTSQ3 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTSS0 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTSS1 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTSS2 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTSS3 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTST0 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTST1 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTST2 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTST3 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVB0 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVB1 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVB2 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVB3 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVB5 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVB6 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVB7 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVB8 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVD0 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVD1 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVD2 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVD3 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVD5 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVD6 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVD7 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVD8 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVQ0 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVQ1 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVQ2 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVQ3 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVQ5 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVQ6 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVQ7 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVQ8 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVS0 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVS1 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVS2 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVS3 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVS5 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVS6 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVS7 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVS8 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVT0 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVT1 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVT2 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVT3 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVT5 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVT6 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVT7 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVT8 UNDERCOUNTER DISHWASHER
Whirlpool DU1061XTSB0 UNDERCOUNTER DISHWASHER
Whirlpool DU1061XTSQ0 UNDERCOUNTER DISHWASHER
Whirlpool DU1061XTST0 UNDERCOUNTER DISHWASHER
Whirlpool DU1065XTPB0 UNDERCOUNTER DISHWASHER
Whirlpool DU1065XTPB1 UNDERCOUNTER DISHWASHER
Whirlpool DU1065XTPQ0 UNDERCOUNTER DISHWASHER
Whirlpool DU1065XTPQ1 UNDERCOUNTER DISHWASHER
Whirlpool DU1065XTPS0 UNDERCOUNTER DISHWASHER
Whirlpool DU1065XTPS1 UNDERCOUNTER DISHWASHER
Whirlpool DU1098XLW0 Dishwasher
Whirlpool DU1098XLW1 Dishwasher
Whirlpool DU1098XRW0 Dishwasher
Whirlpool DU1098XRW1 Dishwasher
Whirlpool DU1099XT0 Dishwasher
Whirlpool DU1099XT1 Dishwasher
Whirlpool DU1099XT2 Dishwasher
Whirlpool DU1099XT3 Dishwasher
Whirlpool DU1100XTPB0 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPB1 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPB3 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPB6 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPB7 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPB8 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPB9 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPBA UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPBB UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPQ0 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPQ1 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPQ3 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPQ6 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPQ7 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPQ8 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPQ9 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPQA UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPQB UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPS0 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPS1 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPS3 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPS6 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPS7 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPS8 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPS9 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPSA UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPSB UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPT0 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPT1 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPT3 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPT6 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPT7 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPT8 UNDERCOUNTER DISHWASHER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Quiet Partner II does not drain JosephC Dishwasher Repair 9 03-29-2015 07:35 AM
Whirlpool quiet partner 2 won't start or drain Garrett1234567 Dishwasher Repair 2 04-26-2014 03:25 AM
Whirlpool Quiet Partner I - no drain Maxbumpo Dishwasher Repair 6 03-26-2012 06:34 PM
Whirlpool Quiet Partner 11 Will Not Drain cabezio Dishwasher Repair 1 09-27-2009 08:52 PM
Whirlpool Quiet Partner III Does Not Drain volant Dishwasher Repair 6 12-28-2007 02:17 AM
