Hello,
My Bosch Dishwasher is not filling up in the bottom. I can run the dishwasher and it works fine if, at the right point in the cycle, I open the door and fill it with water.
Here's what I've done to troubleshoot:
1. Checked the water pressure - all set! 2. Checked the hoses for blockage - all set! 3. Made sure drains were working fine. 3. (I know I'm not supposed to do this but...) I uninstalled the inlet valve and opened it... It was pretty clean!
I went ahead and ordered a new valve - which is why I figured I'd give taking it apart a go...
I pulled out the dishwasher and ran it - there is water going through the inlet valve. It almost seems like it's just not running long enough... Does anyone know how I can check that? How long is it supposed to run?
Is there something besides the inlet valve that could be causing this problem? Is there a computer timer or something that might be defective...
Any help troubleshooting this would be appreciated. Thanks!
