Dishwasher stopped working last week. Have checked thermal fuse and have power to the control board, door switch also tested good. If I unplug control board and reconnect the steam clean light will come on. After closing the door the dishwasher runs through a drain cycle and stops. Will not respond to any button push unless I disconnect the control board power. I am leaning toward a bad control board rather then panel but would like confirmation I am not missing something.
