Discuss
Replaced Tub Seal and Collar Bearing but still leaking
 in
Dishwasher Repair
Water keeps dripping from collar bearing onto the transmission. I have replaced the tub seal twice and the collar bearing
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Replaced Tub Seal and Collar Bearing but still leaking
  #1 (permalink)
Old 03-08-2017, 08:41 AM
Junior Member
john9454 is on a distinguished road
Default Replaced Tub Seal and Collar Bearing but still leaking
Model Number: WHDSR209G8WW   Brand: GE   Age: 5 - 10 years
Water keeps dripping from collar bearing onto the transmission. I have replaced the tub seal twice and the collar bearing once. Not sure why it still keeps doing this. I wiped down the trans shaft prior to re-assembly. I did not see any noticeable cracks in the tub when I had it removed. Is there a sealant that i should be applying to the outer ring of the seal? I applied dishwashing soap as recommended in the DIY videos. This has been a bit of a hassle, in that I had to drill and cut out the seized tub nut to begin with. I do not believe that i damaged anything while removing the collar bearing. However, I should admit that the inside face of the plastic in the sleeve area was a bit rough. But, water should not even be in that area to begin with. There is definitely water under the tub seal after removal. Any guidance would be greatly appreciated. Thanks.
Related Models
General Electric WHDSR209G8WW WASHER
General Electric WHDSR209G9WW WASHER
General Electric WHDSR315D0WW Washer
General Electric WHDSR315D5WW Washer
General Electric WHDSR315DAWW Washer
General Electric WHDSR315DBWW Washer
General Electric WHDSR315DCWW Washer
General Electric WHDSR315DDWW WASHER
General Electric WHDSR316G0WW Washer
General Electric WHDSR316G1WW WASHER
General Electric WHDSR316G2WW WASHER
General Electric WHDSR316G3WW WASHER
General Electric WHDSR316G4WW WASHER
General Electric WHDSR316G5WW WASHER
General Electric WHDSR316G6WW WASHER
General Electric WHDSR417D0WW Washer
General Electric WHDSR417D5WW Washer
General Electric WHDVH626F0GG Washer
General Electric WHDVH626F0WW Washer
General Electric WHDVH626H1GG WASHER
General Electric WHDVH626H1WW WASHER
General Electric WHDVH660H0BB Washer
General Electric WHDVH660H0GG Washer
General Electric WHDVH660H0MB WASHER
General Electric WHDVH660H0MS WASHER
General Electric WHDVH660H0WW Washer
General Electric WHDVH660H1BB WASHER
General Electric WHDVH660H1GG WASHER
General Electric WHDVH660H1MB WASHER
General Electric WHDVH660H1MS WASHER
General Electric WHDVH660H1WW WASHER
General Electric WHDVH680J0BB WASHER
General Electric WHDVH680J0GG WASHER
General Electric WHDVH680J0MB WASHER
General Electric WHDVH680J0MR WASHER
General Electric WHDVH680J0MS WASHER
General Electric WHDVH680J0WW WASHER
General Electric WHDVH680J1MR WASHER
General Electric WHDVH680J1MS WASHER
General Electric WHDVH680J1WW WASHER
Whirlpool WHE33311 30" Electric Range
Whirlpool WHE383311 30" ELECTRIC RANGE COOKTOP
Whirlpool WHP1000SB1 PEDESTAL
Whirlpool WHP1000SK0 PEDESTAL
Whirlpool WHP1000SK1 PEDESTAL
Whirlpool WHP1000SL0 PEDESTAL
Whirlpool WHP1000SL1 PEDESTAL
Whirlpool WHP1000SQ0 PEDESTAL
