Discuss
Kitchen aid dishwasher, only runs when that tap has been run for 10 min.
 in
Dishwasher Repair
I have a Kitchen aid dishwasher, and the circulation pump only runs when the water entering the basin is very
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Kitchen aid dishwasher, only runs when that tap has been run for 10 min.
  #1 (permalink)
Old 01-07-2018, 04:15 PM
Junior Member
dcollins is on a distinguished road
Default Kitchen aid dishwasher, only runs when that tap has been run for 10 min.
Model Number: KDTE104DSS0   Brand: Kitchen Aid   Age: 1 - 5 years
I have a Kitchen aid dishwasher, and the circulation pump only runs when the water entering the basin is very hot, so I have to run the faucet for 5-10 minutes to purge the cold water from the line.
I've checked the the heater coil, and it reads 13 Ohms as it's supposed to. But if I start with cold water, it never seems to run, and the voltage across the coil is always zero. It's zero if I measure it either at the control board or at the coil itself. The hot line from the wall is 120 at the control board. I've replaced the thermistor and the control board and neither helped. Are there any other sensors that would tell the controller to not send voltage to the heater? Also, why would the circulation pump not run if the water isn't hot?
Thanks in advance!
Related Models
Gaggenau KE262-6__
Gaggenau KE272-6__
Gaggenau KE282-6__
Amana KE5313 WASHER-TOP LOADING
Amana KE5513 WASHER-TOP LOADING
Amana KE6533 WASHER-TOP LOADING
Whirlpool KEBC101KBL0 OVEN
Whirlpool KEBC101KBL03 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC101KBL04 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC101KBL05 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC101KBL06 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC101KSS04 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC101KSS05 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC101KSS06 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC101KWH0 OVEN
Whirlpool KEBC101KWH03 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC101KWH04 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC101KWH05 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC101KWH06 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC107HBL0 ELECTRIC OVEN
Whirlpool KEBC107HBL1 BUILT-IN ELECTRIC OVEN
Whirlpool KEBC107HBL2 BUILT-IN ELECTRIC OVEN
Whirlpool KEBC107HBL3 ELECTRIC BUILT IN OVEN
Whirlpool KEBC107HBT0 ELECTRIC OVEN
Whirlpool KEBC107HBT1 BUILT-IN ELECTRIC OVEN
Whirlpool KEBC107HBT2 BUILT-IN ELECTRIC OVEN
Whirlpool KEBC107HBT3 ELECTRIC BUILT IN OVEN
Whirlpool KEBC107HWH0 ELECTRIC OVEN
Whirlpool KEBC107HWH1 BUILT-IN ELECTRIC OVEN
Whirlpool KEBC107HWH2 BUILT-IN ELECTRIC OVEN
Whirlpool KEBC107HWH3 ELECTRIC BUILT IN OVEN
Whirlpool KEBC107KBL0 OVEN
Whirlpool KEBC107KBL03 30" BUILT-IN ELECTRIC OVEN SELF CLEAN THERMAL CONVECTION
Whirlpool KEBC107KBL04 SELF CLEAN THERMAL CONVECTION 30" BUILT-IN ELECTRIC OVEN
Whirlpool KEBC107KBL05 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC107KBL1 30" BUILT IN OVEN
Whirlpool KEBC107KBS0 OVEN
Whirlpool KEBC107KBS1 30" BUILT IN OVEN
Whirlpool KEBC107KBT0 OVEN
Whirlpool KEBC107KBT03 30" BUILT-IN ELECTRIC OVEN SELF CLEAN THERMAL CONVECTION
Whirlpool KEBC107KBT04 SELF CLEAN THERMAL CONVECTION 30" BUILT-IN ELECTRIC OVEN
Whirlpool KEBC107KBT05 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC107KBT1 30" BUILT IN OVEN
Whirlpool KEBC107KSS0 OVEN
Whirlpool KEBC107KSS03 30" BUILT-IN ELECTRIC OVEN SELF CLEAN THERMAL CONVECTION
Whirlpool KEBC107KSS04 SELF CLEAN THERMAL CONVECTION 30" BUILT-IN ELECTRIC OVEN
Whirlpool KEBC107KSS05 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC107KSS1 30" BUILT IN OVEN
Whirlpool KEBC107KWH0 OVEN
Whirlpool KEBC107KWH03 30" BUILT-IN ELECTRIC OVEN SELF CLEAN THERMAL CONVECTION
Whirlpool KEBC107KWH04 SELF CLEAN THERMAL CONVECTION 30" BUILT-IN ELECTRIC OVEN
Whirlpool KEBC107KWH05 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC107KWH1 30" BUILT IN OVEN
Whirlpool KEBC141KBL0 ELECTRIC OVEN
Whirlpool KEBC141KBL03 24" BUILT-IN ELECTRIC SINGLE OVEN SELF-CLEAN
Whirlpool KEBC141KBL05 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC141KBL1 ELECTRIC OVEN
Whirlpool KEBC141KWH0 ELECTRIC OVEN
Whirlpool KEBC141KWH03 24" BUILT-IN ELECTRIC SINGLE OVEN SELF-CLEAN
