Good Morning my name is Nick and I have an issue with my Kitchen Aid Dishwasher model #KUDK02CRBS0.
At first my cancel button light was continuously blinking. I completed a restart on the dishwashers computer by "high temp", "heat dry", "high temp", & "heat dry". It was successful and the machine began to drain and everything appeared to be in good order.
Then I attempted to perform a "Rinse Cycle" on the dishes that were still in the dish washer. the machine filled and began to work properly. Within 2 minutes of the cycle the machine stopped again.
I performed the same reboot as I mentioned above, but now ALL THE LIGHTS on the overlay front panel illuminated. I proceeded to hit the cancel button and unplug the machine for 1 minute. I re-plugged the machine back in and performed the above reboot process again. Once again all the lights illuminated on the panel.
I then proceeded to "high temp", & "heat dry" buttons simultaneously for a total of 5 times each as I read from other posts and saw on you tube. Unfortunately, it didn't work and then panel immediately ALL illuminated after pressing the "high temp", "heat dry", "high temp", & "heat dry" reboot process.
HELP! Is there anything else I can do or do I need to replace Electronic Control Board, the main control board, or the push button overlay. Any information would be helpful. The machine is about 10 years old and has never had an issue.
Nick
ndiiorio attached the following image(s):
