Discuss
bosch dishwasher drain pump runs all the time
 in
Dishwasher Repair
Turn on machine and it only allows sump pump to run. Switches set to reg heavy does not matter. Pump
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » bosch dishwasher drain pump runs all the time
  #1 (permalink)
Old 12-31-2016, 08:22 AM
Junior Member
jimmy.faulkner is on a distinguished road
Default bosch dishwasher drain pump runs all the time
Model Number: SXX33RF5UC/64   Brand: Bosch   Age: 1 - 5 years
Turn on machine and it only allows sump pump to run. Switches set to reg heavy does not matter. Pump will pump water out but will not cycle and allow dishwasher to operate. Have already changed door switch prior from different issue. Where do I go from here to diagnose and order repair parts.
Related Models
Amana SZ22MBL REF - SXS/I&W
Amana SZ22MBW REF - SXS/I&W
Amana SZ22ML REF - SXS/I&W
Amana SZ22MW REF - SXS/I&W
Amana SZ22NE REF - SXS/I&W
Amana SZ22NL REF - SXS/I&W
Amana SZ22NW REF - SXS/I&W
Amana SZ25M2L REF - SXS/I&W
Amana SZ25M2W REF - SXS/I&W
Amana SZ25ML REF - SXS/I&W
Amana SZ25MP2L REF - SXS/I&W
Amana SZ25MP2W REF - SXS/I&W
Amana SZ25MPL REF - SXS/I&W
Amana SZ25MPW REF - SXS/I&W
Amana SZ25MW REF - SXS/I&W
Amana SZ25NE REF - SXS/I&W
Amana SZ25NL REF - SXS/I&W
Amana SZ25NW REF - SXS/I&W
Amana SZD20J Ref - SXS/I&W
Amana SZD20K REF - SXS/I&W
Amana SZD20KB REF - SXS/I&W
Amana SZD20KP REF - SXS/I&W
Amana SZD20MBL REF - SXS/I&W
Amana SZD20MBW REF - SXS/I&W
Amana SZD20ML REF - SXS/I&W
Amana SZD20MPE REF - SXS/I&W
Amana SZD20MPL REF - SXS/I&W
Amana SZD20MPW REF - SXS/I&W
Amana SZD20MW REF - SXS/I&W
Amana SZD20NE REF - SXS/I&W
Amana SZD20NL REF - SXS/I&W
Amana SZD20NPE REF - SXS/I&W
Amana SZD20NPL REF - SXS/I&W
Amana SZD20NPW REF - SXS/I&W
Amana SZD20NW REF - SXS/I&W
Amana SZD22M2L REF - SXS/I&W
Amana SZD22M2W REF - SXS/I&W
Amana SZD22MB2L REF - SXS/I&W
Amana SZD22MB2W REF - SXS/I&W
Amana SZD22MBL REF - SXS/I&W
Amana SZD22MBW REF - SXS/I&W
Amana SZD22ML REF - SXS/I&W
Amana SZD22MW REF - SXS/I&W
Amana SZD22NG REF - SXS/I&W
Amana SZD22NL REF - SXS/I&W
Amana SZD22NW REF - SXS/I&W
Amana SZD22S5E REF - SXS/I&W
Amana SZD22S5L REF - SXS/I&W
Amana SZD22S5W REF - SXS/I&W
Amana SZD23VE REF - SXS/I&W
Amana SZD23VL REF - SXS/I&W
Amana SZD23VW REF - SXS/I&W
Amana SZD25M2L REF - SXS/I&W
Amana SZD25M2W REF - SXS/I&W
Amana SZD25MB2L REF - SXS/I&W
Amana SZD25MB2W REF - SXS/I&W
Amana SZD25MBL REF - SXS/I&W
Amana SZD25MBW REF - SXS/I&W
Amana SZD25ML REF - SXS/I&W
Amana SZD25MP2L REF - SXS/I&W
Amana SZD25MP2W REF - SXS/I&W
Amana SZD25MPE REF - SXS/I&W
Amana SZD25MPL REF - SXS/I&W
Amana SZD25MPW REF - SXS/I&W
Amana SZD25MW REF - SXS/I&W
Amana SZD25N2E REF - SXS/I&W
Amana SZD25N2L REF - SXS/I&W
Amana SZD25N2W REF - SXS/I&W
Amana SZD25NE REF - SXS/I&W
Amana SZD25NL REF - SXS/I&W
Amana SZD25NW REF - SXS/I&W
Amana SZD25S5E REF - SXS/I&W
Amana SZD25S5L REF - SXS/I&W
Amana SZD25S5W REF - SXS/I&W
Amana SZD26VE REF - SXS/I&W
Amana SZD26VL REF - SXS/I&W
Amana SZD26VW REF - SXS/I&W
Amana SZD27KBL REF - SXS/I&W
Amana SZD27KBW REF - SXS/I&W
Amana SZD27KL REF - SXS/I&W
Amana SZD27KPL REF - SXS/I&W
Amana SZD27KPW REF - SXS/I&W
Amana SZD27KW REF - SXS/I&W
  #2 (permalink)
Old 01-09-2017, 05:14 PM
Junior Member
battaglia is on a distinguished road
Default Same issue, no solution
Hopefully an expert sees this and responds to both but I have the same issue even after changing out the water inlet valve and the float switch assembly. The machine worked for a couple of weeks then it started happening again, the drain pump runs continuously.
The only think I can think to try is disconnect every drain hose and make sure there isn't something in them or call a repair man.
  #3 (permalink)
Old 01-11-2017, 07:46 AM
Junior Member
mdub is on a distinguished road
Default
I'm not an expert, but from what I understand, it could be your water overflow safety switch that's stuck. I've heard of other people cleaning it out, or otherwise replacing it altogether. If it's on, it activates the drain pump, and if it's stuck, it would explain why the drain never stops.
  #4 (permalink)
Old 01-11-2017, 08:31 AM
Junior Member
Default
I'll check to see if it has one separate from the float switch assembly but i thought that is what i disconnected and reconnected when i changed out the whole blue plastic assembly.
  #5 (permalink)
Old 02-10-2017, 06:14 PM
Junior Member
scout186 is on a distinguished road
Default Also have same issue. Any luck fixing it?
I have the same issue. The drain pump runs continually, even with the door open. I've replaced the water inlet valve and the float switch. There is no water in the drain pan, and both floats move freely. I have manually triggered/released the new float switch and that doesn't change the fact that the drain pump is still running. Anyone find a fix?
  #6 (permalink)
Old 02-11-2017, 05:58 PM
Junior Member
TiDa is on a distinguished road
Default
I have the same issue on a SHE33M06UC/48 model Bosch dishwasher. I had to pop the breaker to keep it from filing and draining. Was doing so all night. I'll be interested to see if you get any feedback.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch Dishwasher Drain Pump won't run under a load. Mollywood Dishwasher Repair 0 04-08-2015 12:23 PM
Bosch dishwasher drain pump cycling on off RoberTX Dishwasher Repair 0 05-20-2014 07:51 PM
Bosch dishwasher drain pump ntkorbjr Dishwasher Repair 0 02-10-2013 08:55 AM
LG WM2277 Drain Pump Runs All the time souljoe Washer Repair 1 02-10-2012 04:36 PM
GE dishwasher drain pump runs continuously rogerabbit Dishwasher Repair 0 07-05-2009 10:55 AM
