Dishwasher Not Fully Draining
Dishwasher Repair
My dishwasher doesn't fully drain out the water from the tub. There is about 1/4 inch of water around the
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher Not Fully Draining
  #1 (permalink)
Old 03-18-2017, 04:53 PM
Junior Member
gciccol is on a distinguished road
Default Dishwasher Not Fully Draining
Model Number: GSD4010Z04AA   Brand: GE   Age: More than 10 years
My dishwasher doesn't fully drain out the water from the tub. There is about 1/4 inch of water around the back of the tub at the end of the wash cycle.
Repair Steps.
1. I removed the filter frame, piston and nut assembly,sump cover and sump cap in the rear of the tub. There was nothing blocking them. I used a shop vac to suck out all the water and anything down in the sump area.
2. The Piston and Nut Assembly looked a little worn so I replaced it with a new one.
3. The Drain Solenoid arm moves freely and the piston slides up/down fine. I watched it engage during a test cycle where the piston was pushed down for about 30 seconds as the tub was draining. I also pulled it out of the unit to test it for resistance. I showed 37 ohms of resistance which my research says is correct for a good solenoid. I reinstalled it on the washer.
4. I removed the Check Valve & Body Assembly. The check valve looked a little worn so I replaced it with a new unit.
5. I checked the drain line where it connects into the garbage disposal and it was clear. I forgot to check the line coming out of the bottom of the drain pump before I reinstalled the washer back into the cabinet.
6. I did not test the drain pump as I don't know how. I do see the drain solenoid engaging and hear the pump pushing water as I saw the drain line moving back and forth so it seems like the drain pump is fine.
Does anyone know of another test I could be doing?
Is there a way to test the pump/motor assembly?
Is there a test to check if the control board is just shutting off the drain pump too soon at the end of the cycle?
The only thing I have left to replace is the complete pump/motor assembly and I hate to spend $128 on it and find it doesn't fix my problem.
Any assistance would be greatly appreciated. Thank You
Related Models
General Electric GSD4010Z04AA Dishwasher
General Electric GSD4010Z05AA Dishwasher
General Electric GSD4010Z07AA Dishwasher
General Electric GSD4020Y70BB Dishwasher
General Electric GSD4020Y72BB Dishwasher
General Electric GSD4020Y73BB Dishwasher
General Electric GSD4020Y74BB Dishwasher
General Electric GSD4020Z00BB Dishwasher
General Electric GSD4020Z02BB Dishwasher
General Electric GSD4020Z04BB Dishwasher
General Electric GSD4020Z05BB Dishwasher
General Electric GSD4020Z07BB Dishwasher
General Electric GSD4030Y70WW Dishwasher
General Electric GSD4030Y72WW Dishwasher
General Electric GSD4030Y73WW Dishwasher
General Electric GSD4030Y74WW Dishwasher
General Electric GSD4030Z00WW Dishwasher
General Electric GSD4030Z02WW Dishwasher
General Electric GSD4030Z04WW Dishwasher
General Electric GSD4030Z05WW Dishwasher
General Electric GSD4030Z07WW Dishwasher
General Electric GSD4060J00SS Dishwasher
General Electric GSD4060J20SS Dishwasher
General Electric GSD4060N00SS DISHWASHER
General Electric GSD4060N10SS DISHWASHER
General Electric GSD4060N20SS DISHWASHER
General Electric GSD4060R00SS DISHWASHER
General Electric GSD4060R15SS DISHWASHER
General Electric GSD4100J00BB Dishwasher
General Electric GSD4100J00CC Dishwasher
General Electric GSD4100J00WW Dishwasher
General Electric GSD4110Y70AA Dishwasher
General Electric GSD4110Y72AA Dishwasher
General Electric GSD4110Y73AA Dishwasher
General Electric GSD4112Z02AA Dishwasher
General Electric GSD4112Z04AA Dishwasher
General Electric GSD4112Z05AA Dishwasher
General Electric GSD4112Z07AA Dishwasher
