Hey all. I got this dishwasher secondhand but unused a few months ago. It had never been installed, all the stickers still inside, etc. I installed a new 2-way hot water valve under the sink and ran a SS line to the dishwasher. Got it all installed and plumbed in, ran the first load of dishes and it worked great.
Fast forward a few days, I run another load of dishes on the same cycle as the first time and it seems like there's not enough water cycling through the machine. It will run through a cycle normally, but afterwards the soap (tried liquid and the gel-packs) will be at the bottom of the machine unused and the dishes look as if I never ran a cycle.
Where should I start? Possibly a clogged water line or inlet?
Any input is much appreciated. Thanks
