Discuss
Maytag dishwasher fills on 1st Cycle but not on following cycles
 in
Dishwasher Repair
To All: I have a Maytag Dishwasher Model MDBH979AWW3. It fills on the first (pre-rinse) cycle, cycles through and drains.
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Maytag dishwasher fills on 1st Cycle but not on following cycles
  #1 (permalink)
Old 02-18-2017, 08:57 AM
Junior Member
Tom Hawk is on a distinguished road
Default Maytag dishwasher fills on 1st Cycle but not on following cycles
Model Number: MDBH979AWW3   Brand: Maytag   Age: 1 - 5 years
To All:
I have a Maytag Dishwasher Model MDBH979AWW3. It fills on the first (pre-rinse) cycle, cycles through and drains. There is a pause when it is supposed to fill. No water flows into the machine but the detergent dispenser opens. Therefore, it must know where it is in the program. If left unattended, the pump works but no water sprays on the following cycles as there is no water in the machine. I started opening the machine after the pre-rinse cycle, filling it manually with water until the float valve rises to its proper height. I then close the door and press the "resume" button. It then runs through the wash cycle. After it drains, there is a pause when it should fill. As before, I then manually fill it with water, close the door and press the "resume" button. It completes the rinse cycle, progresses through the drying cycle and shuts off as normal.
Obviously, the fill valve and the float switch work or it would not fill for the pre-rinse cycle. All other functions work properly. The detergent dispenser opens properly, the heating element works, the drain and spray cycles work. The float valve is free, the machine is clean inside. Everything seems to work except the fill cycle on all cycles following the pre-rinse cycle. The issues are the same in the heavy, normal or light wash programs.
Since everything seems to work except the fill cycles following the pre-wash cycle, I suspect the circuit board is defective. Should I purchase and install a new circuit board or is there something else that may be the cause.
Thanks in advance for any help that may be offered.
Tom Hawk
Related Models
Maytag MDBH979AWW3 UNDERCOUNTER DISHWASHER
Maytag MDBH980AWB0 UNDERCOUNTER DISHWASHER
Maytag MDBH980AWB1 UNDERCOUNTER DISHWASHER
Maytag MDBH980AWB10 UNDERCOUNTER DISHWASHER
Maytag MDBH980AWB41 UNDERCOUNTER DISHWASHER
Maytag MDBH980AWB44 UNDERCOUNTER DISHWASHER
Maytag MDBH980AWB45 UNDERCOUNTER DISHWASHER
Maytag MDBH980AWQ0 UNDERCOUNTER DISHWASHER
Maytag MDBH980AWQ1 UNDERCOUNTER DISHWASHER
Maytag MDBH980AWQ10 UNDERCOUNTER DISHWASHER
Maytag MDBH980AWQ41 UNDERCOUNTER DISHWASHER
Maytag MDBH980AWQ44 UNDERCOUNTER DISHWASHER
Maytag MDBH980AWQ45 UNDERCOUNTER DISHWASHER
Maytag MDBH980AWS0 UNDERCOUNTER DISHWASHER
Maytag MDBH980AWS1 UNDERCOUNTER DISHWASHER
Maytag MDBH980AWS10 UNDERCOUNTER DISHWASHER
Maytag MDBH980AWS41 UNDERCOUNTER DISHWASHER
Maytag MDBH980AWS44 UNDERCOUNTER DISHWASHER
