Discuss
Bosch Power Switch Puzzle
 in
Dishwasher Repair
*The model number on the post description is wrong, I have a SHX46L15UC/50 Hello, my Bosch dishwasher stopped powering up
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch Power Switch Puzzle
  #1 (permalink)
Old 05-02-2017, 09:01 AM
Junior Member
haukeg is on a distinguished road
Default Bosch Power Switch Puzzle
Model Number: SHX45L15UC   Brand: Bosch   Age: 5 - 10 years
Hello, my Bosch dishwasher stopped powering up when I hit the main power switch (at least the red segment display is not showing anything). I cracked it open and confirmed I have power from the main at the harness so proceeded to the power switch (part 00424410) diagnostic. Per the attached schematic troubleshooting (see attached image) I tested resistance across the pins as instructed in "No Power" Step 3. A gave me 0 ohms, however B and C did not so I assumed the part was faulty and ordered a new one which arrived yesterday.
The new part showed the same results upon resistance testing, and did not fix the issue when replaced, so now I am at a loss on what to try next (the schematic has no further solutions after the resistance test for the main switch).
If anyone can offer suggestions for next steps to diagnose my issue or has a hunch for what the problem may be, I would appreciate it! Thank you.
Not sure if my image attach worked, but you can view here:
https://www.dropbox.com/s/21tdeewm2c...%20PM.jpg?dl=0
Related Models
Bosch SHX46A02 UC/14 (FD 8211-)
Bosch SHX46A05 UC/14 (FD 8211-)
Bosch SHX46A06 UC/14 (FD 8211-)
Bosch SHX46A07 UC/14 (FD 8211-)
Bosch SHX46B02 UC/14 (FD 8211-)
Bosch SHX46B05 UC/14 (FD 8211-)
Bosch SHX46B06 UC/14 (FD 8211-)
Bosch SHX46B07 UC/14 (FD 8211-)
Bosch SHX56B02 UC/14 (FD 8211-)
Bosch SHX56B05 UC/14 (FD 8211-)
Bosch SHX56B06 UC/14 (FD 8211-)
Bosch SHX99B05 UC/14 (FD 8212-)
Bosch SHX99B06 UC/14 (FD 8212-)
Bosch SHY56A02 UC/14 (FD8301-)
Bosch SHY56A05 UC/14 (FD8301-)
Bosch SHY56A06 UC/14 (FD8301-)
Bosch SHY66C02 UC/14 (FD8301-)
Bosch SHY66C05 UC/14 (FD8301-)
Bosch SHY66C06 UC/14 (FD8301-)
Bosch SHY99A02 UC/14 (FD 8212-)
Bosch SHY99A05 UC/14 (FD 8212-)
Bosch SHY99A06 UC/14 (FD 8212-)
Amana SI19E REF - SXS/I&W
General Electric SIG140060B SIGNATURE REFRIGERATOR
General Electric SIG1480A66WH DISHWASHER
General Electric SIG1482A68BA DISHWASHER
General Electric SIG60100T0WG SIGNATURE WASHER
General Electric SIG7010ET0WG SIGNATURE ELECTRIC DRYER
General Electric SIG7010ET1WG Electric dryer
Admiral SILVER22 REF - SXS/I&W
Admiral SILVER24 REF - SXS/I&W
Maytag SK525-2W REF - SXS
Maytag SK535-2 REF - SXS/I&W
Gaggenau SK590-2 REF - BOTTOM MOUNTS
Hardwick SKG4622MGA639R RANGE-F/S CONT CLEAN GAS
Hardwick SKG4622MGW639R RANGE-F/S CONT CLEAN GAS
Hardwick SKG9611A540R RANGE-F/S CONT CLEAN GAS
Hardwick SKG9611W540R RANGE-F/S CONT CLEAN GAS
Amana SKI22F REF - SXS/I&W
Amana SKI22F-A REF - SXS/I&W
Amana SKI22F-C REF - SXS/I&W
Amana SKI22F-G REF - SXS/I&W
