Kenmore Dishwasher Model 665.16022403 (Ser FT1101577) does not seem to be working well. Last night I turned it on, filled soap dispenser (use the Cascade Complete from Costco) and turned on using Pot scrubber mode. I noticed there didn’t seem to be a lot of water swishing around inside. This morning I opened the dishwasher and there was still a bit of soap in the dispenser. Most of it seemed to be gone, but there was a fair amount (blue) trickling down the door. I had placed a plate in the spot that kind of covers the dispenser, but the door had opened. I moved the plate to a different spot and turned the dishwasher back on, but I did not hear the dishwasher fill with water like it does in the beginning. I opened the door and sprayed a bunch of water on the door to try to rinse most of the soap down to the bottom and tried the Smart Wash mode. Still did not seem to be water going into the dishwasher, just the amount I sprayed inside.
Does this seem to be a blockage or something like a check valve failure?
