Discuss
Wiring Diagram / Schematic request
 in
Dishwasher Repair
Hi folks; About two months ago the control board decided to develop a high-resistance connection at one of the big
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Wiring Diagram / Schematic request
  #1 (permalink)
Old 05-22-2017, 03:25 PM
Junior Member
tickerguy is on a distinguished road
Default Wiring Diagram / Schematic request
Model Number: 661.17052400   Brand: Kenmore   Age: More than 10 years
Hi folks;
About two months ago the control board decided to develop a high-resistance connection at one of the big spade terminals (probably for the heating element) and burned up that terminal. I was successful in jumpering it directly to the board through the now-vacant hole, and rescued the board, cleaning up and tightening all the other connectors at the same time (a couple of which were quite loose and probably headed for the same problem.)
All was well for a while and now the thermal fuse has opened. It MAY have been from the stress of the previous incident (it did NOT pop when the board tried to burn up!) but then again, it may NOT. There is no evidence of further heat damage to the wiring -- it all looks ok -- but I cannot see inside the relay covers of course since they're opaque.
I found the fuse part number and have a new one coming, but I'd REALLY like a schematic so I can check for shorts before I put the new fuse in and immediately have it blow if there IS a short somewhere. Without some sort of wiring diagram I'm shooting blind (or have to pull the entire harness apart and trace each wire, which I do not look forward to!) I rate the probability of the original failure being due to a partial short in the heating element (which I've seen in water heaters before and they tend to trash the wiring at the thermostats when it happens) as relatively low due to the discovery of other terminals that were quite loose, so I *believe* it was simple arcing, but I could be wrong on this and would like to head off the possibility. The circuit does not have a GFI on it so if there's a partial short in the element to the case I can find it with a schematic but if it's a partial short and being that the case is grounded it would not trip the breaker but *would* materially over-draw the current ratings of the wiring in the unit.
There is some sort of sensor in the top left of the unit's control panel protruding into where vapor exits during drying; it reads open (high impedance), but I don't know if that's a thermal switch (e.g. closes when hot) or whether it's a thermistor or similar. If it's a thermistor it's probably bad. It appears to be on some sort of sealed bracket with no immediately-obvious way to unlock said bracket for replacement IF it's bad. The door switches are good.
It appears that the failure occurred during a dry cycle; I had no idea it was dead until I went to load it and the control panel was blacked out.
A schematic would allow me to answer all the questions but I can't find one scraping around the Internet... thanks in advance for any help!
Related Models
Admiral 663AH-CV RANGE- S/C F/S ELE
Admiral 663WH-CV RANGE- S/C F/S ELE
Kenmore 6644098997 BUILT IN OVEN
Kenmore 6644428916 ELECTRIC OVEN, BUILT-IN
Kenmore 6644558953 ELECTRIC COOKTOP / BUILT-IN OVEN
Kenmore 6644558995 ELECTRIC COOKTOP
Kenmore 6644579391 ELECTRIC RANGE
Kenmore 66463783600 MICROWAVE
Kenmore 66475272502 FREE STANDING GAS
Kenmore 66475273502 FREE STANDING GAS
Kenmore 66475274502 FREE STANDING GAS
Kenmore 66475279502 FREE STANDING GAS
Kenmore 66495272502 FREE STANDING ELECTRIC RANGE
Kenmore 66495273502 FREE STANDING ELECTRIC RANGE
Kenmore 66495274502 FREE STANDING ELECTRIC RANGE
Kenmore 66495279502 FREE STANDING ELECTRIC RANGE
Kenmore 664KERH507YAL0 ELECTRIC RANGE
Kenmore 664KERH507YAL1 ELECTRIC RANGE
Kenmore 664KERH507YBL0 ELECTRIC RANGE
Kenmore 664KERH507YBL1 ELECTRIC RANGE
Kenmore 664KERH507YWH0 ELECTRIC RANGE
Kenmore 664KERH507YWH1 ELECTRIC RANGE
Kenmore 664KIRD801XSS3 30" &36" RETRACTABLE DOWNDRAFT
Kenmore 664KIRD861XSS3 30" &36" RETRACTABLE DOWNDRAFT
Kenmore 664RF3020XYN1 RANGE
Kenmore 664RF3020XYN2 30" ELECTRONIC FREESTANDING CONVENTIONAL OVEN
