Discuss
Control Board or Touch Panel? Kitchenaid
 in
Dishwasher Repair
This is a higher-end model with the touchpad hidden inside the door (not on the front). There are no physical
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Control Board or Touch Panel? Kitchenaid
  #1 (permalink)
Old 02-01-2017, 10:28 AM
Junior Member
Hannatwins is on a distinguished road
Default Control Board or Touch Panel? Kitchenaid
Model Number: KDTM 354DSS0   Brand: Kitchen Aid   Age: 1 - 5 years
This is a higher-end model with the touchpad hidden inside the door (not on the front). There are no physical buttons to push, it just senses the touch. Recently Start button would not always recognize a touch. The dishwasher worked great when we could push start up until yesterday. Now we can't select START. It appears CANCEL button may not work either (we don't usually use it, so not sure). These two buttons are on the far left of the touchpad, by the way. All other buttons to select wash and dry options light up and seem to work, but we can't start the machine. Ran the service test cycle and all lights on the panel lit up including start and cancel. It then ran through all the cycles fine. But, the start button still doesn't respond.
How can I determine if I need to replace the control panel or the touch pad? Thanks for any advice so I order the correct part.
Existing part numbers are: Touchpad W10537423-A and Control panel W10539792-Rev C
Related Models
Gaggenau KE262-6__
Gaggenau KE272-6__
Gaggenau KE282-6__
Amana KE5313 WASHER-TOP LOADING
Amana KE5513 WASHER-TOP LOADING
Amana KE6533 WASHER-TOP LOADING
Whirlpool KEBC101KBL0 OVEN
Whirlpool KEBC101KBL03 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC101KBL04 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC101KBL05 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC101KBL06 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC101KSS04 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC101KSS05 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC101KSS06 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC101KWH0 OVEN
Whirlpool KEBC101KWH03 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC101KWH04 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC101KWH05 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC101KWH06 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC107HBL0 ELECTRIC OVEN
Whirlpool KEBC107HBL1 BUILT-IN ELECTRIC OVEN
Whirlpool KEBC107HBL2 BUILT-IN ELECTRIC OVEN
Whirlpool KEBC107HBL3 ELECTRIC BUILT IN OVEN
Whirlpool KEBC107HBT0 ELECTRIC OVEN
Whirlpool KEBC107HBT1 BUILT-IN ELECTRIC OVEN
Whirlpool KEBC107HBT2 BUILT-IN ELECTRIC OVEN
Whirlpool KEBC107HBT3 ELECTRIC BUILT IN OVEN
Whirlpool KEBC107HWH0 ELECTRIC OVEN
Whirlpool KEBC107HWH1 BUILT-IN ELECTRIC OVEN
Whirlpool KEBC107HWH2 BUILT-IN ELECTRIC OVEN
Whirlpool KEBC107HWH3 ELECTRIC BUILT IN OVEN
Whirlpool KEBC107KBL0 OVEN
Whirlpool KEBC107KBL03 30" BUILT-IN ELECTRIC OVEN SELF CLEAN THERMAL CONVECTION
Whirlpool KEBC107KBL04 SELF CLEAN THERMAL CONVECTION 30" BUILT-IN ELECTRIC OVEN
Whirlpool KEBC107KBL05 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC107KBL1 30" BUILT IN OVEN
Whirlpool KEBC107KBS0 OVEN
Whirlpool KEBC107KBS1 30" BUILT IN OVEN
Whirlpool KEBC107KBT0 OVEN
Whirlpool KEBC107KBT03 30" BUILT-IN ELECTRIC OVEN SELF CLEAN THERMAL CONVECTION
Whirlpool KEBC107KBT04 SELF CLEAN THERMAL CONVECTION 30" BUILT-IN ELECTRIC OVEN
Whirlpool KEBC107KBT05 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC107KBT1 30" BUILT IN OVEN
Whirlpool KEBC107KSS0 OVEN
Whirlpool KEBC107KSS03 30" BUILT-IN ELECTRIC OVEN SELF CLEAN THERMAL CONVECTION
Whirlpool KEBC107KSS04 SELF CLEAN THERMAL CONVECTION 30" BUILT-IN ELECTRIC OVEN
Whirlpool KEBC107KSS05 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC107KSS1 30" BUILT IN OVEN
Whirlpool KEBC107KWH0 OVEN
Whirlpool KEBC107KWH03 30" BUILT-IN ELECTRIC OVEN SELF CLEAN THERMAL CONVECTION
Whirlpool KEBC107KWH04 SELF CLEAN THERMAL CONVECTION 30" BUILT-IN ELECTRIC OVEN
Whirlpool KEBC107KWH05 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC107KWH1 30" BUILT IN OVEN
Whirlpool KEBC141KBL0 ELECTRIC OVEN
Whirlpool KEBC141KBL03 24" BUILT-IN ELECTRIC SINGLE OVEN SELF-CLEAN
Whirlpool KEBC141KBL05 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC141KBL1 ELECTRIC OVEN
Whirlpool KEBC141KWH0 ELECTRIC OVEN
Whirlpool KEBC141KWH03 24" BUILT-IN ELECTRIC SINGLE OVEN SELF-CLEAN