Whirlpool KEBC141KWH05 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC141KWH1 ELECTRIC OVEN
Whirlpool KEBC147KBL0 ELECTRIC OVEN
Whirlpool KEBC147KBL03 24" BUILT-IN ELECTRIC SINGLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC147KBL04 24" BUILT-IN ELECTRIC SINGLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC147KBL05 24" BUILT-IN ELECTRIC SINGLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC147KBL06 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC147KBL07 24" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC147KBL08 24" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC147KBL1 ELECTRIC OVEN
Whirlpool KEBC147KSS04 24" BUILT-IN ELECTRIC SINGLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC147KSS05 24" BUILT-IN ELECTRIC SINGLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC147KSS06 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC147KSS07 24" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC147KSS08 24" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC147KWH0 ELECTRIC OVEN
Whirlpool KEBC147KWH03 24" BUILT-IN ELECTRIC SINGLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC147KWH04 24" BUILT-IN ELECTRIC SINGLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC147KWH05 24" BUILT-IN ELECTRIC SINGLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC147KWH06 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC147KWH07 24" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC147KWH08 24" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC147KWH1 ELECTRIC OVEN
Whirlpool KEBC147VBL00 24" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC147VBL02 24" BUILT-IN ELECTRIC OVEN SELF CLEAN
KitchenAid KEBC147VBL03 24" BUILT-IN ELECTRIC OVEN
Whirlpool KEBC147VSS00 24" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC147VSS02 24" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC147VWH00 24" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC147VWH02 24" BUILT-IN ELECTRIC OVEN SELF CLEAN
KitchenAid KEBC147VWH03 24" BUILT-IN ELECTRIC OVEN
Whirlpool KEBC167MSS00 36" BUILT-IN ELECTRIC OVEN THERMAL CONVECTION
Whirlpool KEBC167MSS01 36" BUILT-IN ELECTRIC OVEN THERMAL CONVECTION
Whirlpool KEBC167MSS02 36" BUILT-IN ELECTRIC OVEN THERMAL CONVECTION
Whirlpool KEBC167MSS03 36" BUILT-IN ELECTRIC OVEN THERMAL CONVECTION
Whirlpool KEBC167MSS04 36" BUILT-IN ELECTRIC OVEN THERMAL CONVECTION
Whirlpool KEBC167VSS00 36" BUILT-IN ELECTRIC OVEN THERMAL CONVECTION
KitchenAid KEBC167VSS01 36" BUILT-IN ELECTRIC OVEN
KitchenAid KEBC167VSS02 36" BUILT-IN ELECTRIC OVEN
Whirlpool KEBC171KBL0 OVEN
Whirlpool KEBC171KBL03 27" BUILT-IN ELECTRIC SINGLE OVEN SELF-CLEAN
Whirlpool KEBC171KBL04 27" BUILT-IN ELECTRIC SINGLE OVEN SELF-CLEAN
Whirlpool KEBC171KBL05 27" BUILT-IN ELECTRIC SINGLE OVEN SELF-CLEAN
Whirlpool KEBC171KBL06 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC171KSS04 27" BUILT-IN ELECTRIC SINGLE OVEN SELF-CLEAN
Whirlpool KEBC171KSS05 27" BUILT-IN ELECTRIC SINGLE OVEN SELF-CLEAN
Whirlpool KEBC171KSS06 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC171KWH0 OVEN
Whirlpool KEBC171KWH03 27" BUILT-IN ELECTRIC SINGLE OVEN SELF-CLEAN
Whirlpool KEBC171KWH04 27" BUILT-IN ELECTRIC SINGLE OVEN SELF-CLEAN
Whirlpool KEBC171KWH05 27" BUILT-IN ELECTRIC SINGLE OVEN SELF-CLEAN
Whirlpool KEBC171KWH06 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC177BT05 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC177HBL0 BUILT-IN ELECTRIC OVEN
Whirlpool KEBC177HBL1 BUILT-IN ELECTRIC OVEN
Whirlpool KEBC177HBL3 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBC177HBT0 BUILT-IN ELECTRIC OVEN
Whirlpool KEBC177HBT1 BUILT-IN ELECTRIC OVEN
Whirlpool KEBC177HBT3 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBC177HWH0 BUILT-IN ELECTRIC OVEN
Whirlpool KEBC177HWH1 BUILT-IN ELECTRIC OVEN
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch dishwasher runs & runs John McElhiney Dishwasher Repair 0 01-21-2012 04:56 PM
Kitchen Aid Dishwasher runs and runs GNACK Dishwasher Repair 2 03-04-2011 11:24 AM
Kitchen Aid Dishwasher runs for a very long time GNACK Dishwasher Repair 0 02-13-2011 10:40 AM
Kitchen Aid Trash Compactor runs continuously cthorne Trash Compactor Repair 0 11-10-2009 12:41 PM
Kitchen Aid Dishwasher- Runs then blows Fuse dbshaw Dishwasher Repair 0 09-21-2009 10:43 AM
