Register | FAQ's | New Posts | Today's Posts | Extras |
» year 2000 KitchenAid dishwasher doesn't drain at all |
![]() Model Number: KUDC25CHSS1 Brand: Kitchen Aid Age: More than 10 years
![]() Hi, RE: KUDC25CHSS1 Dishwasher type with vertical motor and pump directly under lower arm Doesn't drain any water. Hose not clogged. Motor runs. Besides the impeller, what else could cause the problem? Is the motor supposed to reverse to pump? Related Models |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
![]() The motor should reverse to pump out. When I used to work on these, I found all kinds of stuff stuck in the screens and impeller area.
Another thing I used to see all the time was a cracked impeller. It cracks and leaks water into the motor shaft rusting it and sticking the impeller on the shaft. It can make the job a lot harder. The impeller kit is here, there is a video too. Whirlpool 675806 Drain & Wash Impeller Kit - AppliancePartsPros.com |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Frigidaire 2000 Series will not drain | getrdone | Dishwasher Repair | 1 | 03-06-2011 12:27 PM |
Kitchenaid Dishwasher won't drain | crestlake | Dishwasher Repair | 0 | 05-10-2010 01:43 PM |
Estate Top Loading Washer Grinding spin cycle (Model year 2000?) | fareall | Washer Repair | 1 | 08-31-2009 02:29 AM |
2 year old GE Dishwasher Will Not Drain. | gmguy01 | Dishwasher Repair | 1 | 03-24-2009 07:25 PM |
Kitchenaid Dishwasher (drain air gap problem) | Janice | Dishwasher Repair | 0 | 04-01-2008 03:46 PM |
