Discuss
Problem with Electronic Control Board?
 in
Dishwasher Repair
I am having a problem with my Dishwasher. It is a Whirlpool GU9805CGG0. I have tested the Float Switch and
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Problem with Electronic Control Board?
  #1 (permalink)
Old 11-03-2009, 07:30 PM
Stevebca Stevebca is offline
Junior Member
Stevebca is on a distinguished road
Default Problem with Electronic Control Board?
Model Number: GU9805SCGG0   Brand: Whirlpool   Age: 5 - 10 years
I have tested the Float Switch and it is OK,
I have tested all the buttons on the front panel and the are all OK.
I believe that I am having a problem with the control board which is a 8051136.
Symptoms
1. When I close the door, the dishwasher starts in Normal mode automatically. During the run time, the board turns on the China Crystal LED and it starts blinking saying that it is a stuck switch and the controls are locked.
I can cancel it, it drains but it will restart itself again and the process repeats.
2. If I try to put the controller into a diagnostic test by pushing Power Scour, Air Dry, Power Scour, Air Dry the following happens - All LED's are turned on then off. Next the dishwasher starts in NORMAL mode with Add a Dish LED turned on. I can not advance the program by pressing the Pots and Pan button, thus I believe that the program has been terminated.
I think that the CPU on the control board or the EPROM have gone bad.
Before I get a new board, I would like to get some feedback from a knowledgeable person.
Thanks in advance for any help.
Related Models
Whirlpool GU980QPDB0
Whirlpool GU980QPDQ0
Whirlpool GU980QPDZ0
Whirlpool GU980SCGB0
Whirlpool GU980SCGB1
Whirlpool GU980SCGB2
Whirlpool GU980SCGB3
Whirlpool GU980SCGQ0
Whirlpool GU980SCGQ1
Whirlpool GU980SCGQ2
Whirlpool GU980SCGQ3
Whirlpool GU980SCGS1
Whirlpool GU980SCGS2
Whirlpool GU980SCGS3
Whirlpool GU980SCGT2
Whirlpool GU980SCGT3
Whirlpool GU980SCGZ0
Whirlpool GU980SCGZ1
Whirlpool GU980SCGZ2
Maytag GV1110PRW Range - F/s Std Gas
International GV1226NXEW Freezer - Vertical
International GV1726NXEW Freezer - Vertical
Hoover GV3177WUA Range - F/s Std Gas
Hoover GV3177WUA5 Range - F/s Std Gas
Hoover GV3177WUW Range - F/s Std Gas
Hoover GV3177WUW5 Range - F/s Std Gas
Maytag GV3277XUA Range - F/s Std Gas
Maytag GV3277XUW Range - F/s Std Gas
Hoover GV3531WUA Range - F/s Std Ele
Hoover GV3531WUW Range - F/s Std Ele
Whirlpool GVW9959KL0
Whirlpool GVW9959KL1
Whirlpool GVW9959KL2
Whirlpool GVW9959KL3 Automatic Washer
Whirlpool GVW9959KQ0
Whirlpool GVW9959KQ1
Whirlpool GVW9959KQ2
Whirlpool GVW9959KQ3 Automatic Washer
Whirlpool GVW9959KT0
Whirlpool GVW9959KT1
Whirlpool GVW9959KT2
Whirlpool GVW9959KT3 Automatic Washer
Maytag GW18F1 Washer - Top Loading
Maytag GW18F1A Washer - Top Loading
Maytag GW18F1H Washer - Top Loading
Maytag GW18F1W Washer - Top Loading
Maytag GW18F2 Washer - Top Loading
Maytag GW18F2A Washer - Top Loading
Maytag GW18F2H Washer - Top Loading
Maytag GW18F2W Washer - Top Loading
Maytag GW18G1 Washer - Top Loading
Maytag GW18G100 Washer - Top Loading
Maytag GW18G124 Washer - Top Loading
Maytag GW18G125 Washer - Top Loading
Maytag GW18G1A Washer - Top Loading
Maytag GW18G1HW Washer - Top Loading
Maytag GW18G1WW Washer - Top Loading
Maytag GW20F6 Washer - Top Loading
Maytag GW20F600 Washer - Top Loading
Maytag GW20F624 Washer - Top Loading
Maytag GW20F625 Washer - Top Loading
Maytag GW20F6A Washer - Top Loading
Maytag GW20F6H Washer - Top Loading
Maytag GW20F6W Washer - Top Loading
Frigidaire GW30SPEA2 Wwh(v1) / Electric Range
Frigidaire GW30SPED1 Wwh(v2) / Electric Range
Frigidaire GW30SPEW1 Wwh(v1) / Electric Range
Frigidaire GW30SPEW2 Wwh(v2) / Electric Range
Whirlpool GW395LEGB0
Whirlpool GW395LEGB1
Whirlpool GW395LEGB3
Whirlpool GW395LEGB4
Whirlpool GW395LEGB5
Whirlpool GW395LEGB6
Whirlpool GW395LEGQ0
Whirlpool GW395LEGQ1
Whirlpool GW395LEGQ3
Whirlpool GW395LEGQ4
Whirlpool GW395LEGQ5
Whirlpool GW395LEGQ6
Whirlpool GW395LEGT3
Whirlpool GW395LEGT4
Whirlpool GW395LEGT5
Whirlpool GW395LEGT6
Whirlpool GW395LEGZ0
Whirlpool GW395LEGZ1
Whirlpool GW395LEGZ3
Whirlpool GW395LEPB00 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPB01 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPB02 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPB03 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPB04 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPB05 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ00 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ01 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ02 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ03 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ04 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ05 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS00 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS01 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS02 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS03 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS04 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS05 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPT00 30" Slide - in Gas Oven Non - Convect
Whirlpool GW395LEPT01 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPT02 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPT03 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPT04 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPT05 30" Slide - in Gas Oven Non - Conv
Maytag GWC202 Dishwasher - Convertible
Maytag GWC204 Dishwasher - Convertible
General Electric GWR03AAMABB Refrigerator
Gibson GWS1149AS0 Washer - Gibson
Gibson GWS1149AS1 Washer - Gibson
Gibson GWS1339CS0 Gibson/washer
Gibson GWS1339CS1 Gibson/washer
Gibson GWS1749AS0 Washer - Gibson
Gibson GWS1749AS1 Washer - Gibson
  #2 (permalink)
Old 11-04-2009, 04:22 AM
denman denman is offline
Senior Expert
APP Volunteer
denman will become famous soon enough
Default
I cannot find any info on the listed Model Number but by the sound of it you have the tech sheet.
I agree with you that it does look like a bad control board.
I would open it up and check the wiring harness in the door.
Also check the connectors on the control board for signs of corrosion/dirt.
Probably would not be a bad idea to clean the connectors, though this is a long shot, see below.
If all the above are OK then I would replace the control board.
Connector Cleaning
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Removing Oven Electronic Control Board Avgenackis Oven Repair (including Ranges and Cooktops) 3 03-19-2009 09:23 PM
Electronic Control Board Clicking guinness39 Refrigerator & Freezer Repair 1 12-06-2008 08:49 AM
Electronic Control Board Air Dry Option timkmora Dishwasher Repair 0 07-27-2008 09:11 PM
Help with electronic control board installation Loriabrass Dryer Repair 3 05-28-2008 03:38 PM
Replacement Electronic Control Board vbaroni Washer Repair 0 05-27-2008 12:14 PM
