Discuss
Dishwasher won't start when house is too cold
 in
Dishwasher Repair
Do dishwashers have a sensor that keeps them from starting if the unit is too cold? Never a problem with
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher won't start when house is too cold
  #1 (permalink)
Old 01-02-2018, 09:13 AM
Junior Member
manshack_one is on a distinguished road
Default Dishwasher won't start when house is too cold
Brand: -brand-   Age: 1 - 5 years
Do dishwashers have a sensor that keeps them from starting if the unit is too cold? Never a problem with it in warmer weather but anytime we get a cold snap it doesn't want to start. Running the hot water in the sink doesn't help because the water in the line that tees off doesn't get warmer that way. we have to get a portable space heater and open the door and point it directly into the unit for an hour or so before it'll let us start it.
  #2 (permalink)
Old 01-03-2018, 02:52 PM
Junior Member
Default
Apparently this has to do with a cold solder joint or something in the control panel. Left the heater pointed at the control panel instead of inside the dishwasher and in about an hour it was warm enough to start. Apparently my washing machine is suffering the same fate since I had to get the garage up higher than 50 degrees before it would also turn on.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
won't start cycle in cold/cold position jtrom Washer Repair 1 01-01-2013 07:01 AM
Dishwasher will not work after power surge to house LNZ Dishwasher Repair 0 08-21-2011 11:56 AM
Metal box to house wires underneath the dishwasher maissaking Dishwasher Repair 1 01-31-2011 04:41 PM
dishwasher tripping house breaker slvrpkr Dishwasher Repair 0 10-09-2010 12:01 PM
