Our 23 month old BOSCH dishwasher totally stopped. No power. Had the Bosch Factory Technician out to the expense tune of $254, not including the TERMINAL BLOCK for an addition $61. (which you can purchase online for @$16) BOSCH has a recall on older TERMINAL BLOCKS part, but not the model shown above, nor the Terminal Block part- MFG CODE/REF: 9820045848
The Technician blamed it on the person installing the white wire into the terminal block. Stating they did not tighten it tightly, so it caused a spark that then blew out the terminal box.
I call this a major flaw design, which I am pursing with the BSH Home Appliance Corp through the BOSCH website.
So save yourself alot of $, By checking the Terminal Block.