General Electric GSD4114Z02AA Dishwasher
General Electric GSD4114Z04AA Dishwasher
General Electric GSD4120Y01BB Dishwasher
General Electric GSD4120Y04BB Dishwasher
General Electric GSD4120Y70BB Dishwasher
General Electric GSD4120Y72BB Dishwasher
General Electric GSD4120Y73BB Dishwasher
General Electric GSD4122Z02BB Dishwasher
General Electric GSD4122Z04BB Dishwasher
General Electric GSD4122Z05BB Dishwasher
General Electric GSD4122Z07BB Dishwasher
General Electric GSD4124Z02BB Dishwasher
General Electric GSD4124Z04BB Dishwasher
General Electric GSD4130Y01WW Dishwasher
General Electric GSD4130Y04WW Dishwasher
General Electric GSD4130Y70WW Dishwasher
General Electric GSD4130Y72WW Dishwasher
General Electric GSD4130Y73WW Dishwasher
General Electric GSD4132Z02WW Dishwasher
General Electric GSD4132Z04WW Dishwasher
General Electric GSD4132Z05WW Dishwasher
General Electric GSD4132Z07WW Dishwasher
General Electric GSD4134Z02WW Dishwasher
General Electric GSD4134Z04WW Dishwasher
General Electric GSD4160J00SS Dishwasher
General Electric GSD4200J00BB Dishwasher
General Electric GSD4200J00CC Dishwasher
General Electric GSD4200J00WW Dishwasher
General Electric GSD4210X65AA Dishwasher
General Electric GSD4210X66AA Dishwasher
General Electric GSD4210X72AA Dishwasher
General Electric GSD4210X73AA Dishwasher
General Electric GSD4220X65BB Dishwasher
General Electric GSD4220X66BB Dishwasher
General Electric GSD4220X72BB Dishwasher
General Electric GSD4220X73BB Dishwasher
General Electric GSD4230X65WW Dishwasher
General Electric GSD4230X66WW Dishwasher
General Electric GSD4230X72WW Dishwasher
General Electric GSD4230X73WW Dishwasher
General Electric GSD4260J00SS Dishwasher
General Electric GSD4300L03BB Dishwasher
General Electric GSD4300L03WW Dishwasher
General Electric GSD4310Y72AA Dishwasher
General Electric GSD4310Y73AA Dishwasher
General Electric GSD4310Z00AA Dishwasher
General Electric GSD4310Z02AA Dishwasher
General Electric GSD4310Z04AA Dishwasher
General Electric GSD4315Z00AA Dishwasher
General Electric GSD4315Z02AA Dishwasher
General Electric GSD4315Z04AA Dishwasher
General Electric GSD4320Y72BB Dishwasher
General Electric GSD4320Y73BB Dishwasher
General Electric GSD4320Z00BB Dishwasher
General Electric GSD4320Z02BB Dishwasher
General Electric GSD4320Z04BB Dishwasher
General Electric GSD4325Z00BB Dishwasher
General Electric GSD4325Z02BB Dishwasher
General Electric GSD4325Z04BB Dishwasher
General Electric GSD4330Y72WW Dishwasher
General Electric GSD4330Y73WW Dishwasher
General Electric GSD4330Z00WW Dishwasher
General Electric GSD4330Z02WW Dishwasher
General Electric GSD4330Z04WW Dishwasher
General Electric GSD4335Z00WW Dishwasher
General Electric GSD4335Z02WW Dishwasher
General Electric GSD4335Z04WW Dishwasher
General Electric GSD4360L03SS Dishwasher
General Electric GSD4410X65AA Dishwasher
General Electric GSD4410X66AA Dishwasher
General Electric GSD4410X72AA Dishwasher
General Electric GSD4410X73AA Dishwasher
General Electric GSD4420X65BB Dishwasher
General Electric GSD4420X66BB Dishwasher
General Electric GSD4420X72BB Dishwasher
General Electric GSD4420X73BB Dishwasher
General Electric GSD4430X65WW Dishwasher
General Electric GSD4430X66WW Dishwasher
General Electric GSD4430X72WW Dishwasher
General Electric GSD4430X73WW Dishwasher
General Electric GSD4500G00BB Dishwasher
General Electric GSD4500G00CC Dishwasher
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dishwasher not draining fully ernestcmjr Dishwasher Repair 1 01-29-2016 02:13 PM
Dishwasher leaking slightly and not draining fully bdgnae Dishwasher Repair 0 07-31-2013 11:46 AM
Dishwasher Not Fully Draining Rich A1 Dishwasher Repair 0 04-05-2013 07:34 AM
Dishwasher not fully draining gciccol Dishwasher Repair 5 07-04-2012 10:00 AM
Dishwasher not fully draining JandLKay Dishwasher Repair 1 08-10-2010 05:51 AM
