Discuss
Roach Motel Eviction Notice
 in
Dishwasher Repair
My start buttons are not working on my Jenn Air and when I opened the control panel, there is Roach
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Roach Motel Eviction Notice
  #1 (permalink)
Old 10-17-2016, 07:23 AM
Junior Member
DaisyLove is on a distinguished road
Default Roach Motel Eviction Notice
Brand: Jenn-Air   Age: 1 - 5 years
My start buttons are not working on my Jenn Air and when I opened the control panel, there is Roach waste all over it...I am going to gently clean it off with alcohol and HOPE that that fixes it...is there a way to prevent these squatters from living inside my dishwasher?
  #2 (permalink)
Old 10-17-2016, 08:20 AM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
Roach Prufe!
Get some, put it under your DW and kill all the roaches. It really works!
  #3 (permalink)
Old 10-17-2016, 09:11 AM
Junior Member
Default
I am getting the Roach Prufe today!!! Thank you ThatGuy!!
So, I cleaned all the roach poop off gently with alcohol and q-tips (see before and after) but read in another thread (see attached) to remove ribbon cable and clean edge but I don't think my ribbon cable can be removed. Is there anything else I can unattached and clean the poop to make sure it's all clean (and HOPEFULLY working :-)
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
Read more: Jenn-Air start light not turning on, touch panel or control board?
Appliance Repair Forum - Free Service from Appliance Parts Pros
File Type: jpg Screen Shot 2016-10-17 at 12.09.07 PM.jpg (44.2 KB, 5 views)
File Type: jpg Screen Shot 2016-10-17 at 12.10.19 PM.jpg (32.8 KB, 5 views)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
notice a problem has been detected with this unit nique - CT Washer Repair 1 07-16-2013 08:42 PM
The Roach did it! borth Refrigerator & Freezer Repair 2 10-24-2012 03:07 AM
