Discuss
GE Dishwasher Losing Water During Cycle
 in
Dishwasher Repair
Hello! My 6 yr old GE Dishwasher (GSD4060N00SS) is draining most of it's water during the normal wash cycles, so
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » GE Dishwasher Losing Water During Cycle
  #1 (permalink)
Old 01-09-2017, 12:11 PM
Junior Member
mdmitch2 is on a distinguished road
Default GE Dishwasher Losing Water During Cycle
Model Number: GSD4060N00SS   Brand: GE   Age: 5 - 10 years
Hello! My 6 yr old GE Dishwasher (GSD4060N00SS) is draining most of it's water during the normal wash cycles, so the dishes aren't getting clean, and the soap isn't dissolving.
I put it into service mode, and went through the operations, and everything seems to work normally except operation #9, which is listed as 'Auxiliary Pump / Drain Solenoid'. When I select this, I hear a fairly loud buzzing sound for a few seconds, and I can see the solenoid engaging, but the water doesn't drain. On the other hand, if I run the 'activate water valve' operation, it fills the basin to the correct level (about 3/8") above the bottom of the float cover, and the water stays at that level without draining. Then, within a few seconds of engaging the 'main pump' operation, the water level has drained to almost nothing, and certainly not enough to circulate.
I've already cleaned everything, and checked for clogs in all tubing, and screens, water valve, etc. I also replaced the impeller assembly because the chopper arm had fallen off due to worn out threads.
I've also tested the function of the float switch with a multimeter, and I measured all of the other components resistance, and everything seemed to be within spec. The only possible exception being the drain solenoid, which measure 33 ohms, rather than the 40 listed on the schematic. This number dropped into the 20's when I manually engaged the plunger. I'm thinking 33 ohms is probably fine since the solenoid seems to be engaging normally, and it's not THAT far off 40..... but I really don't know since I'm not a dishwasher tech!
The dishwasher has been working well for several years, and it seems to be in good shape apart from this issue, so I'd like to get it back up and running. Any suggestions on what might be wrong, and/or how to test/repair it?
Thanks!
Matt
Related Models
General Electric GSD4060N00SS DISHWASHER
General Electric GSD4060N10SS DISHWASHER
General Electric GSD4060N20SS DISHWASHER
General Electric GSD4060R00SS DISHWASHER
General Electric GSD4060R15SS DISHWASHER
General Electric GSD4100J00BB Dishwasher
General Electric GSD4100J00CC Dishwasher
General Electric GSD4100J00WW Dishwasher
General Electric GSD4110Y70AA Dishwasher
General Electric GSD4110Y72AA Dishwasher
General Electric GSD4110Y73AA Dishwasher
General Electric GSD4112Z02AA Dishwasher
General Electric GSD4112Z04AA Dishwasher
General Electric GSD4112Z05AA Dishwasher
General Electric GSD4112Z07AA Dishwasher
General Electric GSD4114Z02AA Dishwasher
General Electric GSD4114Z04AA Dishwasher
General Electric GSD4120Y01BB Dishwasher
General Electric GSD4120Y04BB Dishwasher
General Electric GSD4120Y70BB Dishwasher
General Electric GSD4120Y72BB Dishwasher
General Electric GSD4120Y73BB Dishwasher
General Electric GSD4122Z02BB Dishwasher
General Electric GSD4122Z04BB Dishwasher
General Electric GSD4122Z05BB Dishwasher
General Electric GSD4122Z07BB Dishwasher
General Electric GSD4124Z02BB Dishwasher
General Electric GSD4124Z04BB Dishwasher
General Electric GSD4130Y01WW Dishwasher
General Electric GSD4130Y04WW Dishwasher
General Electric GSD4130Y70WW Dishwasher
General Electric GSD4130Y72WW Dishwasher
General Electric GSD4130Y73WW Dishwasher
General Electric GSD4132Z02WW Dishwasher
General Electric GSD4132Z04WW Dishwasher
General Electric GSD4132Z05WW Dishwasher
General Electric GSD4132Z07WW Dishwasher
General Electric GSD4134Z02WW Dishwasher
