Discuss
dishwasher doesn’t dry dishes
 in
Dishwasher Repair
More often than not, this is a problem with the dishwasher’s heating element. If your heating element is in working
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » dishwasher doesn’t dry dishes
  #1 (permalink)
Old 08-19-2017, 01:27 AM
Junior Member
victorgrant is on a distinguished road
Default dishwasher doesn’t dry dishes
Brand: Hotpoint   Age: Less than 1 year
More often than not, this is a problem with the dishwasher’s heating element. If your heating element is in working order, check the high-limit thermostat (a device that prevents the dishwasher from getting too hot). According to Part Select, a malfunctioning high-limit thermostat can cause the heat to shut off before your dishes are fully dry. You can usually find your high limit at the bottom of the dishwasher tub, directly behind the access panel. You can use a multimeter to check the device. Lastly, check your rinse aid dispenser to make sure it’s not empty and that it’s dispensing properly. Without rinse aid, your dishes will not dry as easily.
For more you can check
Broadcast Monitoring Video
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dishwasher Doesn’t Run victorgrant Dishwasher Repair 0 08-19-2017 01:25 AM
LG Dishwasher won't dry dishes thoos Dishwasher Repair 0 12-12-2011 07:09 PM
Dishwasher does not dry dishes mbreuhaus Dishwasher Repair 1 03-02-2010 02:30 PM
Dishwasher won't dry dishes Doris A. Evans, M.D. Dishwasher Repair 3 01-12-2010 04:47 PM
Dishwasher does not dry the dishes masterteck4gm Dishwasher Repair 6 01-14-2008 05:55 PM
