I have an LG dishwasher (LDS5540ST) that seems to be pumping out the water as its filling. When the wash cycle starts there's not enough water in the basin and the pump cavitates. Already replaced the fill valve, but no change. Would a faulty overflow switch set the drain pump off or should I suspect something else?
