Discuss
Quietpartner 3 issue
 in
Dishwasher Repair
Ok I have the common 7 blinking lights issue. Trying to figure out the actual cause. Here are some interesting
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Quietpartner 3 issue
  #1 (permalink)
Old 10-28-2017, 12:52 AM
Junior Member
Tofuti is on a distinguished road
Default Quietpartner 3 issue
Brand: Whirlpool   Age: 5 - 10 years
Here are some interesting symptoms:
If attempting to run normally it will fill and run but shut off after about 10-15 minutes.
If I wait for it to fill and then manually fill with additional water from the tap till just touching the element, same thing.
However, if I manually fill with additional boiling hot water it then runs just fine!
I replaced the inlet valve awhile back because it was not draining all the way.
No obvious damage to the element.
There is not a loop in the drain hose, but don't think one is required as the drain hose goes all the way up to the air gap.
So does it seem like I need a new control board? Or something else?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool quietpartner 3 will not start kane14109 Dishwasher Repair 0 03-16-2015 07:32 AM
Whirlpool Gold QuietPartner 3 - No Lights, No Power jtcountry Dishwasher Repair 0 05-17-2013 07:02 PM
Whirlpool QuietPartner II arup_sinha Dishwasher Repair 0 07-07-2010 09:00 AM
Whirlpool QuietPartner III Dirty Dishes czei Dishwasher Repair 1 09-30-2009 02:33 AM
wHIRLPOOL QUIETPARTNER III clean light blinking aduttle Dishwasher Repair 0 05-07-2009 09:30 AM
