dishwasher shuts down after 4 to 5 minutes running.. will push any button but nothing comes on.. red cancel light is on.. reset the breaker ( not tripped) and the console comes on. I can run the dishwasher without any heat, and it cycles okay. heating element shows some discoloration where it is clipped to a holding clip, no surface breakage or bubbles noted. is it possible the element is open ( shorted out). I have no meter to check the element.
