Discuss
Please help! Fuse keeps blowing
 in
Dishwasher Repair
I need your help! My dishwasher will not complete a cycle w/o blowing the TCO fuse. I just replaced the
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Please help! Fuse keeps blowing
  #1 (permalink)
Old 03-18-2017, 01:12 PM
Junior Member
MikeFixItAll is on a distinguished road
Default Please help! Fuse keeps blowing
Model Number: GU2400XTPQ1   Brand: Whirlpool   Age: More than 10 years
I need your help! My dishwasher will not complete a cycle w/o blowing the TCO fuse. I just replaced the fuse, along with a new board, and about 5 minutes after the soap dispenser released, it shut off, and I immediately opened it up to verify the fuse had blown. Wires all seem fine.
Here's some history:
• I'm the only owner, installed in brand new house in 2005.
• Heating element was replaced in first year due to recall, but never had a problem
• Worked perfectly until last year, faulted intermittently and wouldn't finish a load...had the notorious "clean light blinking 7 times"
• Troubleshooting led to finding burned solder points on control board - one at heater relay (K2), the other on the connected blade terminal solder joint at CON1 (W-R).
• Resoldered joints, worked like a champ for 2 months, then died
• Found fuse to be blown. Ordered new fuse with wires, replaced but blew on first load run. Countdown display read 50-something when it blew. On advice, I did not use the wires included with the new fuse, but crimped the existing connectors to ensure a very tight connection on the new TCO.
• Questioning the integrity of my solder repairs, I ordered a like-new used board and fuse.
• New board came with good fuse attached, so I attached existing (original) wires which connected tightly - shouldn't have posed a problem
• Fuse blew on first wash load, about five minutes after soap dispenser opened.
• *** I've noticed the steam vent stays open - I think it's stuck or solenoid is bad. I can hear all the inside noise that I don't ever remember hearing before during any cycle. When I cover it with my hand it is much quieter. Could this be related to the fuse blowing?
• I've pulled the dishwasher out and ohm'd the heating element and high limit thermostat. Both checked good and the connections are clean and tight.
I still have a new fuse w/ wires, but I feel like it's just going to blow again. What would likely cause the failure even with new fuse and control board? Am I missing something?
Thanks for any help!
Mike
Edit: About 5 minutes after initially starting the dishwasher with the new control board and fuse, I stopped the cycle by opening the door to troubleshoot the apparent vent stuck open. The water inside was very warm but not hot, heating element did not feel hot either. It sat long enough for the water to get cool before resuming the cycle. It then finished spraying, drained, refilled and continued as normal. The moment it cut out (about 7 to 10 minutes later), I opened it and felt the water temp - it was lukewarm, as was the heating element. I expected it to be much warmer if not hot. I'm wondering if my problem isn't a bad element...?