Maytag MDBH980AWS45 UNDERCOUNTER DISHWASHER
Maytag MDBH980AWW0 UNDERCOUNTER DISHWASHER
Maytag MDBH980AWW1 UNDERCOUNTER DISHWASHER
Maytag MDBH980AWW10 UNDERCOUNTER DISHWASHER
Maytag MDBH980AWW41 UNDERCOUNTER DISHWASHER
Maytag MDBH980AWW44 UNDERCOUNTER DISHWASHER
Maytag MDBH980AWW45 UNDERCOUNTER DISHWASHER
Maytag MDBH985AWB0 UNDERCOUNTER DISHWASHER
Maytag MDBH985AWB10 UNDERCOUNTER DISHWASHER
Maytag MDBH985AWB41 UNDERCOUNTER DISHWASHER
Maytag MDBH985AWB44 UNDERCOUNTER DISHWASHER
Maytag MDBH985AWB45 UNDERCOUNTER DISHWASHER
Maytag MDBH985AWS0 UNDERCOUNTER DISHWASHER
Maytag MDBH985AWS10 UNDERCOUNTER DISHWASHER
Maytag MDBH985AWS41 UNDERCOUNTER DISHWASHER
Maytag MDBH985AWS44 UNDERCOUNTER DISHWASHER
Maytag MDBH985AWS45 UNDERCOUNTER DISHWASHER
Maytag MDBH985AWW10 UNDERCOUNTER DISHWASHER
Maytag MDBH985AWW41 UNDERCOUNTER DISHWASHER
Maytag MDBH985AWW44 UNDERCOUNTER DISHWASHER
Maytag MDBH985AWW45 UNDERCOUNTER DISHWASHER
Maytag MDBH989AWB1 UNDERCOUNTER DISHWASHER
Maytag MDBH989AWB2 UNDERCOUNTER DISHWASHER
Maytag MDBH989AWB3 UNDERCOUNTER DISHWASHER
Maytag MDBH989AWQ1 UNDERCOUNTER DISHWASHER
Maytag MDBH989AWQ2 UNDERCOUNTER DISHWASHER
Maytag MDBH989AWQ3 UNDERCOUNTER DISHWASHER
Maytag MDBH989AWS1 UNDERCOUNTER DISHWASHER
Maytag MDBH989AWS2 UNDERCOUNTER DISHWASHER
Maytag MDBH989AWS3 UNDERCOUNTER DISHWASHER
Maytag MDBH989AWW1 UNDERCOUNTER DISHWASHER
Maytag MDBH989AWW2 UNDERCOUNTER DISHWASHER
Maytag MDBH989AWW3 UNDERCOUNTER DISHWASHER
Maytag MDBM601AWB DISHWASHER- UNDERCOUNTER
Maytag MDBM601AWB0 UNDERCOUNTER DISHWASHER
Maytag MDBM601AWB1 UNDERCOUNTER DISHWASHER
Maytag MDBM601AWB2 UNDERCOUNTER DISHWASHER
Maytag MDBM601AWB3 UNDERCOUNTER DISHWASHER
Maytag MDBM601AWQ DISHWASHER- UNDERCOUNTER
Maytag MDBM601AWQ0 UNDERCOUNTER DISHWASHER
Maytag MDBM601AWQ1 UNDERCOUNTER DISHWASHER
Maytag MDBM601AWQ2 UNDERCOUNTER DISHWASHER
Maytag MDBM601AWQ3 UNDERCOUNTER DISHWASHER
Maytag MDBM601AWS DISHWASHER- UNDERCOUNTER
Maytag MDBM601AWS0 UNDERCOUNTER DISHWASHER
Maytag MDBM601AWS1 UNDERCOUNTER DISHWASHER
Maytag MDBM601AWS2 UNDERCOUNTER DISHWASHER
Maytag MDBM601AWS3 UNDERCOUNTER DISHWASHER
Maytag MDBM601AWW DISHWASHER- UNDERCOUNTER
Maytag MDBM601AWW0 UNDERCOUNTER DISHWASHER
Maytag MDBM601AWW1 UNDERCOUNTER DISHWASHER
Maytag MDBM601AWW2 UNDERCOUNTER DISHWASHER
Maytag MDBM601AWW3 UNDERCOUNTER DISHWASHER
Maytag MDBM755AWB DISHWASHER- UNDERCOUNTER
Maytag MDBM755AWQ DISHWASHER- UNDERCOUNTER
Maytag MDBM755AWS DISHWASHER- UNDERCOUNTER
Maytag MDBM755AWW DISHWASHER- UNDERCOUNTER
Maytag MDBS561AWB DISHWASHER- UNDERCOUNTER
Maytag MDBS561AWB0 UNDERCOUNTER DISHWASHER
Maytag MDBS561AWB1 UNDERCOUNTER DISHWASHER
Maytag MDBS561AWB2 UNDERCOUNTER DISHWASHER
Maytag MDBS561AWB3 UNDERCOUNTER DISHWASHER
Maytag MDBS561AWQ0 UNDERCOUNTER DISHWASHER
Maytag MDBS561AWQ1 UNDERCOUNTER DISHWASHER
Maytag MDBS561AWQ2 UNDERCOUNTER DISHWASHER
Maytag MDBS561AWS DISHWASHER- UNDERCOUNTER
Maytag MDBS561AWS0 UNDERCOUNTER DISHWASHER
Maytag MDBS561AWS1 UNDERCOUNTER DISHWASHER
Maytag MDBS561AWS2 UNDERCOUNTER DISHWASHER
Maytag MDBS561AWS3 UNDERCOUNTER DISHWASHER
