Rank:: Member
My dishwasher is leaking only when running not when it is pumping out. Water seems to be coming from bottom of the pump however pump is running fine. Is there a gasket I can replace or do I need to replace the whole pump? I haven't pulled the unit out, I have just observed the unit from undeneath while running.