Amana SKI22FL REF - SXS/I&W
Hardwick SKJ7141819DE WALLOVEN- CONT CLEAN GAS
Maytag SL10AN-A01 STACKED LAUNDRY- ELE
Maytag SL10AN-A02 STACKED LAUNDRY- ELE
Maytag SL10AN-A03 STACKED LAUNDRY- ELE
Maytag SL11AA STACKED LAUNDRY- ELE
Maytag SL11AN STACKED LAUNDRY- ELE
General Electric SL208 Room air conditioner
General Electric SL210 Room air conditioner
General Electric SL212 Room air conditioner
General Electric SL214 Room air conditioner
General Electric SL217 Room air conditioner
General Electric SL220 Room air conditioner
General Electric SL223 Room air conditioner
Amana SL22F REF - SXS/I&W
Amana SL22F-A REF - SXS/I&W
Amana SL22F-C REF - SXS/I&W
Amana SL22F-G REF - SXS/I&W
Amana SL22F-L REF - SXS/I&W
Amana SL22G REF - SXS/I&W
Amana SL22GL REF - SXS/I&W
Amana SL22JB REF - SXS/I&W
Amana SL22JB Ref - SXS/I&W
Amana SL22MBG REF - SXS/I&W
Amana SL22MBL REF - SXS/I&W
Amana SL22MBW REF - SXS/I&W
Amana SL25G REF - SXS/I&W
Amana SL25GL REF - SXS/I&W
Amana SL25H REF - SXS/I&W
Amana SL25J REF - SXS/I&W
Amana SL25J Ref - SXS/I&W
Amana SL25M2L REF - SXS/I&W
Amana SL25M2W REF - SXS/I&W
Amana SL25MG REF - SXS/I&W
Amana SL25ML REF - SXS/I&W
Amana SL25MW REF - SXS/I&W
Amana SLD22JB REF - SXS/I&W
Amana SLD22MB2L REF - SXS/I&W
Amana SLD22MB2W REF - SXS/I&W
Amana SLD22MBG REF - SXS/I&W
Amana SLD22MBL REF - SXS/I&W
Amana SLD22MBW REF - SXS/I&W
Amana SLD25J REF - SXS/I&W
Amana SLD25JB REF - SXS/I&W
Amana SLD25JP REF - SXS/I&W
Amana SLD25M2G REF - SXS/I&W
  #2 (permalink)
Old 05-11-2017, 08:39 AM
Junior Member
Default Update
After speaking with a repair tech, sounds like it most likely is the Control Board. This particular unit does not have e a thermal fuse he said and they tend to go out frequently. I'm going to order a new one and swap it out. Will report back if it fixes to close this issue out.
  #3 (permalink)
Old 05-18-2017, 09:06 AM
Junior Member
Default Fixed - New Control Board
After swapping the control board in my unit, all is fixed. Unfortunate that I had to pay $200+ to fix it, but better than $400+ to have a repair technician do it.
Quick tip for anyone facing a similar issue - There is a fantastic YouTube video for fixing some of the common issues with control boards by replacing a burned out relay. My control board had a burn on a relay solder just as the issue in this video has, however since mine did not power on at all it would unlikely fix my issue. But maybe it will help someone else in trouble: https://youtu.be/Jb8gAnMb2zQ
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Power cutting off during wash cycle. Power switch? Ken Lebbin Dishwasher Repair 0 04-17-2013 09:56 AM
puzzle Torie Colvin Oven Repair (including Ranges and Cooktops) 1 08-20-2011 04:57 AM
Bosch power switch won't stay on rfjoinery Dishwasher Repair 0 07-12-2009 11:30 AM
My no heat dryer puzzle for you wizards. jfull1965 Dryer Repair 1 10-22-2008 03:40 PM
gas dryer puzzle jkozz12 Dryer Repair 0 05-29-2008 10:47 AM