Whirlpool KEBC141KWH05 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC141KWH1 ELECTRIC OVEN
Whirlpool KEBC147KBL0 ELECTRIC OVEN
Whirlpool KEBC147KBL03 24" BUILT-IN ELECTRIC SINGLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC147KBL04 24" BUILT-IN ELECTRIC SINGLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC147KBL05 24" BUILT-IN ELECTRIC SINGLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC147KBL06 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC147KBL07 24" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC147KBL08 24" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC147KBL1 ELECTRIC OVEN
Whirlpool KEBC147KSS04 24" BUILT-IN ELECTRIC SINGLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC147KSS05 24" BUILT-IN ELECTRIC SINGLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC147KSS06 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC147KSS07 24" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC147KSS08 24" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC147KWH0 ELECTRIC OVEN
Whirlpool KEBC147KWH03 24" BUILT-IN ELECTRIC SINGLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC147KWH04 24" BUILT-IN ELECTRIC SINGLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC147KWH05 24" BUILT-IN ELECTRIC SINGLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC147KWH06 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC147KWH07 24" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC147KWH08 24" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC147KWH1 ELECTRIC OVEN
Whirlpool KEBC147VBL00 24" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC147VBL02 24" BUILT-IN ELECTRIC OVEN SELF CLEAN
KitchenAid KEBC147VBL03 24" BUILT-IN ELECTRIC OVEN
Whirlpool KEBC147VSS00 24" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC147VSS02 24" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC147VWH00 24" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC147VWH02 24" BUILT-IN ELECTRIC OVEN SELF CLEAN
KitchenAid KEBC147VWH03 24" BUILT-IN ELECTRIC OVEN
Whirlpool KEBC167MSS00 36" BUILT-IN ELECTRIC OVEN THERMAL CONVECTION
Whirlpool KEBC167MSS01 36" BUILT-IN ELECTRIC OVEN THERMAL CONVECTION
Whirlpool KEBC167MSS02 36" BUILT-IN ELECTRIC OVEN THERMAL CONVECTION
Whirlpool KEBC167MSS03 36" BUILT-IN ELECTRIC OVEN THERMAL CONVECTION
Whirlpool KEBC167MSS04 36" BUILT-IN ELECTRIC OVEN THERMAL CONVECTION
Whirlpool KEBC167VSS00 36" BUILT-IN ELECTRIC OVEN THERMAL CONVECTION
KitchenAid KEBC167VSS01 36" BUILT-IN ELECTRIC OVEN
KitchenAid KEBC167VSS02 36" BUILT-IN ELECTRIC OVEN
Whirlpool KEBC171KBL0 OVEN
Whirlpool KEBC171KBL03 27" BUILT-IN ELECTRIC SINGLE OVEN SELF-CLEAN
Whirlpool KEBC171KBL04 27" BUILT-IN ELECTRIC SINGLE OVEN SELF-CLEAN
Whirlpool KEBC171KBL05 27" BUILT-IN ELECTRIC SINGLE OVEN SELF-CLEAN
Whirlpool KEBC171KBL06 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC171KSS04 27" BUILT-IN ELECTRIC SINGLE OVEN SELF-CLEAN
Whirlpool KEBC171KSS05 27" BUILT-IN ELECTRIC SINGLE OVEN SELF-CLEAN
Whirlpool KEBC171KSS06 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC171KWH0 OVEN
Whirlpool KEBC171KWH03 27" BUILT-IN ELECTRIC SINGLE OVEN SELF-CLEAN
Whirlpool KEBC171KWH04 27" BUILT-IN ELECTRIC SINGLE OVEN SELF-CLEAN
Whirlpool KEBC171KWH05 27" BUILT-IN ELECTRIC SINGLE OVEN SELF-CLEAN
Whirlpool KEBC171KWH06 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC177BT05 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool KEBC177HBL0 BUILT-IN ELECTRIC OVEN
Whirlpool KEBC177HBL1 BUILT-IN ELECTRIC OVEN
Whirlpool KEBC177HBL3 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBC177HBT0 BUILT-IN ELECTRIC OVEN
Whirlpool KEBC177HBT1 BUILT-IN ELECTRIC OVEN
Whirlpool KEBC177HBT3 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBC177HWH0 BUILT-IN ELECTRIC OVEN
Whirlpool KEBC177HWH1 BUILT-IN ELECTRIC OVEN
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jenn-Air start light not turning on, touch panel or control board? Jennairfrustrated Dishwasher Repair 11 05-15-2016 08:50 PM
Trying to determine bad control board or touch panel ndsports Dishwasher Repair 0 02-22-2016 09:44 AM
Touch Panel or Control Board Bad? patmac Microwave Repair 0 05-28-2015 01:13 PM
Touch Screen Control Panel does not respond to touch lauras711 Microwave Repair 1 10-23-2012 02:49 PM
Dishwasher touch panel or control board? Kebmike Dishwasher Repair 2 04-22-2008 06:44 PM
