Discuss
Bosch Dishwasher Gremlins
 in
Dishwasher Repair
Hello, I'm stumped... Initial problem started with dishwasher not filling after starting cycle, no pumps, nothing. The digital timer WOULD
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch Dishwasher Gremlins
  #1 (permalink)
Old 02-02-2018, 09:41 AM
Junior Member
waterndirt is on a distinguished road
Default Bosch Dishwasher Gremlins
Model Number: SHE3ARF2UC/07   Brand: Bosch   Age: 5 - 10 years
Hello,
I'm stumped...
Initial problem started with dishwasher not filling after starting cycle, no pumps, nothing. The digital timer WOULD count down to zero but dishwasher would do nothing for the 2 hours or so. (Each time I Power On dishwasher through each step below, I can hear relays clicking, along with the circulation / heat pump initiating and attempting to turn, a bit of a grunting sound from it, but nothing out of the ordinary. From memory, its always done that.)
1- Replaced fill valve. Everything worked fine for 2 to 3 cycles. Problem came back.
2 - Continued research and found a way to access Fault Codes and Customer service settings. Upon initial Fault Code runs, there were no codes given, each of the 8 cycles came back, E:00. Customer service program was run and it stopped after the Fill portion. Left with water at bottom of tub.
3- Continued research, attempted to start dishwasher cycle while using magnet at hall sensor at door, pulled up Float and drain pump engaged, draining tub completely.
4- Dishwasher worked again for a few cycles. Once it failed again, I ran more fault code and customer service tests. No fault codes, Customer Service test now acts strangely, locks up, all lights go on.
5- Ordered new control module and power module. After installation, dishwasher ran for a few cycles.
6 - Installed new float switch, even though current switch tested good.
7 - Dishwasher sat for a few days, I'm frustrated, more research, found out how to reset drain pump.
8- Dishwasher works again, for a few cycles. Stopped working, ordered new drain pump.
9 - Dishwasher doesn't work after installing new drain pump. Reset drain pump, dishwasher works for a few cycles. Now, Auto cycle has initial run time 1:59 hr. instead of 2:00 hr. and dishwasher ends cycle at :01 with soapy water in tub.
10- I'm tired of this.
11 - Help!
12 - (New 3/7/18 ) Installed new heat pump, nothing, same symptoms. I've now replaced every part on this machine. Checked and secured all wiring.
Again, at no point was the digital display ever reading codes, E:00 was always the result.
Ryan
Related Models
Whirlpool SHF3801W0 Dishwasher
Whirlpool SHF3804W2 Dishwasher
Whirlpool SHF4500W0 Dishwasher
Whirlpool SHF5500W0 Dishwasher
Whirlpool SHF5501W0 Dishwasher
Whirlpool SHF5504W0 Dishwasher
Whirlpool SHF5584P1 Dishwasher
Whirlpool SHF5584P2 Dishwasher
Whirlpool SHF5801W0 Dishwasher
Whirlpool SHF5801W1 Dishwasher
Whirlpool SHF5884P1 Dishwasher
Whirlpool SHF5884P2 Dishwasher
Whirlpool SHF7800W0 Dishwasher
Whirlpool SHF7801W0 Dishwasher
Whirlpool SHF7804W1 Dishwasher
Whirlpool SHF7884P0 Dishwasher
Whirlpool SHF7884P1 Dishwasher
Whirlpool SHF7884P2 Dishwasher
Bosch SHI4302 UC/06 -FD8002
Bosch SHI4302 UC/11 -FD8003
Bosch SHI4302 UC/12
Bosch SHI4306 UC/06 -FD8002
Bosch SHI4306 UC/11 -FD8003
Bosch SHI4306 UC/12
Bosch SHI66A05 UC/14 (FD 8211-)
Bosch SHI6802 UC/06
Bosch SHI6802 UC/11
Bosch SHI6802 UC/12
Bosch SHI6805 UC/06
Bosch SHI6805 UC/11
Bosch SHI6805 UC/12
Bosch SHI6806 UC/06
Bosch SHI6806 UC/11
Bosch SHI6806 UC/12
Whirlpool SHU30011 DISHWASHER
Bosch SHU3002
Whirlpool SHU30041 DISHWASHER
Bosch SHU3006
Bosch SHU3012
Whirlpool SHU30140 DISHWASHER
Whirlpool SHU30141 DISHWASHER
Bosch SHU3016
Bosch SHU3032 UC/06 (FD 7908-8002)
