I first discovered the repair video on how to replace the Orings on the circulation pump. Removed dishwasher from under countertop..ect. It seemed simple enough. The front (smaller) Oring had a small stretch, like the letter U on the edge, so I assumed that was the problem. But, after I assembled it back together, it still leaks. Leaks in the same spot. There doesn't seem to be any gaps and it leaks fairly fast. I am able to test it without installing it back underneath the counter...now. I reseated the pump one more time, but still leaks....right on the metal brace that secures it.
