| » wiring diagram |
Model Number: hda2000g00ww Brand: GE Age: 1 - 5 years
if someone has a wiring diagram? I'm having same problem with drain solenoid melting. Its getting 120v for 10 sec. Is the timer bad or is there a nother switch? Ge dishwasher hda2000g00ww. thanks
Related Models |
Replacement parts for GE HDA2000G00WW | AppliancePartsPros.com if someone has a wiring diagram? GE likes to keep this info secret so I do not have a wiring diagram. Perhaps someone else can supply it. I'm having same problem with drain solenoid melting. Its getting 120v for 10 sec. This is how it should work. The problem is the timer contacts get pitted and stick closed every once in a while overheating the solenoid Is the timer bad or is there a nother switch? As far as I know there is not another switch. I would replace both the solenoid and the timer.
__________________
| Display Modes | |
| Need wiring diagram | Arina | Washer Repair | 1 | 09-22-2009 02:53 PM |
| need wiring diagram | GSPRICE | Heating, Ventilation, and Air Conditioning (HVAC) | 1 | 08-31-2009 10:27 AM |
| wiring diagram | BFS | Dishwasher Repair | 1 | 08-10-2009 11:28 AM |
| wiring diagram | scuotto | Dryer Repair | 9 | 06-01-2009 05:14 AM |
| Wiring Diagram | trussmonkey | Dryer Repair | 1 | 04-29-2009 12:22 PM |