Kenmore 664RF3020XYW0 ELECTRIC RANGE
Kenmore 664RF3020XYW1 RANGE
Kenmore 664RF3020XYW2 30" ELECTRONIC FREESTANDING CONVENTIONAL OVEN
Kenmore 665110739120 DISHWASHER
Kenmore 665110739130 DISHWASHER
Kenmore 665110739140 DISHWASHER
Kenmore 665110739190 DISHWASHER
Kenmore 66513012K110 UNDERCOUNTER DISHWASHER
Kenmore 66513013K110 UNDERCOUNTER DISHWASHER
Kenmore 66513014K110 UNDERCOUNTER DISHWASHER
Kenmore 66513019K110 UNDERCOUNTER DISHWASHER
Kenmore 66513023K110 DISHWASHER
Kenmore 66513032K110 UNDERCOUNTER DISHWASHER
Kenmore 66513033K110 UNDERCOUNTER DISHWASHER
Kenmore 66513039K110 UNDERCOUNTER DISHWASHER
Kenmore 66513042K110 UNDERCOUNTER DISHWASHER
Kenmore 66513043K110 UNDERCOUNTER DISHWASHER
Kenmore 66513044K110 UNDERCOUNTER DISHWASHER
Kenmore 66513049K110 UNDERCOUNTER DISHWASHER
Kenmore 66513102K900 DISHWASHER
Kenmore 66513102K901 UNDERCOUNTER DISHWASHER
Kenmore 66513102K902 UNDERCOUNTER DISHWASHER
Kenmore 66513103K900 DISHWASHER
Kenmore 66513103K901 UNDERCOUNTER DISHWASHER
Kenmore 66513103K902 UNDERCOUNTER DISHWASHER
Kenmore 66513104K900 DISHWASHER
Kenmore 66513104K901 UNDERCOUNTER DISHWASHER
Kenmore 66513104K902 UNDERCOUNTER DISHWASHER
Kenmore 66513109K900 DISHWASHER
Kenmore 66513109K901 UNDERCOUNTER DISHWASHER
Kenmore 66513109K902 UNDERCOUNTER DISHWASHER
Kenmore 66513112K700 DISHWASHER
Kenmore 66513112K701 DISHWASHER
Kenmore 66513112K702 UNDERCOUNTER DISHWASHER
Kenmore 66513113K700 DISHWASHER
Kenmore 66513113K701 DISHWASHER
Kenmore 66513113K702 UNDERCOUNTER DISHWASHER
Kenmore 66513114K700 DISHWASHER
Kenmore 66513114K701 DISHWASHER
Kenmore 66513114K702 UNDERCOUNTER DISHWASHER
Kenmore 66513119K700 DISHWASHER
Kenmore 66513119K701 DISHWASHER
Kenmore 66513119K702 UNDERCOUNTER DISHWASHER
Kenmore 66513122K700 DISHWASHER
Kenmore 66513122K701 DISHWASHER
Kenmore 66513122K702 DISHWASHER
Kenmore 66513122K703 DISHWASHER
Kenmore 66513123K700 DISHWASHER
Kenmore 66513123K701 DISHWASHER
Kenmore 66513123K702 DISHWASHER
Kenmore 66513123K703 DISHWASHER
Kenmore 66513124K700 DISHWASHER
Kenmore 66513124K701 DISHWASHER
Kenmore 66513124K702 DISHWASHER
Kenmore 66513124K703 DISHWASHER
Kenmore 66513129K700 DISHWASHER
Kenmore 66513129K701 DISHWASHER
Kenmore 66513129K702 DISHWASHER
Kenmore 66513129K703 UNDERCOUNTER DISHWASHER
Kenmore 66513132K700 DISHWASHER
Kenmore 66513132K701 DISHWASHER
Kenmore 66513133K700 DISHWASHER
Kenmore 66513133K701 DISHWASHER
Kenmore 66513139K700 DISHWASHER
Kenmore 66513139K701 DISHWASHER
Kenmore 66513152K700 DISHWASHER
Kenmore 66513152K701 DISHWASHER
Kenmore 66513152K702 DISHWASHER
Kenmore 66513153K700 DISHWASHER
Kenmore 66513153K701 DISHWASHER
Kenmore 66513153K702 DISHWASHER
Kenmore 66513154K700 DISHWASHER
Kenmore 66513154K701 DISHWASHER
Kenmore 66513154K702 DISHWASHER
Kenmore 66513159K700 DISHWASHER
Kenmore 66513159K701 DISHWASHER
Kenmore 66513159K702 DISHWASHER
Kenmore 66513163K700 DISHWASHER
Kenmore 66513163K701 DISHWASHER
Kenmore 66513163K702 DISHWASHER
Kenmore 66513163K703 DISHWASHER
Kenmore 66513169K700 DISHWASHER
Kenmore 66513169K701 DISHWASHER
Kenmore 66513169K702 DISHWASHER
Kenmore 66513169K703 DISHWASHER
Kenmore 66513173K700 DISHWASHER
Kenmore 66513173K701 DISHWASHER
Kenmore 66513173K702 DISHWASHER
Kenmore 66513173K703 DISHWASHER
Kenmore 66513173K704 UNDERCOUNTER DISHWASHER
Kenmore 66513182K800 DISHWASHER
Kenmore 66513182K801 DISHWASHER
Kenmore 66513182K802 DISHWASHER
Kenmore 66513183K800 DISHWASHER
  #2 (permalink)
Old 05-14-2018, 04:54 PM
Junior Member
madmaxltd2 is on a distinguished road
Default scribd or your Manufacturer
Try scribd and search their database on your make or model. Also, many manufacturers will email schematics to you.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Wiring Diagram\schematic mike1712 Refrigerator & Freezer Repair 2 12-20-2016 09:17 AM
Wiring schematic diagram lilray1331 Heating, Ventilation, and Air Conditioning (HVAC) 2 09-22-2013 01:13 AM
i need a schematic wiring or diagram procool Oven Repair (including Ranges and Cooktops) 0 07-20-2012 12:24 PM
Schematic/wiring diagram gsstraha Dishwasher Repair 1 06-09-2012 01:36 PM
Wiring Schematic and Wiring Diagram Needed tabrane Refrigerator & Freezer Repair 1 11-11-2010 12:24 AM
