Discuss
motor drains but wont wash
 in
Dishwasher Repair
DW fills and pumps out but evidently the motor is not reversing any ideas? Related ModelsWhirlpool KUD121SS1 Whirlpool&
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » motor drains but wont wash
  #1 (permalink)
Old 11-04-2009, 06:12 PM
kevin smolek kevin smolek is offline
Junior Member
kevin smolek is on a distinguished road
Default motor drains but wont wash
Model Number: kud101flbl3   Brand: Kitchen Aid   Age: 1 - 5 years
Related Models
Whirlpool KUD121SS1
Whirlpool KUDA03CTBL0 Undercounter Dishwasher
Whirlpool KUDA03CTBL1 Undercounter Dishwasher
Whirlpool KUDA03CTBL2 Undercounter Dishwasher
Whirlpool KUDA03CTBS0 Undercounter Dishwasher
Whirlpool KUDA03CTBS1 Undercounter Dishwasher
Whirlpool KUDA03CTBS2 Undercounter Dishwasher
Whirlpool KUDA03CTWH0 Undercounter Dishwasher
Whirlpool KUDA03CTWH1 Undercounter Dishwasher
Whirlpool KUDA03CTWH2 Undercounter Dishwasher
Whirlpool KUDA210S0
Whirlpool KUDA220T0
Whirlpool KUDA220T1
Whirlpool KUDA220TWH0
Whirlpool KUDA220TWH1
Whirlpool KUDA220TWH2
Whirlpool KUDA220TWH3
Whirlpool KUDA220TWH4
Whirlpool KUDA220TWH5
Whirlpool KUDA220TWH6
Whirlpool KUDA22ST0
Whirlpool KUDA22ST1
Whirlpool KUDA22ST2
Whirlpool KUDA22ST3
Whirlpool KUDA22ST4
Whirlpool KUDA22ST5
Whirlpool KUDA22SWWH0
Whirlpool KUDA22SWWH1
Whirlpool KUDA22SWWH2
Whirlpool KUDA230YAL0
Whirlpool KUDA230YAL1
Whirlpool KUDA230YAL2
Whirlpool KUDA230YWH0
Whirlpool KUDA230YWH1
Whirlpool KUDA230YWH2
Whirlpool KUDA23HB0
Whirlpool KUDA23HBWH0
Whirlpool KUDA23HYAL0
Whirlpool KUDA23HYWH0
Whirlpool KUDA23HYWH1
Whirlpool KUDA23SB0
Whirlpool KUDA23SBWH0
Whirlpool KUDA23SY0
Whirlpool KUDA23SY1
Whirlpool KUDA23SY2
Whirlpool KUDA23SYWH0
Whirlpool KUDA23SYWH1
Whirlpool KUDA23SYWH2
Whirlpool KUDA23ZY0
Whirlpool KUDA23ZY1
Whirlpool KUDA23ZYWH0
Whirlpool KUDB03CTBL0 Undercounter Dishwasher
Whirlpool KUDB03CTBL1 Undercounter Dishwasher
Whirlpool KUDB03CTBL2 Undercounter Dishwasher
Whirlpool KUDB03CTBS0 Undercounter Dishwasher
Whirlpool KUDB03CTBS1 Undercounter Dishwasher
Whirlpool KUDB03CTBS2 Undercounter Dishwasher
Whirlpool KUDB210S0
Whirlpool KUDB210S1
Whirlpool KUDB210S2
Whirlpool KUDB21S0
Whirlpool KUDB220T0
Whirlpool KUDB220T1
Whirlpool KUDB220T2
Whirlpool KUDB220T3
Whirlpool KUDB220T4
Whirlpool KUDB220T5
Whirlpool KUDB220T6
Whirlpool KUDB22HT0
Whirlpool KUDB22HT1
Whirlpool KUDB230B0
Whirlpool KUDB230Y0
Whirlpool KUDB230Y1
Whirlpool KUDB230Y2
Whirlpool KUDB23HB0
Whirlpool KUDB23HY0
Whirlpool KUDB23HY1
Whirlpool KUDB23HY2
Whirlpool KUDC01TMBL0 Undercounter Dishwasher
Whirlpool KUDC01TMBL1 Undercounter Dishwasher
