Hey All
I'm wondering if someone can help me with this...I've googled and read similar postings with no luck in fixing the issue.
I have a Frigidaire FGHD2433KF1 dishwasher that the drain pump won't stop when the cycle is done and it should be off (plus, during a wash cycle it will continue to stay on while the water is filling, thereby draining all of the water that is going into the dishwasher, but strangely, it *will* shut off part way through the washing cycle, but that does no good as there is no water in the dishwasher).
I've already tried cleaning everything out and draining the water. I had figured it was the float switch, but I took it apart and I checked the continuity and function of the float switch and it works correctly.
Any other ideas?
Thanks! :)