Related Models
Whirlpool GU2400XTPQ1 DISHWASHER
Whirlpool GU2400XTPQ3 UNDERCOUNTER DISHWASHER
Whirlpool GU2400XTPQ6 DISHWASHER
Whirlpool GU2400XTPQ7 UNDERCOUNTER DISHWASHER
Whirlpool GU2400XTPS0 UNDERCOUNTER DISHWASHER
Whirlpool GU2400XTPS1 DISHWASHER
Whirlpool GU2400XTPS3 UNDERCOUNTER DISHWASHER
Whirlpool GU2400XTPS6 DISHWASHER
Whirlpool GU2400XTPS7 UNDERCOUNTER DISHWASHER
Whirlpool GU2400XTPT0 UNDERCOUNTER DISHWASHER
Whirlpool GU2400XTPT1 DISHWASHER
Whirlpool GU2400XTPT3 UNDERCOUNTER DISHWASHER
Whirlpool GU2400XTPT6 DISHWASHER
Whirlpool GU2400XTPT7 UNDERCOUNTER DISHWASHER
Whirlpool GU2451XTSB0 UNDERCOUNTER DISHWASHER
Whirlpool GU2451XTSB1 UNDERCOUNTER DISHWASHER
Whirlpool GU2451XTSB2 UNDERCOUNTER DISHWASHER
Whirlpool GU2451XTSQ0 UNDERCOUNTER DISHWASHER
Whirlpool GU2451XTSQ1 UNDERCOUNTER DISHWASHER
Whirlpool GU2451XTSQ2 UNDERCOUNTER DISHWASHER
Whirlpool GU2451XTSS0 UNDERCOUNTER DISHWASHER
Whirlpool GU2451XTSS1 UNDERCOUNTER DISHWASHER
Whirlpool GU2451XTSS2 UNDERCOUNTER DISHWASHER
Whirlpool GU2451XTST0 UNDERCOUNTER DISHWASHER
Whirlpool GU2451XTST1 UNDERCOUNTER DISHWASHER
Whirlpool GU2451XTST2 UNDERCOUNTER DISHWASHER
Whirlpool GU2455XTSB0 UNDERCOUNTER DISHWASHER
Whirlpool GU2455XTSB1 UNDERCOUNTER DISHWASHER
Whirlpool GU2455XTSB2 UNDERCOUNTER DISHWASHER
Whirlpool GU2455XTSB3 UNDERCOUNTER DISHWASHER
Whirlpool GU2455XTSQ0 UNDERCOUNTER DISHWASHER
Whirlpool GU2455XTSQ1 UNDERCOUNTER DISHWASHER
Whirlpool GU2455XTSQ2 UNDERCOUNTER DISHWASHER
Whirlpool GU2455XTSQ3 UNDERCOUNTER DISHWASHER
Whirlpool GU2455XTSS0 UNDERCOUNTER DISHWASHER
Whirlpool GU2455XTSS1 UNDERCOUNTER DISHWASHER
Whirlpool GU2455XTSS2 UNDERCOUNTER DISHWASHER
Whirlpool GU2455XTSS3 UNDERCOUNTER DISHWASHER
Whirlpool GU2455XTST0 UNDERCOUNTER DISHWASHER
Whirlpool GU2455XTST1 UNDERCOUNTER DISHWASHER
Whirlpool GU2455XTST2 UNDERCOUNTER DISHWASHER
Whirlpool GU2455XTST3 UNDERCOUNTER DISHWASHER
Whirlpool GU2475XTVB0 UNDERCOUNTER DISHWASHER
Whirlpool GU2475XTVB1 UNDERCOUNTER DISHWASHER
Whirlpool GU2475XTVB2 UNDERCOUNTER DISHWASHER
Whirlpool GU2475XTVB3 UNDERCOUNTER DISHWASHER
Whirlpool GU2475XTVQ0 UNDERCOUNTER DISHWASHER
Whirlpool GU2475XTVQ1 UNDERCOUNTER DISHWASHER
Whirlpool GU2475XTVQ2 UNDERCOUNTER DISHWASHER
Whirlpool GU2475XTVQ3 UNDERCOUNTER DISHWASHER
Whirlpool GU2475XTVY0 UNDERCOUNTER DISHWASHER
Whirlpool GU2475XTVY1 UNDERCOUNTER DISHWASHER
Whirlpool GU2475XTVY2 UNDERCOUNTER DISHWASHER
Whirlpool GU2475XTVY3 UNDERCOUNTER DISHWASHER
Whirlpool GU2500XTPB0 UNDERCOUNTER DISHWASHER
Whirlpool GU2500XTPB1 UNDERCOUNTER DISHWASHER
Whirlpool GU2500XTPB3 UNDERCOUNTER DISHWASHER
Whirlpool GU2500XTPB6 UNDERCOUNTER DISHWASHER
Whirlpool GU2500XTPB7 UNDERCOUNTER DISHWASHER
Whirlpool GU2500XTPQ0 UNDERCOUNTER DISHWASHER
Whirlpool GU2500XTPQ1 UNDERCOUNTER DISHWASHER
Whirlpool GU2500XTPQ3 UNDERCOUNTER DISHWASHER
Whirlpool GU2500XTPQ6 UNDERCOUNTER DISHWASHER
Whirlpool GU2500XTPQ7 UNDERCOUNTER DISHWASHER
