Discuss
Bosch dishwasher temporarily stops running mid-cycle, then starts back up
 in
Dishwasher Repair
Hi, I’m having a hard time troubleshooting the problem. SHORT VERSION At pretty much every drain/refill during the cycle, the
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch dishwasher temporarily stops running mid-cycle, then starts back up
  #1 (permalink)
Old 01-08-2017, 10:00 PM
Junior Member
mdub is on a distinguished road
Default Bosch dishwasher temporarily stops running mid-cycle, then starts back up
Model Number: SHY56A05UC / 23   Brand: Bosch   Age: 5 - 10 years
SHORT VERSION
At pretty much every drain/refill during the cycle, the dishwasher drains, then waits 30-45 before it starts refilling again to continue the wash cycle. I changed the computer, but the problem is still there. I'm thinking water inlet valve or water level sensor? Is there a way to test the sensor at the wire where it plugs into the computer? Not really sure how to test these... any help is appreciated!
LONG VERSION
When I start the cycle, it fills up and starts running like normal. After 10-15 min, the water drains out, refills, and the wash (or pre-wash) continues. After that batch of water drains out next time around, the dishwasher just sits there with nothing happening. The ‘wash’ light on the front is still lit like everything’s normal. If I wait somewhere around 30+ minutes (maybe even 45 min), all of the a sudden the water inlet opens, the dishwasher refills and the wash cycle continues like nothing ever happened. This happens constantly with every drain/refill throughout the wash cycle until the end, which means a load of dishes might take 4 or 5 hours to complete.
If I open & close the door, it doesn’t change anything. If I reset the wash cycle, it usually works, but sometimes doesn’t. I don’t know if the computer times out before resending a signal to the water valve (which would explain the open/close not working, but the cycle cancel/reset working), or what. When I open the door, the water is plenty hot, so I know it’s not a heating issue. I thought this was the computer board so I bought a replacement, but the problem continues. At this point, I’m thinking either a bad water valve, water level sensor or water overflow protection sensor? The water valve is accessible from the front panel so I can test if it’s getting voltage (haven’t done that yet), but since the timing is very predictable, I’m thinking maybe one of the other sensors? I’m not sure how the test the water level or overflow protection at the wire that plugs into the computer so I don’t have to pull the dishwasher out every time to test something different. Any ideas? Thanks for any help!!
Related Models
Bosch SHY56A06 UC/14 (FD8301-)
Bosch SHY66C02 UC/14 (FD8301-)
Bosch SHY66C05 UC/14 (FD8301-)
Bosch SHY66C06 UC/14 (FD8301-)
Bosch SHY99A02 UC/14 (FD 8212-)
Bosch SHY99A05 UC/14 (FD 8212-)
Bosch SHY99A06 UC/14 (FD 8212-)
Amana SI19E REF - SXS/I&W
General Electric SIG140060B SIGNATURE REFRIGERATOR
General Electric SIG1480A66WH DISHWASHER
General Electric SIG1482A68BA DISHWASHER
General Electric SIG60100T0WG SIGNATURE WASHER
General Electric SIG7010ET0WG SIGNATURE ELECTRIC DRYER
General Electric SIG7010ET1WG Electric dryer
Admiral SILVER22 REF - SXS/I&W
Admiral SILVER24 REF - SXS/I&W
Maytag SK525-2W REF - SXS
Maytag SK535-2 REF - SXS/I&W
Gaggenau SK590-2 REF - BOTTOM MOUNTS
Hardwick SKG4622MGA639R RANGE-F/S CONT CLEAN GAS
Hardwick SKG4622MGW639R RANGE-F/S CONT CLEAN GAS
Hardwick SKG9611A540R RANGE-F/S CONT CLEAN GAS
Hardwick SKG9611W540R RANGE-F/S CONT CLEAN GAS
Amana SKI22F REF - SXS/I&W
Amana SKI22F-A REF - SXS/I&W
Amana SKI22F-C REF - SXS/I&W
Amana SKI22F-G REF - SXS/I&W
Amana SKI22FL REF - SXS/I&W
Hardwick SKJ7141819DE WALLOVEN- CONT CLEAN GAS
Maytag SL10AN-A01 STACKED LAUNDRY- ELE
Maytag SL10AN-A02 STACKED LAUNDRY- ELE
Maytag SL10AN-A03 STACKED LAUNDRY- ELE
Maytag SL11AA STACKED LAUNDRY- ELE
Maytag SL11AN STACKED LAUNDRY- ELE
General Electric SL208 Room air conditioner
General Electric SL210 Room air conditioner
General Electric SL212 Room air conditioner
General Electric SL214 Room air conditioner
General Electric SL217 Room air conditioner
General Electric SL220 Room air conditioner
General Electric SL223 Room air conditioner
Amana SL22F REF - SXS/I&W
Amana SL22F-A REF - SXS/I&W
Amana SL22F-C REF - SXS/I&W
Amana SL22F-G REF - SXS/I&W
Amana SL22F-L REF - SXS/I&W
Amana SL22G REF - SXS/I&W
Amana SL22GL REF - SXS/I&W
Amana SL22JB REF - SXS/I&W
Amana SL22JB Ref - SXS/I&W
Amana SL22MBG REF - SXS/I&W
Amana SL22MBL REF - SXS/I&W
Amana SL22MBW REF - SXS/I&W
Amana SL25G REF - SXS/I&W
Amana SL25GL REF - SXS/I&W
Amana SL25H REF - SXS/I&W
Amana SL25J REF - SXS/I&W
Amana SL25J Ref - SXS/I&W
Amana SL25M2L REF - SXS/I&W
Amana SL25M2W REF - SXS/I&W
Amana SL25MG REF - SXS/I&W
Amana SL25ML REF - SXS/I&W
Amana SL25MW REF - SXS/I&W
Amana SLD22JB REF - SXS/I&W
Amana SLD22MB2L REF - SXS/I&W
Amana SLD22MB2W REF - SXS/I&W
Amana SLD22MBG REF - SXS/I&W
Amana SLD22MBL REF - SXS/I&W
Amana SLD22MBW REF - SXS/I&W
Amana SLD25J REF - SXS/I&W
Amana SLD25JB REF - SXS/I&W
Amana SLD25JP REF - SXS/I&W
Amana SLD25M2G REF - SXS/I&W
Amana SLD25M2L REF - SXS/I&W
Amana SLD25M2W REF - SXS/I&W
Amana SLD25MB2L REF - SXS/I&W
Amana SLD25MB2W REF - SXS/I&W
Amana SLD25MBG REF - SXS/I&W
Amana SLD25MBL REF - SXS/I&W
Amana SLD25MBW REF - SXS/I&W
Amana SLD25MG REF - SXS/I&W
Amana SLD25ML REF - SXS/I&W
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch Dishwasher Circ Pump starts & stops sabphi Dishwasher Repair 0 04-17-2014 11:49 AM
Whirlpool Dishwasher starts cycle for a few seconds, then stops tommy_boy Dishwasher Repair 2 09-22-2013 12:38 PM
Dryer stops, then starts back up on own, etc. Marcus L 75 Dryer Repair 0 05-21-2011 12:23 PM
Bosch Dishwasher stops during cycle couickj Dishwasher Repair 0 08-21-2010 05:56 AM
maytag dishwasher stops cycle starts clicking rainbow Dishwasher Repair 6 04-08-2008 08:20 PM
