Discuss
Bosch Dishwasher Water Fault and beeping
 in
Dishwasher Repair
About a minute into the wash cycle the water faucet symbol lights up and it starts beeping. I ran through
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch Dishwasher Water Fault and beeping
  #1 (permalink)
Old 04-23-2017, 02:49 PM
Junior Member
mknhouston is on a distinguished road
Default Bosch Dishwasher Water Fault and beeping
Model Number: SHE68M05UC50   Brand: Bosch   Age: More than 10 years
About a minute into the wash cycle the water faucet symbol lights up and it starts beeping. I ran through the test cycle and got an E3 error code.
I bought a new inlet valve and installed it. Same problem, but after running the test cycle got error E5.
I pull the level switch and tested the continuity and all tested good.
I then ran a normal cycle and found out that the cycle didn't stop after the beeping started. It ran through the entire wash cycle with no problem except the error light was on and it was beeping. Turns out that it beeps every time water comes in, which is two or three times per cycle, and goes off when the water shuts off. So during a cycle it beeps while water comes in, stops when it is full and during washing, then drains, and when it starts to bring in fresh water it starts beeping again. stops when it is full and so on.
What causes this and how do it confirm the part is the real problem?
Related Models
Whirlpool SHF3801W0 Dishwasher
Whirlpool SHF3804W2 Dishwasher
Whirlpool SHF4500W0 Dishwasher
Whirlpool SHF5500W0 Dishwasher
Whirlpool SHF5501W0 Dishwasher
Whirlpool SHF5504W0 Dishwasher
Whirlpool SHF5584P1 Dishwasher
Whirlpool SHF5584P2 Dishwasher
Whirlpool SHF5801W0 Dishwasher
Whirlpool SHF5801W1 Dishwasher
Whirlpool SHF5884P1 Dishwasher
Whirlpool SHF5884P2 Dishwasher
Whirlpool SHF7800W0 Dishwasher
Whirlpool SHF7801W0 Dishwasher
Whirlpool SHF7804W1 Dishwasher
Whirlpool SHF7884P0 Dishwasher
Whirlpool SHF7884P1 Dishwasher
Whirlpool SHF7884P2 Dishwasher
Bosch SHI4302 UC/06 -FD8002
Bosch SHI4302 UC/11 -FD8003
Bosch SHI4302 UC/12
Bosch SHI4306 UC/06 -FD8002
Bosch SHI4306 UC/11 -FD8003
Bosch SHI4306 UC/12
Bosch SHI66A05 UC/14 (FD 8211-)
Bosch SHI6802 UC/06
Bosch SHI6802 UC/11
Bosch SHI6802 UC/12
Bosch SHI6805 UC/06
Bosch SHI6805 UC/11
Bosch SHI6805 UC/12
Bosch SHI6806 UC/06
Bosch SHI6806 UC/11
Bosch SHI6806 UC/12
Whirlpool SHU30011 DISHWASHER
Bosch SHU3002
Whirlpool SHU30041 DISHWASHER
Bosch SHU3006
Bosch SHU3012
Whirlpool SHU30140 DISHWASHER
Whirlpool SHU30141 DISHWASHER
Bosch SHU3016
Bosch SHU3032 UC/06 (FD 7908-8002)
Bosch SHU3032 UC/11 (FD 8002-8003)
Bosch SHU3032 UC/12 (FD 8003-)
Bosch SHU3035 UC/12 (FD 8006-)
Bosch SHU3036 UC/06 (FD 7908-8002)
Bosch SHU3036 UC/11 (FD 8002-8003)
Bosch SHU3036 UC/12 (FD 8003-)
Bosch SHU3132 UC/12 (FD 8105-)
Bosch SHU3135 UC/12 (FD 8105-)
Bosch SHU3136 UC/12 (FD 8105-)
Bosch SHU3302 UC/06 (FD 7902-8003)
Bosch SHU3302 UC/11 (FD 8003-8003)
Bosch SHU3302 UC/12 (FD 8003 -)
Bosch SHU3305 UC/06 (FD 7902-8003)
Bosch SHU3305 UC/11 (FD 8003-8003)
Bosch SHU3305 UC/12 (FD 8003 -)
Bosch SHU3306 UC/06 (FD 7902-8003)
Bosch SHU3306 UC/11 (FD 8003-8003)
Bosch SHU3306 UC/12 (FD 8003 -)
Bosch SHU3307 UC/12 (FD 8005 -)
Bosch SHU3322 UC/06
Bosch SHU3322 UC/11
Bosch SHU3322 UC/12
Bosch SHU3322 UC/12 (FD 8003-)
Bosch SHU3326 UC/06
Bosch SHU3326 UC/11
Bosch SHU3326 UC/12
Bosch SHU3326 UC/12 (FD 8003-)
Bosch SHU3336 UC/06
Bosch SHU3336 UC/11
Bosch SHU3336 UC/12
Bosch SHU3336 UC/12 (FD 8003-)
Bosch SHU33A02 UC/14 (FD 8211-)
Bosch SHU33A06 UC/14 (FD 8211-)
Bosch SHU33AC02 UC/14
Bosch SHU33AC06 UC/14
Whirlpool SHU40011 DISHWASHER
Bosch SHU4002 UC/06
Whirlpool SHU40041 DISHWASHER
Bosch SHU4006 UC/06
Bosch SHU4016 UC/06
Bosch SHU4022 UC/06
Bosch SHU4026 UC/06
Bosch SHU4036 UC/06
Bosch SHU4302 UC/06 (FD 7705-7912)
Bosch SHU4302 UC/11 (FD 8001-8003)
Bosch SHU4302 UC/12 (FD 8003-)
Bosch SHU4306 UC/06 (FD 7705-7912)
Bosch SHU4306 UC/11 (FD 8001-8003)
Bosch SHU4306 UC/12 (FD 8003-)
Bosch SHU4312 UC/06 (FD 7701-7912)
Bosch SHU4312 UC/11 (FD 8001-8003)
Bosch SHU4312 UC/12 (FD 8003-)
Bosch SHU4316 UC/06
Bosch SHU4316 UC/11
Bosch SHU4316 UC/12
