Discuss
Kenmore Pump Continues to Run
 in
Dishwasher Repair
We have a ten year old Kenmore Dishwasher Model # 665.1311.4K700. Recently at the very end of the cycle the
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Kenmore Pump Continues to Run
  #1 (permalink)
Old 03-12-2017, 09:11 AM
Junior Member
Jbrune is on a distinguished road
Default Kenmore Pump Continues to Run
Model Number: 665.1311.4K700   Brand: Kenmore   Age: More than 10 years
Recently at the very end of the cycle the pump continues to run even though all thereís no water left to pump out. I believe I confirmed this when I pulled off both ends of the drain hose and there was no water left in the unit. BTW: I also checked the hose for blockages and there were none. We end up pressing the cancel button to shut it off.
I then tested the float switch with my ohm meter and it appears to be OK.
At this point I donít know what else to test.
A repairman I talked to suggested replacing the pump but since it seems to be pumping OK Iím wondering if thereís another sensor that may be at fault or if this leads me back to the control panel.
Or, is there something internal to the pump assembly causing it to run on and I should replace the pump.
Everything else seems to be working fine.
Thanks in advance for your help and advice.
Jeff
Related Models
Kenmore 665110739120 DISHWASHER
Kenmore 665110739130 DISHWASHER
Kenmore 665110739140 DISHWASHER
Kenmore 665110739190 DISHWASHER
Kenmore 66513012K110 UNDERCOUNTER DISHWASHER
Kenmore 66513013K110 UNDERCOUNTER DISHWASHER
Kenmore 66513014K110 UNDERCOUNTER DISHWASHER
Kenmore 66513019K110 UNDERCOUNTER DISHWASHER
Kenmore 66513023K110 DISHWASHER
Kenmore 66513032K110 UNDERCOUNTER DISHWASHER
Kenmore 66513033K110 UNDERCOUNTER DISHWASHER
Kenmore 66513039K110 UNDERCOUNTER DISHWASHER
Kenmore 66513042K110 UNDERCOUNTER DISHWASHER
Kenmore 66513043K110 UNDERCOUNTER DISHWASHER
Kenmore 66513044K110 UNDERCOUNTER DISHWASHER
Kenmore 66513049K110 UNDERCOUNTER DISHWASHER
Kenmore 66513102K900 DISHWASHER
Kenmore 66513102K901 UNDERCOUNTER DISHWASHER
Kenmore 66513102K902 UNDERCOUNTER DISHWASHER
Kenmore 66513103K900 DISHWASHER
Kenmore 66513103K901 UNDERCOUNTER DISHWASHER
Kenmore 66513103K902 UNDERCOUNTER DISHWASHER
Kenmore 66513104K900 DISHWASHER
Kenmore 66513104K901 UNDERCOUNTER DISHWASHER
Kenmore 66513104K902 UNDERCOUNTER DISHWASHER
Kenmore 66513109K900 DISHWASHER
Kenmore 66513109K901 UNDERCOUNTER DISHWASHER
Kenmore 66513109K902 UNDERCOUNTER DISHWASHER
Kenmore 66513112K700 DISHWASHER
Kenmore 66513112K701 DISHWASHER
Kenmore 66513112K702 UNDERCOUNTER DISHWASHER
Kenmore 66513113K700 DISHWASHER
Kenmore 66513113K701 DISHWASHER
Kenmore 66513113K702 UNDERCOUNTER DISHWASHER
Kenmore 66513114K700 DISHWASHER
Kenmore 66513114K701 DISHWASHER
Kenmore 66513114K702 UNDERCOUNTER DISHWASHER
Kenmore 66513119K700 DISHWASHER
Kenmore 66513119K701 DISHWASHER
Kenmore 66513119K702 UNDERCOUNTER DISHWASHER
Kenmore 66513122K700 DISHWASHER
Kenmore 66513122K701 DISHWASHER
Kenmore 66513122K702 DISHWASHER
Kenmore 66513122K703 DISHWASHER
Kenmore 66513123K700 DISHWASHER
Kenmore 66513123K701 DISHWASHER
