Discuss
KitchenAid Dishwasher Control Board Advice
 in
Dishwasher Repair
Hi people! I recently changed out the control board for my Kitchenaid KUDT03STSS03 after the dishwasher stopped washing/pumping and I
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » KitchenAid Dishwasher Control Board Advice
  #1 (permalink)
Old 11-28-2016, 01:37 PM
Junior Member
platypie is on a distinguished road
Default KitchenAid Dishwasher Control Board Advice
Model Number: KUDT03STSS03   Brand: Kitchen Aid   Age: 5 - 10 years
Hi people! I recently changed out the control board for my Kitchenaid KUDT03STSS03 after the dishwasher stopped washing/pumping and I found this module had melted/burned out. It seemed to be exactly what I needed and it functioned properly after the replacement. However, two weeks later my dishwasher did a repeat performance and burned out the new control board. I'm now weighing my options on this dishwasher. It is nearly eight years old, but as this dishwasher was a very expensive purchase in early 2009, I'm struggling with the decision to write it off without more of a fight. I'm trying to make sense of what may have caused the electronics to overheat like this. Does it make sense that the first meltdown compromised the wiring harness enough to cause the second meltdown? Is it likely or possible that a malfunctioning pump/capacitor assembly could cause enough heat in the harness and control board? If that is even feasible it might explain the first meltdown. But the pump/capacitor assembly is very expensive to replace on speculation. The dishwasher did seem to work fine for two weeks after replacing the control board the first time. But is it more likely that over eight years the control module just simply went bad, and that the second meltdown is probably just the result of the wiring harness having gone bad after the first control module meltdown? There is presently black sticky matter on the wiring harness (no exposed wires though). This could be either the wire insulation itself OR the adjacent black plastic lining on the inside of the dishwasher door. It is really hard to tell if the sticky gunky black is the lining, the wire, or a combination.
So this is just a potential last ditch effort to salvage the unit (originally a $1,200 purchase). I have to weigh the costs of experimenting again to repair it, which could range between $220 and $400 in parts or giving up on it - writing off all Whirlpool manufactured dishwashers - and replacing it with $540 Bosch (Ascenta Series Stainless Steel Built-In Dishwasher - SHE3AR75UC), on sale. Any advice will be appreciated. Thank you in advance for your help.
--Jeff
Related Models
Whirlpool KUDT03STSS1 UNDERCOUNTER DISHWASHER
Whirlpool KUDT03STSS2 UNDERCOUNTER DISHWASHER
