spock
#1 Posted : Saturday, November 19, 2016 10:41:13 AM(UTC)
spock
I have a kitchen aid dishwasher that does not dry the dishes after any cycle. Additionally it will not heat the water for high temperature settings. I have tested the heating element with an ohm meter and it tests ok. I have also tested the thermostat and it tests ok as well. (closed) Since kitchen aid does not supply a wiring diagram, I don't know if the next step is to replace the control board or the timer. Any help would be appreciated.
ThatGuy
#2 Posted : Saturday, November 19, 2016 2:32:27 PM(UTC)
ThatGuy
Groups: Expert
United States
If the parts test OK and the wiring is good all the way back to the computer/electronic control, logically its probably the bad part. W10854215
Whirlpool W10854215 Cntrl-Elec - AppliancePartsPros.com
spock
#3 Posted : Sunday, November 20, 2016 8:48:34 AM(UTC)
spock
Thanks for the reply! I located the directions for accessing the diagnostics and was able to reset the electronic / computer control. It had set an error code for a draining problem. I assume it was an isolated event so after resetting I will run the dishwasher through a cycle and see if it dries the dishes. Will update forum. Thanks again for the reply.
dishwasher heater not working (Dishwasher Repair)
by Caldwell 10/25/2007 12:46:57 PM(UTC)