Whirlpool KUDC01TMBL6 Undercounter Dishwasher
Whirlpool KUDC01TMWH1 Undercounter Dishwasher
Whirlpool KUDC01TMWH6 Undercounter Dishwasher
Whirlpool KUDC01TMWHO Undercounter Dishwasher
Whirlpool KUDC02IRBL0 Undercounter Dishwasher
Whirlpool KUDC02IRBL1 Undercounter Dishwasher
Whirlpool KUDC02IRBL2 Undercounter Dishwasher
Whirlpool KUDC02IRBL3 Undercounter Dishwasher
Whirlpool KUDC02IRBL4 Undercounter Dishwasher
Whirlpool KUDC02IRBS1 Undercounter Dishwasher
Whirlpool KUDC02IRBS2 Undercounter Dishwasher
Whirlpool KUDC02IRBS3 Undercounter Dishwasher
Whirlpool KUDC02IRBS4 Undercounter Dishwasher
Whirlpool KUDC02IRWH0 Undercounter Dishwasher
Whirlpool KUDC02IRWH1 Undercounter Dishwasher
Whirlpool KUDC02IRWH2 Undercounter Dishwasher
Whirlpool KUDC02IRWH3 Undercounter Dishwasher
Whirlpool KUDC02IRWH4 Undercounter Dishwasher
Whirlpool KUDC03FTSS0 Undercounter Dishwasher
Whirlpool KUDC03FTSS2 Undercounter Dishwasher
Whirlpool KUDC03ITBL0 Undercounter Dishwasher
Whirlpool KUDC03ITBL1 Undercounter Dishwasher
Whirlpool KUDC03ITBL2 Undercounter Dishwasher
Whirlpool KUDC03ITBS0 Undercounter Dishwasher
Whirlpool KUDC03ITBS1 Undercounter Dishwasher
Whirlpool KUDC03ITBS2 Undercounter Dishwasher
Whirlpool KUDC210S0
Whirlpool KUDC210S1
Whirlpool KUDC210S2
Whirlpool KUDC210S3
Whirlpool KUDC21CS1
Whirlpool KUDC21DS0
Whirlpool KUDC220T0
Whirlpool KUDC220T1
Whirlpool KUDC220T2
Whirlpool KUDC220T3
Whirlpool KUDC220T4
Whirlpool KUDC220T5
Whirlpool KUDC220T6
Whirlpool KUDC230B0
  #2 (permalink)
Old 11-05-2009, 03:17 AM
denman denman is offline
Senior Expert
APP Volunteer
denman will become famous soon enough
Default
I cannot find any info on your Model Number but if I look up other KUDL01 units none of them have a reversing motor.
Perhaps the following will help
https://secured.whirlpool.com/Servic...$FILE/KD01.pdf
I would check the motor windings for continuity with a meter.
If OK
I would check to see if it is getting voltage when it should.
If OK then and the motor turns by hand (not jammed) then it is toast.
If no voltage
Check that the wires have continuity back to the control board.
If OK
Then probably your control board is toast.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dishwasher will not wash, fills and drains, no wash hitchcow Dishwasher Repair 0 07-14-2009 07:41 AM
fills and drains but doesnt wash behrgood Dishwasher Repair 4 05-18-2009 06:45 AM
Dishwasher fills and then drains during wash camflightrn Dishwasher Repair 1 04-14-2009 09:29 AM
Drains during wash cycle thxyung Washer Repair 5 11-20-2008 12:44 PM
Maytag drains before wash cycle markm196 Dishwasher Repair 0 02-09-2008 10:11 AM
