boschgirl1
#1 Posted : Sunday, November 1, 2009 12:27:17 PM(UTC)
boschgirl1
My Bosch dishwasher, only 3 yrs. old, will not empty the soap dispenser. This is leaving my dishes dirty. I've cleaned the spray arms and filter getting the same results. Do I need a professional repair or can someone help me through this?
Thanks,
Boschgirl1
MrD
#2 Posted : Thursday, May 2, 2013 6:28:19 PM(UTC)
MrD
I had a similar problem where the soap packets would turn into a gooey mess and remain stuck in the dispenser.
After much research, I stumbled across a description of the function of the wax motor. Based on the description, I came to the conclusion that the motor/actuator system that operates the soap dispenser, ALSO activates the rinse. OR - another way of saying it would be that the FIRST time the motor is activated, it dispenses soap. The SECOND time the motor is activated, it dispenses rinse.
What would happen if you were to interrupt the dishwasher AFTER the soap was dispensed and BEFORE the rinse.
I ran an empty cycle for about 20 - 30 minutes ... interrupted the cycle ... then ran it again.
Yeah ... the problem was fixed and it has been working flawlessly for about a month now.
BEFORE you spend a bunch of money on parts and the labor to replace the unit, try this "free" approach. I hope it works for you like it did for me.
soap dispenser not emptying (Dishwasher Repair)
by boschgirl1 11/1/2009 12:33:43 PM(UTC)