Maytag MDBS561AWW DISHWASHER- UNDERCOUNTER
Maytag MDBS561AWW0 UNDERCOUNTER DISHWASHER
Maytag MDBS561AWW1 UNDERCOUNTER DISHWASHER
Maytag MDBS561AWW2 UNDERCOUNTER DISHWASHER
Maytag MDBS561AWW3 UNDERCOUNTER DISHWASHER
Maytag MDBS661AWB DISHWASHER- UNDERCOUNTER
Maytag MDBS661AWQ DISHWASHER- UNDERCOUNTER
Maytag MDBS661AWS DISHWASHER- UNDERCOUNTER
Maytag MDBS661AWW DISHWASHER- UNDERCOUNTER
Maytag MDBTT50AWB DISHWASHER- UNDERCOUNTER
Maytag MDBTT50AWQ DISHWASHER- UNDERCOUNTER
Maytag MDBTT50AWS DISHWASHER- UNDERCOUNTER
Maytag MDBTT50AWW DISHWASHER- UNDERCOUNTER
Maytag MDBTT53AWB0 UNDERCOUNTER DISHWASHER
Maytag MDBTT53AWB1 UNDERCOUNTER DISHWASHER
Maytag MDBTT53AWW0 UNDERCOUNTER DISHWASHER
Maytag MDBTT53AWW1 UNDERCOUNTER DISHWASHER
Maytag MDBTT59AWB DISHWASHER- UNDERCOUNTER
Maytag MDBTT59AWQ DISHWASHER- UNDERCOUNTER
Maytag MDBTT59AWS DISHWASHER- UNDERCOUNTER
Maytag MDBTT59AWW DISHWASHER- UNDERCOUNTER
Maytag MDBTT60AWB DISHWASHER- UNDERCOUNTER
Maytag MDBTT60AWB0 UNDERCOUNTER DISHWASHER
Maytag MDBTT60AWB1 UNDERCOUNTER DISHWASHER
Maytag MDBTT60AWB2 UNDERCOUNTER DISHWASHER
Maytag MDBTT60AWB3 UNDERCOUNTER DISHWASHER
Maytag MDBTT60AWQ DISHWASHER- UNDERCOUNTER
Maytag MDBTT60AWQ0 UNDERCOUNTER DISHWASHER
Maytag MDBTT60AWQ1 UNDERCOUNTER DISHWASHER
Maytag MDBTT60AWQ2 UNDERCOUNTER DISHWASHER
Maytag MDBTT60AWQ3 UNDERCOUNTER DISHWASHER
Maytag MDBTT60AWS DISHWASHER- UNDERCOUNTER
  #2 (permalink)
Old 02-23-2017, 06:44 AM
Junior Member
Default
To All,
On Jake's recommendation (another forum) I replaced the fill valve. All is ok!
Tom
  #3 (permalink)
Old 02-23-2017, 08:03 AM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
Thanks for posting the "fix".
So many people get their appliance repaired, but never tell anyone how it was done or what the real problem was.
I didn't see this post before or I could have told you to check the water valve.
I've seen it many times before. I even spent more than an hour one day, laying on a guy's kitchen floor watching a dishwasher fill and drain and fill and drain waiting for it to fail. I'd checked it twice before and it worked just fine every time. Then the next day or so, it would fail to fill while I wasn't there and the customer would call me again.
The last time I was determined to wait till it failed so I could prove it was bad. Sure enough when it finally stopped filling the water the valve coil tested "open".
The coils have very fine wiring in them and they can develop a hairline crack in the winding that has continuity when cold, but opens up when the coil warms up.
Gas dryers have the same problem with their gas valve coils.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dishwasher won't run cycles, only fills a bit Snowfinch Dishwasher Repair 1 07-07-2015 02:48 PM
maytag dishwasher promply stops after it fills and attempts cycle start.. morelandjoseph Dishwasher Repair 0 07-24-2011 05:47 PM
Maytag Dishwasher fills but doesn't run cycle teachaudio Dishwasher Repair 3 06-08-2011 06:13 AM