General Electric GSD4134Z04WW Dishwasher
General Electric GSD4160J00SS Dishwasher
General Electric GSD4200J00BB Dishwasher
General Electric GSD4200J00CC Dishwasher
General Electric GSD4200J00WW Dishwasher
General Electric GSD4210X65AA Dishwasher
General Electric GSD4210X66AA Dishwasher
General Electric GSD4210X72AA Dishwasher
General Electric GSD4210X73AA Dishwasher
General Electric GSD4220X65BB Dishwasher
General Electric GSD4220X66BB Dishwasher
General Electric GSD4220X72BB Dishwasher
General Electric GSD4220X73BB Dishwasher
General Electric GSD4230X65WW Dishwasher
General Electric GSD4230X66WW Dishwasher
General Electric GSD4230X72WW Dishwasher
General Electric GSD4230X73WW Dishwasher
General Electric GSD4260J00SS Dishwasher
General Electric GSD4300L03BB Dishwasher
General Electric GSD4300L03WW Dishwasher
General Electric GSD4310Y72AA Dishwasher
General Electric GSD4310Y73AA Dishwasher
General Electric GSD4310Z00AA Dishwasher
General Electric GSD4310Z02AA Dishwasher
General Electric GSD4310Z04AA Dishwasher
General Electric GSD4315Z00AA Dishwasher
General Electric GSD4315Z02AA Dishwasher
General Electric GSD4315Z04AA Dishwasher
General Electric GSD4320Y72BB Dishwasher
General Electric GSD4320Y73BB Dishwasher
General Electric GSD4320Z00BB Dishwasher
General Electric GSD4320Z02BB Dishwasher
General Electric GSD4320Z04BB Dishwasher
General Electric GSD4325Z00BB Dishwasher
General Electric GSD4325Z02BB Dishwasher
General Electric GSD4325Z04BB Dishwasher
General Electric GSD4330Y72WW Dishwasher
General Electric GSD4330Y73WW Dishwasher
General Electric GSD4330Z00WW Dishwasher
General Electric GSD4330Z02WW Dishwasher
General Electric GSD4330Z04WW Dishwasher
General Electric GSD4335Z00WW Dishwasher
General Electric GSD4335Z02WW Dishwasher
General Electric GSD4335Z04WW Dishwasher
General Electric GSD4360L03SS Dishwasher
General Electric GSD4410X65AA Dishwasher
General Electric GSD4410X66AA Dishwasher
General Electric GSD4410X72AA Dishwasher
General Electric GSD4410X73AA Dishwasher
General Electric GSD4420X65BB Dishwasher
General Electric GSD4420X66BB Dishwasher
General Electric GSD4420X72BB Dishwasher
General Electric GSD4420X73BB Dishwasher
General Electric GSD4430X65WW Dishwasher
General Electric GSD4430X66WW Dishwasher
General Electric GSD4430X72WW Dishwasher
General Electric GSD4430X73WW Dishwasher
General Electric GSD4500G00BB Dishwasher
General Electric GSD4500G00CC Dishwasher
General Electric GSD4500G00WW Dishwasher
General Electric GSD4525F00BB DISHWASHER & DISPOSAL ACCESSORY
General Electric GSD454W-05 DISHWASHER
General Electric GSD454W-55 DISHWASHER
General Electric GSD4610Z00AA Dishwasher
General Electric GSD4610Z02AA Dishwasher
General Electric GSD4610Z04AA Dishwasher
General Electric GSD4620Z00BB Dishwasher
General Electric GSD4620Z02BB Dishwasher
General Electric GSD4620Z04BB Dishwasher
General Electric GSD4630Z00WW Dishwasher
General Electric GSD4630Z02WW Dishwasher
General Electric GSD4630Z04WW Dishwasher
General Electric GSD464W-54 DISHWASHER
General Electric GSD470S-45WA DISHWASHER
General Electric GSD470S-48WA DISHWASHER
General Electric GSD4800G00BB Dishwasher
General Electric GSD4800G00CC Dishwasher
General Electric GSD4800G00WW Dishwasher
General Electric GSD4800J01BB Dishwasher
General Electric GSD4800J01CC Dishwasher
General Electric GSD4860J01SS Dishwasher
General Electric GSD490M-01 Dishwasher
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dishwasher losing water during cycles CPDG23 Dishwasher Repair 2 01-08-2017 06:54 PM
Losing water, not agitating.. NinjaXij Washer Repair 1 01-02-2014 04:35 PM
Whirlpool dishwasher losing water during wash cycle brogge Dishwasher Repair 1 09-18-2011 04:50 PM
whirlpool dishwasher losing power fred4570 Dishwasher Repair 0 03-27-2011 03:39 AM
water overfilling/fan losing ground vinnytuco Refrigerator & Freezer Repair 0 08-05-2010 04:09 PM