Whirlpool WHP1000SQ1 PEDESTAL
Whirlpool WHP1000ST0 PEDESTAL
Whirlpool WHP1000ST1 PEDESTAL
Whirlpool WHP1000SU1 PEDESTAL
Whirlpool WHP1500SA0 PEDESTAL
Maytag WHP1500SA1 PEDESTAL
Whirlpool WHP1500SB0 PEDESTAL
Maytag WHP1500SB1 PEDESTAL
Whirlpool WHP1500SC0 PEDESTAL
Maytag WHP1500SC1 PEDESTAL
Whirlpool WHP1500SL0 PEDESTAL
Maytag WHP1500SL1 PEDESTAL
Whirlpool WHP1500SQ0 PEDESTAL
Maytag WHP1500SQ1 PEDESTAL
Whirlpool WHP1500ST0 PEDESTAL
Maytag WHP1500ST1 PEDESTAL
Whirlpool WHP1500SU0 PEDESTAL
Maytag WHP1500SU1 PEDESTAL
Whirlpool WHP32812 30" Electric Range Self Clean Oven
Whirlpool WHP54802 30" Electric Range Self Clean Oven
Whirlpool WHP54803 30" Electric Range Self Clean Oven
Whirlpool WHP83812 30" ELECTRIC RANGE CERAN COOKTOP SELF CLEAN
General Electric WHRE5260E0CC Washer
General Electric WHRE5260E0WW Washer
General Electric WHRE5260E1CC Washer
General Electric WHRE5260E1WW Washer
General Electric WHRE5260E6CC Washer
General Electric WHRE5260E6WW Washer
General Electric WHRE5550H0WW WASHER
General Electric WHRE5550H1WW WASHER
General Electric WHRE5550H2WW WASHER
General Electric WHRE5550K0WW WASHER
General Electric WHRE5550K1WW WASHER
General Electric WHRE5550K2WW WASHER
General Electric WHRE5550K3WW WASHER
General Electric WHSB8000B0CC Washer
General Electric WHSB8000B0WW Washer
General Electric WHSB8000B1CC Washer
General Electric WHSB8000B1WW Washer
General Electric WHSB9000B0CC Washer
General Electric WHSB9000B0WC Washer
General Electric WHSB9000B0WW Washer
General Electric WHSE3100A0WB Washer
General Electric WHSE3100A2WB Washer
General Electric WHSE5240D0CC Washer
General Electric WHSE5240D0WW Washer
General Electric WHSE5240D1CC Washer
General Electric WHSE5240D1WW Washer
General Electric WHSE5240DCCC Washer
General Electric WHSE5240DCWW Washer
General Electric WHSR2070V2WB Washer
General Electric WHSR2070V3WB Washer
General Electric WICB103CV1WC Washer
Frigidaire WIDH3 Frg(v18) / Top Loading Washer
Frigidaire WIDH4 Frg(v3) / Top Load Washer
Frigidaire WIDL3 Frg(v19) / Top Loading Washer
Frigidaire WIDL4 Frg(v2) / Top Load Washer
Frigidaire WIDW3 Frg(v20) / Top Loading Washer
Frigidaire WIDW4 Frg(v1) / Top Load Washer
Frigidaire WILH1 Frg(v2) / 27 " Washer
Frigidaire WILL0 Frg(v2) / 27 " Washer
Frigidaire WILL1 Frg(v3) / 27 " Washer
Frigidaire WILW0 Frg(v1) / 27 " Washer
Frigidaire WILW1 Frg(v1) / 27 " Washer
Frigidaire WIMA1 Frg(v16) / Washer
Frigidaire WIMA2 Frg(v17) / Washer
Frigidaire WIMA3 Frg(v15) / Washer
Frigidaire WIMF1 Frg(v18) / Washer
Frigidaire WIMF2 Frg(v19) / Washer
Frigidaire WIMF3 Frg(v16) / Washer
Frigidaire WIMH1 Frg(v20) / Washer
Frigidaire WIMH2 Frg(v21) / Washer
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replaced seal and bearing also spider ToLLcrOss98 Washer Repair 0 01-21-2015 01:43 PM
Looking for a bearing and seal kit appliance1repair@gmail.co Washer Repair 1 09-25-2014 06:41 PM
LG washer leaking at back bearing and seal Ebeeler Washer Repair 3 07-17-2011 12:58 PM
Washing machine leaking 1 month after replacing tub and bearing seal brian mitchell Washer Repair 1 02-19-2010 03:55 PM
Leaking tub seal/bearing Mike Luke Washer Repair 1 10-10-2007 03:43 AM
