Having some difficulty with my 2 year old Samsung. The unit displays an oE error code. It does not overfill. The fill valve opens for a bit, closes, then the drain pump kicks on and the unit drains. The drain pump will run excessively long. This will happen multiple times before the fault code is displayed. I have already replaced the main PCB. I appreciate your help!