Whirlpool KUDT03STSS3 UNDERCOUNTER DISHWASHER
Whirlpool KUDT03STWH0 UNDERCOUNTER DISHWASHER
Whirlpool KUDT03STWH1 UNDERCOUNTER DISHWASHER
Whirlpool KUDT03STWH2 UNDERCOUNTER DISHWASHER
Whirlpool KUDT03STWH3 UNDERCOUNTER DISHWASHER
KitchenAid KUDT23HY3 DISHWASHER
Whirlpool KUDU02FRBL0 UNDERCOUNTER DISHWASHER
Whirlpool KUDU02FRBL1 UNDERCOUNTER DISHWASHER
Whirlpool KUDU02FRBL2 UNDERCOUNTER DISHWASHER
Whirlpool KUDU02FRBL3 UNDERCOUNTER DISHWASHER
Whirlpool KUDU02FRBL4 UNDERCOUNTER DISHWASHER
Whirlpool KUDU02FRSS0 UNDERCOUNTER DISHWASHER
Whirlpool KUDU02FRSS1 UNDERCOUNTER DISHWASHER
Whirlpool KUDU02FRSS2 UNDERCOUNTER DISHWASHER
Whirlpool KUDU02FRSS3 UNDERCOUNTER DISHWASHER
Whirlpool KUDU02FRSS4 UNDERCOUNTER DISHWASHER
Whirlpool KUDU02FRWH0 UNDERCOUNTER DISHWASHER
Whirlpool KUDU02FRWH1 UNDERCOUNTER DISHWASHER
Whirlpool KUDU02FRWH2 UNDERCOUNTER DISHWASHER
Whirlpool KUDU02FRWH3 UNDERCOUNTER DISHWASHER
Whirlpool KUDU02FRWH4 UNDERCOUNTER DISHWASHER
Whirlpool KUDU02VRMT0 UNDERCOUNTER DISHWASHER
Whirlpool KUDU02VRMT1 UNDERCOUNTER DISHWASHER
Whirlpool KUDU02VRPA0 UNDERCOUNTER DISHWASHER
Whirlpool KUDU02VRSS0 UNDERCOUNTER DISHWASHER
Whirlpool KUDU02VRSS1 UNDERCOUNTER DISHWASHER
Whirlpool KUDU02VSPA1 UNDERCOUNTER DISHWASHER
Whirlpool KUDU02VSPA3 UNDERCOUNTER DISHWASHER
Whirlpool KUDU02VSPA4 UNDERCOUNTER DISHWASHER
Whirlpool KUDU03FTBL0 UNDERCOUNTER DISHWASHER
Whirlpool KUDU03FTBL1 UNDERCOUNTER DISHWASHER
Whirlpool KUDU03FTBL2 UNDERCOUNTER DISHWASHER
Whirlpool KUDU03FTBL3 UNDERCOUNTER DISHWASHER
Whirlpool KUDU03FTPA0 DISHWASHER
Whirlpool KUDU03FTPA1 UNDERCOUNTER DISHWASHER
Whirlpool KUDU03FTPA2 UNDERCOUNTER DISHWASHER
Whirlpool KUDU03FTPA3 UNDERCOUNTER DISHWASHER
Whirlpool KUDU03FTSS0 UNDERCOUNTER DISHWASHER
Whirlpool KUDU03FTSS1 UNDERCOUNTER DISHWASHER
Whirlpool KUDU03FTSS2 UNDERCOUNTER DISHWASHER
Whirlpool KUDU03FTSS3 UNDERCOUNTER DISHWASHER
Whirlpool KUDU03FTWH0 UNDERCOUNTER DISHWASHER
Whirlpool KUDU03FTWH1 UNDERCOUNTER DISHWASHER
Whirlpool KUDU03FTWH2 UNDERCOUNTER DISHWASHER
Whirlpool KUDU03FTWH3 UNDERCOUNTER DISHWASHER
Whirlpool KUDU03STBL0 UNDERCOUNTER DISHWASHER
Whirlpool KUDU03STBL1 UNDERCOUNTER DISHWASHER
Whirlpool KUDU03STBL2 UNDERCOUNTER DISHWASHER
Whirlpool KUDU03STBL3 UNDERCOUNTER DISHWASHER
Whirlpool KUDU03STSS0 UNDERCOUNTER DISHWASHER
Whirlpool KUDU03STSS1 UNDERCOUNTER DISHWASHER
Whirlpool KUDU03STSS2 UNDERCOUNTER DISHWASHER
Whirlpool KUDU03STSS3 UNDERCOUNTER DISHWASHER
Whirlpool KUDU03STWH0 UNDERCOUNTER DISHWASHER
Whirlpool KUDU03STWH1 UNDERCOUNTER DISHWASHER
Whirlpool KUDU03STWH2 UNDERCOUNTER DISHWASHER
Whirlpool KUDU03STWH3 UNDERCOUNTER DISHWASHER
Whirlpool KUDV24SEAL0 UNDERCOUNTER DISHWASHER
Whirlpool KUDV24SEAL1 UNDER COUNTER DISHWASHER
Whirlpool KUDV24SEAL2 UNDERCOUNTER DISHWASHER
