Register | FAQ's | New Posts | Today's Posts | Extras |
» GE Dishwasher water level about 1/4" too high |
![]() Model Number: GSC3230F00WW Brand: GE Age: 1 - 5 years
![]() This unit is setup as portable. A small amount of water (barely dampens a small washcloth) is dripping under the dishwasher exactly under where the float assembly is located. Nothing else appears to be wet underneath or on the sides. The rear and center cages are free of debris. The center section holds a very small amount of water (below the level of the tub). I disassembled the float inside the tub and don't see anything obviously wrong. I disassembled the float switch assembly. I inspected the float rod which moves freely and seems fine. The float switch seems to (softly) click when I push the tongue up and down. If the float switch is bad, why doesn't the water continue to overflow and create a larger puddle under the dishwasher? What else would likely allow such a small leak under the inside left front area? Thanks in advance, Sup Related Models |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
![]() Possible there is a small crack in the d/w body.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
![]() Ask if she prewashes dishes using a dishwashing liquid soap. If she does then all dishes must be properly rinsed prior to load them into the dishwasher.
__________________
![]() When I looked previously several times I thought the recess on the left side of the tub was a built-in brace or something else that looked like it belonged there. But after looking closely at the attached picture, it looks like it doesn't belong and might be the source of the leak. Does this style of GE D/W have a built-in recess about the height of the lower rack?
If so, what is it for? If not, how would I seal it? Is this an air vent that is missing a cover? (Pic may be upside down?) Thank you very much! |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Washer leaks when water level high | cardogab7341 | Washer Repair | 0 | 04-13-2015 01:38 PM |
Water level too high | BobbyRII | Washer Repair | 8 | 10-31-2012 06:35 AM |
Dishwasher water level WAY too high and leaking | paulevansonline | Dishwasher Repair | 0 | 01-13-2012 06:36 PM |
Drum goes into high "speed wable" springs are secure when spinning; machine is level | Dean Sheridan | Washer Repair | 3 | 11-25-2008 06:49 AM |
water level too high | gzee | Dishwasher Repair | 0 | 08-21-2008 06:59 AM |
