rubensd73116
#1 Posted : Monday, July 10, 2017 12:58:28 PM(UTC)
rubensd73116
I've been trying to fix my whirlpool DU920PWKQ0 which hadn't been draining. After clearing the water and not finding hose to seem clear, I looked at the drain check valve. The black rubber flap that is visible from the hose side connection was off kilter. It is totally loose. I assume it used to be affixed but I wanted to double check. I'm assuming that I need to replace it, but not sure. I'm starting to think that the water isn't staying but coming back into the dishwasher. Thoughts?
rubensd73116
#2 Posted : Monday, July 10, 2017 1:58:43 PM(UTC)
rubensd73116
After putting everything back together, I ran a rinse only. After the water was added, the motor sounded like it would come on for about 3 seconds and then shut off. I'm guessing that has probably nothing to do with drain check assembly and everything to do with the motor. Ugh!
clear silicone sealant in drain check valve (Dishwasher Repair)
by pchristenson 11/8/2009 9:56:20 AM(UTC)
Kenmore Dishwasher Drain Check Valve (Dishwasher Repair)
by gdaarob 11/20/2008 12:10:59 AM(UTC)
Kitchen Aid / Whirlpool drain check valve no longer available (Dishwasher Repair)
by KenSt 10/24/2008 11:00:07 PM(UTC)