Bosch SHU4322 UC/12
Bosch SHU4322 UC/12 (FD 8003-)
Bosch SHU4326 UC/12
Bosch SHU4326 UC/12 (FD 8003-)
Bosch SHU43C02 UC/14 (FD 8211-)
Bosch SHU43C05 UC/14 (FD 8211-)
Bosch SHU43C06 UC/14 (FD 8211-)
Bosch SHU43C07 UC/14 (FD 8211-)
Bosch SHU43E02 UC/14 (FD 8211-)
Bosch SHU43E05 UC/14 (FD 8211-)
Bosch SHU43E06 UC/14 (FD 8211-)
Bosch SHU43E07 UC/14 (FD 8211-)
Whirlpool SHU45010 Dishwasher
Whirlpool SHU45020 Dishwasher
Whirlpool SHU50041 Dishwasher
Whirlpool SHU50043 Dishwasher
Bosch SHU5302 UC/06 (FD 7705-7912)
Bosch SHU5302 UC/11 (FD 8001-8003)
Bosch SHU5302 UC/12 (FD 8003-)
Bosch SHU5304 UC/06 (FD 7705-7912)
Bosch SHU5304 UC/11 (FD 8001-8003)
Bosch SHU5304 UC/12 (FD 8003-)
  #2 (permalink)
Old 04-24-2017, 04:08 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You may want to run the customer service test program to clear error codes by doing the following:
While pushing (and holding) any two wash cycle buttons, turn the dishwasher on with the on/off switch. After releasing the buttons, LED B will be lit and LED C will flash, confirming youre in the special programs menu.
To enter the test program, push button B repeatedly until the digital display shows P1 or until LED C is lit.
Push button C to start the program -- LED C will blink. The steps will show on the digital display (e.g."S:01") -- push button B to skip a step.
Stored error codes will show on the digital display and LEDs.
The test program can only be stopped/reset by pushing the on/off button it cant be done by turning off the power.
*The buttons and LED's attached.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 04-25-2017, 08:59 AM
Junior Member
Default
Ran the test program and it showed error code 5, but it went away and was not stored after the test. Wierd, eh? It usually stores it.
The beeping seems to be somehow related to filling. I pulled out the dishwasher, pulled off the side panel and watched a full cycle. As soon as it started filling, the beeping started. When the dishwasher got full and the float tripped the switch, the beeping stopped until it got to another fill cycle.
It can't be the inlet valve cause a.) i've replaced it and b.) I have seen it open, fill and close fine.
Would the flow meter cause this issue?
  #4 (permalink)
Old 04-25-2017, 01:48 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I've checked all available for me documentation for your dishwasher model. That's what I found: Error code E5, either safety float water level reached or motor speed error.
If error code E5 is safety float water level reached, check the float and float switch (in the base), check if water is in the base and check if the water inlet valve has re-seated after closing.
No tests for the motor speed. Nothing about beeping. Very weird!
__________________
  #5 (permalink)
Old 04-26-2017, 10:16 AM
Junior Member
Default
Gene thanks.
No water in base. Checked safety switch continuity and its good. And beeping stops after the level is reached.
Motor speed error? Are you talking about the water flow meter? Or one of the pumps?
Weird indeed! The silly thing works, I just have to put up with the the beeping for about a minute, two or three times during the cycle. You know how long a minute can seem when it's beeping at you.
I shall try replacing the flow meter or jug as they call it.
Any ideas would be appreciated.
  #6 (permalink)
Old 05-06-2017, 01:11 PM
Junior Member
Default
Well, I replaced the flow meter and it solved the problem. Hurray!
  #7 (permalink)
Old 05-07-2017, 05:59 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I'm glad you were able to fix it. Good job!
And thank you for sharing it with us.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch Dishwasher Error code with a red spigot and beeping ewance Dishwasher Repair 0 09-07-2015 03:41 PM
bosch dishwasher fault code 4 digearth Dishwasher Repair 0 11-21-2012 03:37 PM
Bosch Dishwasher no water fault tallerpaul007 Dishwasher Repair 2 02-21-2012 02:44 PM
Bosch water sensor filling fault GEHACCI Dishwasher Repair 0 07-15-2011 05:46 PM
Bosch Fault Code 4 Eduardo 71 Dishwasher Repair 0 02-14-2011 09:32 PM