Kenmore 66513123K702 DISHWASHER
Kenmore 66513123K703 DISHWASHER
Kenmore 66513124K700 DISHWASHER
Kenmore 66513124K701 DISHWASHER
Kenmore 66513124K702 DISHWASHER
Kenmore 66513124K703 DISHWASHER
Kenmore 66513129K700 DISHWASHER
Kenmore 66513129K701 DISHWASHER
Kenmore 66513129K702 DISHWASHER
Kenmore 66513129K703 UNDERCOUNTER DISHWASHER
Kenmore 66513132K700 DISHWASHER
Kenmore 66513132K701 DISHWASHER
Kenmore 66513133K700 DISHWASHER
Kenmore 66513133K701 DISHWASHER
Kenmore 66513139K700 DISHWASHER
Kenmore 66513139K701 DISHWASHER
Kenmore 66513152K700 DISHWASHER
Kenmore 66513152K701 DISHWASHER
Kenmore 66513152K702 DISHWASHER
Kenmore 66513153K700 DISHWASHER
Kenmore 66513153K701 DISHWASHER
Kenmore 66513153K702 DISHWASHER
Kenmore 66513154K700 DISHWASHER
Kenmore 66513154K701 DISHWASHER
Kenmore 66513154K702 DISHWASHER
Kenmore 66513159K700 DISHWASHER
Kenmore 66513159K701 DISHWASHER
Kenmore 66513159K702 DISHWASHER
Kenmore 66513163K700 DISHWASHER
Kenmore 66513163K701 DISHWASHER
Kenmore 66513163K702 DISHWASHER
Kenmore 66513163K703 DISHWASHER
Kenmore 66513169K700 DISHWASHER
Kenmore 66513169K701 DISHWASHER
Kenmore 66513169K702 DISHWASHER
Kenmore 66513169K703 DISHWASHER
Kenmore 66513173K700 DISHWASHER
Kenmore 66513173K701 DISHWASHER
Kenmore 66513173K702 DISHWASHER
Kenmore 66513173K703 DISHWASHER
Kenmore 66513173K704 UNDERCOUNTER DISHWASHER
Kenmore 66513182K800 DISHWASHER
Kenmore 66513182K801 DISHWASHER
Kenmore 66513182K802 DISHWASHER
Kenmore 66513183K800 DISHWASHER
Kenmore 66513183K801 DISHWASHER
Kenmore 66513183K802 DISHWASHER
Kenmore 66513189K800 DISHWASHER
Kenmore 66513189K801 DISHWASHER
Kenmore 66513189K802 DISHWASHER
Kenmore 66513192K900 DISHWASHER
Kenmore 66513192K901 UNDERCOUNTER DISHWASHER
Kenmore 66513192K902 DISHWASHER
Kenmore 66513193K900 DISHWASHER
Kenmore 66513193K901 UNDERCOUNTER DISHWASHER
Kenmore 66513193K902 DISHWASHER
Kenmore 66513194K900 DISHWASHER
Kenmore 66513194K901 UNDERCOUNTER DISHWASHER
Kenmore 66513194K902 DISHWASHER
Kenmore 66513199K900 DISHWASHER
Kenmore 66513199K901 UNDERCOUNTER DISHWASHER
Kenmore 66513199K902 DISHWASHER
Kenmore 66513206K901 UNDERCOUNTER DISHWASHER
Kenmore 66513206K902 DISHWASHER
Kenmore 66513212K901 UNDERCOUNTER DISHWASHER
Kenmore 66513212K902 UNDERCOUNTER DISHWASHER
Kenmore 66513213K900 UNDERCOUNTER DISHWASHER
Kenmore 66513213K901 UNDERCOUNTER DISHWASHER
Kenmore 66513213K902 UNDERCOUNTER DISHWASHER
Kenmore 66513219K901 UNDERCOUNTER DISHWASHER
Kenmore 66513219K902 UNDERCOUNTER DISHWASHER
Kenmore 66513222K600 DISHWASHER
Kenmore 66513222K601 DISHWASHER
Kenmore 66513223K600 DISHWASHER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE pump continues to run after cycle beacon1 Dishwasher Repair 0 11-28-2012 10:56 AM
kenmore cooktop igniter continues to click juliaadams Oven Repair (including Ranges and Cooktops) 1 08-05-2011 07:26 AM
dishwashers continues to pump wtr out and cycle again Buddy THompson Dishwasher Repair 1 05-18-2010 03:47 AM
dw continues to pump water with the door open Landendad Dishwasher Repair 1 12-02-2009 01:49 AM
Kenmore quit agitating and water continues to run oldparts Washer Repair 3 03-29-2008 09:14 AM
