lowjones
#1 Posted : Monday, November 2, 2009 12:28:46 PM(UTC)
lowjones
I ordered a new pump gasket to repair a leak. Do I have to apply any vaseline or sealer to it. Also how tight do I have to turn the locking ring?
Any tricks to install?
#2 Posted : Tuesday, November 3, 2009 3:00:45 AM(UTC)
Here is a munual that uses the same pump, at least it looks the same
http://www.servicematters.com/m...ibrary/docs/16010622.pdf
I would not use a sealer. I always put a light coating of grease/vaseline when ever I install seal/O rings.
lowjones
#3 Posted : Thursday, November 5, 2009 9:43:28 AM(UTC)
lowjones
I did get the pump on. I took out the dishwasher and worked on it in my garage. Best thing I ever did. It made it so easy. Thanks for the answer and link. I will definetly check it out..