Bosch SHU3032 UC/11 (FD 8002-8003)
Bosch SHU3032 UC/12 (FD 8003-)
Bosch SHU3035 UC/12 (FD 8006-)
Bosch SHU3036 UC/06 (FD 7908-8002)
Bosch SHU3036 UC/11 (FD 8002-8003)
Bosch SHU3036 UC/12 (FD 8003-)
Bosch SHU3132 UC/12 (FD 8105-)
Bosch SHU3135 UC/12 (FD 8105-)
Bosch SHU3136 UC/12 (FD 8105-)
Bosch SHU3302 UC/06 (FD 7902-8003)
Bosch SHU3302 UC/11 (FD 8003-8003)
Bosch SHU3302 UC/12 (FD 8003 -)
Bosch SHU3305 UC/06 (FD 7902-8003)
Bosch SHU3305 UC/11 (FD 8003-8003)
Bosch SHU3305 UC/12 (FD 8003 -)
Bosch SHU3306 UC/06 (FD 7902-8003)
Bosch SHU3306 UC/11 (FD 8003-8003)
Bosch SHU3306 UC/12 (FD 8003 -)
Bosch SHU3307 UC/12 (FD 8005 -)
Bosch SHU3322 UC/06
Bosch SHU3322 UC/11
Bosch SHU3322 UC/12
Bosch SHU3322 UC/12 (FD 8003-)
Bosch SHU3326 UC/06
Bosch SHU3326 UC/11
Bosch SHU3326 UC/12
Bosch SHU3326 UC/12 (FD 8003-)
Bosch SHU3336 UC/06
Bosch SHU3336 UC/11
Bosch SHU3336 UC/12
Bosch SHU3336 UC/12 (FD 8003-)
Bosch SHU33A02 UC/14 (FD 8211-)
Bosch SHU33A06 UC/14 (FD 8211-)
Bosch SHU33AC02 UC/14
Bosch SHU33AC06 UC/14
Whirlpool SHU40011 DISHWASHER
Bosch SHU4002 UC/06
Whirlpool SHU40041 DISHWASHER
Bosch SHU4006 UC/06
Bosch SHU4016 UC/06
Bosch SHU4022 UC/06
Bosch SHU4026 UC/06
Bosch SHU4036 UC/06
Bosch SHU4302 UC/06 (FD 7705-7912)
Bosch SHU4302 UC/11 (FD 8001-8003)
Bosch SHU4302 UC/12 (FD 8003-)
Bosch SHU4306 UC/06 (FD 7705-7912)
Bosch SHU4306 UC/11 (FD 8001-8003)
Bosch SHU4306 UC/12 (FD 8003-)
Bosch SHU4312 UC/06 (FD 7701-7912)
Bosch SHU4312 UC/11 (FD 8001-8003)
Bosch SHU4312 UC/12 (FD 8003-)
Bosch SHU4316 UC/06
Bosch SHU4316 UC/11
Bosch SHU4316 UC/12
Bosch SHU4322 UC/12
Bosch SHU4322 UC/12 (FD 8003-)
Bosch SHU4326 UC/12
Bosch SHU4326 UC/12 (FD 8003-)
Bosch SHU43C02 UC/14 (FD 8211-)
Bosch SHU43C05 UC/14 (FD 8211-)
Bosch SHU43C06 UC/14 (FD 8211-)
Bosch SHU43C07 UC/14 (FD 8211-)
Bosch SHU43E02 UC/14 (FD 8211-)
Bosch SHU43E05 UC/14 (FD 8211-)
Bosch SHU43E06 UC/14 (FD 8211-)
Bosch SHU43E07 UC/14 (FD 8211-)
Whirlpool SHU45010 Dishwasher
Whirlpool SHU45020 Dishwasher
Whirlpool SHU50041 Dishwasher
Whirlpool SHU50043 Dishwasher
Bosch SHU5302 UC/06 (FD 7705-7912)
Bosch SHU5302 UC/11 (FD 8001-8003)
Bosch SHU5302 UC/12 (FD 8003-)
Bosch SHU5304 UC/06 (FD 7705-7912)
Bosch SHU5304 UC/11 (FD 8001-8003)
Bosch SHU5304 UC/12 (FD 8003-)
  #2 (permalink)
Old 03-11-2018, 08:23 PM
Junior Member
Default
Update: I just finished installing the last of the electrical parts, the door sensor. I've replaced every electrical part except the wire harness on this machine, both pumps, switches, sensors, power modules, controllers. I've checked and secured all plugs and their respective terminals. Obviously, I'm missing something. My wife has been a trooper though her patience is waining. I've learned to like washing dishes by hand. I should have given up two months ago, I refuse. Bosch has been utterly useless. Phone calls never get answered and they only offer to help try to reset the machine by holding the start button.
Someone please help me win the battle...
  #3 (permalink)
Old 03-13-2018, 07:39 PM
Junior Member
home appliance tech is on a distinguished road
Default
Sound's like you covered the basics, the pcb will only give error if it is sensing an error, i.e, in line heater is open, check all of your harness connections, a loose contact in the harness that makes and breaks a contact may cause the dishwasher to fail after a few uses.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
LG Dryer gremlins aritzer Dryer Repair 0 01-17-2014 03:59 PM
Wsher gremlins shelhammer4@yahoo.com Washer Repair 1 02-01-2012 01:34 PM
Gremlins In The Jenn Air stans Oven Repair (including Ranges and Cooktops) 1 12-08-2011 06:55 PM
washer inlet valve gremlins WATTSAIA Washer Repair 2 10-13-2011 04:35 PM