Whirlpool KUDV24SEAL3 UNDERCOUNTER DISHWASHER
Whirlpool KUDV24SEAL4 UNDERCOUNTER DISHWASHER
Whirlpool KUDV24SEAL5 UNDERCOUNTER DISHWASHER
Whirlpool KUDV24SEBL0 UNDERCOUNTER DISHWASHER
Whirlpool KUDV24SEBL1 UNDER COUNTER DISHWASHER
Whirlpool KUDV24SEBL2 UNDERCOUNTER DISHWASHER
Whirlpool KUDV24SEBL3 UNDERCOUNTER DISHWASHER
Whirlpool KUDV24SEBL4 UNDERCOUNTER DISHWASHER
Whirlpool KUDV24SEBL5 UNDERCOUNTER DISHWASHER
Whirlpool KUDV24SEWH0 UNDERCOUNTER DISHWASHER
Whirlpool KUDV24SEWH1 UNDER COUNTER DISHWASHER
Whirlpool KUDV24SEWH2 UNDERCOUNTER DISHWASHER
Whirlpool KUDV24SEWH3 UNDERCOUNTER DISHWASHER
Whirlpool KUDV24SEWH4 UNDERCOUNTER DISHWASHER
Whirlpool KUDV24SEWH5 UNDERCOUNTER DISHWASHER
Whirlpool KUDV25SHBL2 DISHWASHER
Whirlpool KUDV25SHBT2 DISHWASHER
Whirlpool KUDV25SHWH2 DISHWASHER
Whirlpool KUDW02FRBL0 UNDERCOUNTER DISHWASHER
Whirlpool KUDW02FRBL2 UNDERCOUNTER DISHWASHER
Whirlpool KUDW02FRBL3 UNDERCOUNTER DISHWASHER
Whirlpool KUDW02FRBL4 UNDERCOUNTER DISHWASHER
Whirlpool KUDW02FRSS0 UNDERCOUNTER DISHWASHER
Whirlpool KUDW02FRSS2 UNDERCOUNTER DISHWASHER
Whirlpool KUDW02FRSS3 UNDERCOUNTER DISHWASHER
Whirlpool KUDW02FRSS4 UNDERCOUNTER DISHWASHER
Whirlpool KUDW02FRWH0 UNDERCOUNTER DISHWASHER
Whirlpool KUDW02FRWH2 UNDERCOUNTER DISHWASHER
Whirlpool KUDW02FRWH3 UNDERCOUNTER DISHWASHER
Whirlpool KUDW02FRWH4 UNDERCOUNTER DISHWASHER
Whirlpool KUDW03CTBL0 UNDERCOUNTER DISHWASHER
Whirlpool KUDW03CTBL1 UNDERCOUNTER DISHWASHER
Whirlpool KUDW03CTBL2 UNDERCOUNTER DISHWASHER
Whirlpool KUDW03CTBL3 UNDERCOUNTER DISHWASHER
Whirlpool KUDW03CTSS0 UNDERCOUNTER DISHWASHER
Whirlpool KUDW03CTSS1 UNDERCOUNTER DISHWASHER
Whirlpool KUDW03CTSS2 UNDERCOUNTER DISHWASHER
Whirlpool KUDW03CTSS3 UNDERCOUNTER DISHWASHER
Whirlpool KUDW03CTWH0 UNDERCOUNTER DISHWASHER
Whirlpool KUDW03CTWH1 UNDERCOUNTER DISHWASHER
Whirlpool KUDW03CTWH2 UNDERCOUNTER DISHWASHER
Whirlpool KUDW03CTWH3 UNDERCOUNTER DISHWASHER
Whirlpool KUDX03FTSS0 UNDERCOUNTER DISHWASHER
Whirlpool KUDX03FTSS1 UNDERCOUNTER DISHWASHER
Whirlpool KUDX03FTSS2 UNDERCOUNTER DISHWASHER
Whirlpool KUDX03FTSS3 UNDERCOUNTER DISHWASHER
Whirlpool KUDX23HB0 DISHWASHER
Whirlpool KUDY24SEAL0 UNDER COUNTERTOPS-DISHWASHER
Whirlpool KUDY24SEAL5 UNDERCOUNTER DISHWASHER
Whirlpool KUDY24SEBL0 UNDER COUNTERTOPS-DISHWASHER
Whirlpool KUDY24SEBL5 UNDERCOUNTER DISHWASHER
Whirlpool KUDY24SEWH0 UNDER COUNTERTOPS-DISHWASHER
Whirlpool KUDY24SEWH5 UNDERCOUNTER DISHWASHER
Whirlpool KUDY25SHBL0 UNDERCOVER DISHWASHER
Whirlpool KUDY25SHWH1 DISHWASHER
Whirlpool KUIA15NLHS11 ICE CUBE MAKER
Whirlpool KUIA15NLHS4 ICE CUBE MAKER
Whirlpool KUIA15NLHS5 ICE CUBE MAKER
  #2 (permalink)
Old 11-28-2016, 11:53 PM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
Do you have pictures of the burnt boards and wiring harness? It might help if we could see it.