Whirlpool GU2500XTPS0 UNDERCOUNTER DISHWASHER
Whirlpool GU2500XTPS1 UNDERCOUNTER DISHWASHER
Whirlpool GU2500XTPS3 UNDERCOUNTER DISHWASHER
Whirlpool GU2500XTPS6 UNDERCOUNTER DISHWASHER
Whirlpool GU2500XTPS7 UNDERCOUNTER DISHWASHER
Whirlpool GU2500XTPT0 UNDERCOUNTER DISHWASHER
Whirlpool GU2500XTPT1 UNDERCOUNTER DISHWASHER
Whirlpool GU2500XTPT3 UNDERCOUNTER DISHWASHER
Whirlpool GU2500XTPT6 UNDERCOUNTER DISHWASHER
Whirlpool GU2500XTPT7 UNDERCOUNTER DISHWASHER
Whirlpool GU2548XTPB0 UNDERCOUNTER DISHWASHER
Whirlpool GU2548XTPQ0 UNDERCOUNTER DISHWASHER
Whirlpool GU2548XTPQ1 UNDERCOUNTER DISHWASHER
Whirlpool GU2548XTPQ3 UNDERCOUNTER DISHWASHER
Whirlpool GU2548XTPQ6 UNDERCOUNTER DISHWASHER
Whirlpool GU2548XTPQ7 UNDERCOUNTER DISHWASHER
Whirlpool GU2548XTPS0 UNDERCOUNTER DISHWASHER
Whirlpool GU2548XTPS1 UNDERCOUNTER DISHWASHER
Whirlpool GU2548XTPS3 UNDERCOUNTER DISHWASHER
Whirlpool GU2548XTPS6 UNDERCOUNTER DISHWASHER
Whirlpool GU2548XTPS7 UNDERCOUNTER DISHWASHER
Whirlpool GU2548XTPT0 UNDERCOUNTER DISHWASHER
Whirlpool GU2600XTPB0 UNDERCOUNTER DISHWASHER
Whirlpool GU2600XTPB1 UNDERCOUNTER DISHWASHER
Whirlpool GU2600XTPB3 UNDERCOUNTER DISHWASHER
Whirlpool GU2600XTPB6 UNDERCOUNTER DISHWASHER
Whirlpool GU2600XTPB7 UNDERCOUNTER DISHWASHER
Whirlpool GU2600XTPQ0 UNDERCOUNTER DISHWASHER
Whirlpool GU2600XTPQ1 UNDERCOUNTER DISHWASHER
Whirlpool GU2600XTPQ3 UNDERCOUNTER DISHWASHER
Whirlpool GU2600XTPQ6 UNDERCOUNTER DISHWASHER
Whirlpool GU2600XTPQ7 UNDERCOUNTER DISHWASHER
Whirlpool GU2600XTPS0 UNDERCOUNTER DISHWASHER
Whirlpool GU2600XTPS1 UNDERCOUNTER DISHWASHER
Whirlpool GU2600XTPS3 UNDERCOUNTER DISHWASHER
Whirlpool GU2600XTPS6 UNDERCOUNTER DISHWASHER
Whirlpool GU2600XTPS7 UNDERCOUNTER DISHWASHER
Whirlpool GU2600XTPT0 UNDERCOUNTER DISHWASHER
Whirlpool GU2600XTPT1 UNDERCOUNTER DISHWASHER
Whirlpool GU2600XTPT3 UNDERCOUNTER DISHWASHER
Whirlpool GU2600XTPT6 UNDERCOUNTER DISHWASHER
Whirlpool GU2600XTPT7 UNDERCOUNTER DISHWASHER
Whirlpool GU2700XTSB0 UNDERCOUNTER DISHWASHER
Whirlpool GU2700XTSB1 UNDERCOUNTER DISHWASHER
Whirlpool GU2700XTSQ0 UNDERCOUNTER DISHWASHER
Whirlpool GU2700XTSQ1 UNDERCOUNTER DISHWASHER
Whirlpool GU2700XTSS0 UNDERCOUNTER DISHWASHER
Whirlpool GU2700XTSS1 UNDERCOUNTER DISHWASHER
Whirlpool GU2700XTST0 UNDERCOUNTER DISHWASHER
Whirlpool GU2700XTST1 UNDERCOUNTER DISHWASHER
Whirlpool GU2700XTSY0 UNDERCOUNTER DISHWASHER
Whirlpool GU2700XTSY1 UNDERCOUNTER DISHWASHER
Whirlpool GU2800XTVB0 UNDERCOUNTER DISHWASHER
Whirlpool GU2800XTVB1 UNDERCOUNTER DISHWASHER
Whirlpool GU2800XTVB2 UNDERCOUNTER DISHWASHER
Whirlpool GU2800XTVB3 UNDERCOUNTER DISHWASHER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fuse keeps blowing waddawander Microwave Repair 0 04-23-2012 08:11 PM
Dryer overheat blowing thermal fuse heater box, not vent fuse try2repairguy Dryer Repair 2 11-10-2011 08:27 AM
fuse keeps blowing! painter37 Microwave Repair 1 03-26-2010 09:19 AM
Blowing 1 amp fuse john neer Washer Repair 0 09-06-2009 07:18 AM
blowing 15 amp fuse foxie Microwave Repair 5 04-07-2008 05:25 PM
