Whirlpool dishwasher Dishes wet and dirty
Brand: Whirlpool Age: 1 - 5 years
I have a dishwasher that recently has stopped drying dishes well (leaves them really wet), leaves small pieces of debris (food) that I can pretty much rinse off in the sink on dishes, and doesn't regularly dissolve the tablet for washing. All of these symptoms appear to have presented at the same time.
I have done some checks and in my testing it appears to fill and drain without any problems (after cycles there is no standing water in the bottom of the dishwasher). The inside of the dishwasher is clean and generally dry (dishes are completely wet though). It is a metal interior. When running a cycle it fills just fine but when I expect the washer motor to come on it generally clicks about 2-4 times (sometimes with starting the motor for less than 5 seconds). By the 4-5 time the washer motor seems to stay on but sometimes it seems to wait for several minutes between fill and when the motor comes on.
I did find some eggshell recently inside the rotating washer arms (which I removed the arms and shook, blew and compressed water through them until that was clear).
Any suggestions will be appreciated>
Additional info. Dishwasher is about 2 years old.
Reason: additional information