  #3 (permalink)
Old 11-29-2016, 12:02 PM
Junior Member
Default
Thanks for the suggestion. Here are a few pics of the wiring harness, control module and the interior of the door with the black plastic lining which appears to have been damaged by the heat. I've concluded that the black is definitely a combination of overheated wire insulation and the burnt black plastic lining of inside the door. The control module model number is WPW10084141. Have a look:
On the module, the connector that burned out has connections P9, P8, and P6. The most damaged/melted portion of the connector plug is at the P9 (wire blue and red) point on the module which according to wiring diagram is associated with the pump. P8 is associated with the thermal fuse (power source) and P6, the door latch. Just because P9 is pump related doesn't necessarily mean the pump is the problem. Any short could cause excessive heat in a vulnerable node. Right? And if the insulation of the individual wires in the wiring harness were compromised, current could randomly bleed through to any or all the other wires that are wrapped together causing any manner of short. This is why I'm at a loss for a conclusion. I'm really starting to lean away from repairing this dishwasher and toward replacing it instead. If I hazard a guess I could end up replacing the control board several times for each bad guess.
Thanks again for looking and any feedback you can offer.
--Jeff
  #4 (permalink)
Old 11-29-2016, 01:17 PM
ThatGuy's Avatar
Expert
APP Volunteer
Default
Wow! Those pictures tell quite the story.
Its a story of bad connections and the heat they create. At the very least you would need to cut back the wiring harness to get to good copper and splice in new wire and connectors.
This is one of the reasons I don't like these multiple pin push on connectors. Its hard to tell if all the terminals are making a tight connection.
When dealing with electricity clean and tight connections are so important.
Any loose or dirty connection will create resistance and heat. The hotter it gets the more it destroys itself. Then catastrophic failure.
If you could repair the wiring harness and make solid connections to the board it might work. But the board would need to be rebuilt or replaced. There is also a possibility that there are other problems.
If you are half way talked in buying a new DW, that might be the best way to go.
  #5 (permalink)
Old 11-29-2016, 02:02 PM
Junior Member
Default
Yea, there isn't enough positively good wire on that harness close enough for the connectors to reach the control module if I were to cut it down. The burn marks you can see on the door liner show that the wires were hot roughly halfway down. The harness (around $90) would need to be replaced. In all likelihood the control board would need to be replaced (brand new, $200, but cheaper if refurbished and sold on ********), and the thermal fuse ($20), too. And then there could be a deeper cause for the short, like something in the pump capacitor or electronic door latch mechanism. This looks like a loss - or at best a major headache. As stubborn as I can be, I think I have to admit defeat.
It's difficult to avoid Whirlpool-made dishwashers - it seems they make units for so many other companies (Kenmore, Maytag, Kitchenaid, etc.). I'll shop for a Bosch this time. Nobody is perfect, but this experience is going to leave a mark on me. That thing was very expensive, and it couldn't quite reach an eight year life.
Thanks for your input!
--Jeff
  #6 (permalink)
Old 11-29-2016, 02:40 PM
ThatGuy's Avatar
Expert
APP Volunteer
Default
I've always bought Whirlpool and I did factory service for Whirlpool, Frigidaire, and Maytag for 20+ years. That said, the quality of the appliances isn't as good as it should be. In fact its fair to poor. Too much plastic, computers, and touch panels.
Complicated appliances break easier and cost more to fix. Simple is better, simple is good.
  #7 (permalink)
Old 04-03-2017, 11:08 AM
Junior Member
grammy57 is on a distinguished road
Default What brand dishwasher?
I have a Frigidaire that seems to have died. What brand would you recommend?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchenaid Dishwasher repair advice hneuwirth Oven Repair (including Ranges and Cooktops) 0 10-17-2016 11:05 AM
KitchenAid Dishwasher - "new" control board = dead dishwasher Bobo827 Dishwasher Repair 1 08-09-2013 01:46 PM
Advice on Control Board Jim needs help! Dryer Repair 0 02-06-2012 04:50 PM
control board for kitchenaid kudm01tjbl pat1w0 Dishwasher Repair 8 06-16-2009 12:58 PM
Kitchenaid control board merceris Refrigerator & Freezer Repair 1 08-27-2007 10:36 AM
